posted 06-16-2010 11:44 PM ET (US)
On an E-TEC 90-HP, the moving portion of the remote throttle cable connects to the throttle cam, which pivots on a boss machined into the engine block. The throttle cam pushes against a roller on the throttle lever. The shape of the throttle cam translates the motion of the remote throttle handle into movement of the roller and thus the throttle lever. The throttle lever connects via a metal rod linkage to the throttle body shaft, opening the throttle. The throttle is considered to be wide-open then the throttle plate is oriented in the throttle body so as to have minimal restriction of the air flow. If the throttle body is rotated further, the air flow is restricted as the throttle begins to close the passage. |
