| Author | Topic: E-TEC Longevity |
LOCKEMAN'S HARDWARE and BOAT recently serviced a pair of E-TEC 150-HP motors from a U.S. Army Corps of Engineers (USACE) boat. The engines are model E150DPXSUF, which means they are 2007 model year. I believe they have been in service for three years, possibly four years. The engines have accumulated about 1,730-hours running time. The last time the engines were in for service was in the spring of this year, when they had about 1,180-hours. This season the Corps ran 550-hours on the motors pushing their work boat around. If this boat had been powered with a pair of four-cycle engines, and if the recommended oil change service had been performed every 100-hours, these two motors would have had their oil changed 17-times each, or 34-oil changes. They would have had five oil change each, just this season. The engines have three times been winterized using the built-in auto-winterization feature of the E-TEC. |
| Jefecinco |
The engines should be broken in in another year or so. They'll probably be replaced as a preventive maintenance step by then. The Corps generally looks at outboard engines and small boats about the way the Navy does. At a certain somewhat early age it's time to replace them to avoid downtime. The Corps (USACE) spends an incredible amount of money maintaining waterways including locks and dams and hydro power plants but treats vehicles and small craft as consumables. From a business perspective it may make some sense but I never appreciated it when I was part of it. Butch |
| hauptjm |
jimh, What were the two engines serviced for and what was Lockeman's take on the overall "health" of these motors? After that amount of use, it would be interesting to see what mechanicals and techincals were/were not affected by such. I think our military complex offers a great testing ground for both boats and motors. No one is babying these boats! |
| Tohsgib |
With synthetic oil it would have only been 8 oil changes. Let's say they average 5gph per tank so that would be 8500 gallons of fuel and say 100:1 would be 85 gals of oil at say $40 gal or $3400. Let's cut that in half because they got better mileage, better fuel ratios and better MPG and make it $1700 in oil. 8 oil changes at $100ea is how much? |
| Perry |
$1700 in 2 stroke oil vs. $800 in motor oil for the 4 stroke over the same time period, now that puts things in perspective. |
I imagine that if you run a pair of E-TEC engines this much per season you could probably buy the XD100 oil in a 55-gallon drum, which would lower the price considerably below the estimated $40 per gallon. I buy my oil in one-gallon units and I don't pay anywhere near $40 per gallon, more like $30-per-gallon in one-gallon buys. We can hash out the financials of two-cycle versus four-cycle again in another thread. There are already prior discussions on this topic which have found little difference in overall cost. The out-of-service time is more significant. If you have to haul a large boat, drag it over to the dealer, and have the oil changed five or six times per year, that is a pain in the neck. Plus you cannot use the boat. Or, do you hire a mechanic at $75,000-per-year with government benefits so the USACE engineers running the boat don't have to spend a couple weeks each year changing the oil? For most four-cycle outboard motor owners the oil change is a once-a-year procedure, or rather a once-a-year messy, dirty procedure, that is tolerable at that frequency. At a once-every-two-week interval, changing oil in four-cycle outboard motors becomes more of a drudgery. I thought it was interesting to see 1,700-hours on the E-TEC. I wonder if there is a VERADO in this kind of service with that much running time in three years? Comments from other government users of the VERADO looked like they were trading them in at the end of one season with about 1,000-hours. That is a great deal for Mercury, as they get to sell two or three times as many motors as Evinrude to these high-hour users. |
I don't understand how the four-cycle outboard oil change interval got pushed to 200-hours. These are motors in heavy service, so it would be more likely that the oil change interval would be shortened to every-50-hours, not lengthened to every-200-hours. |
| Tohsgib |
200 hours is with synthetic oil like I mentioned above. Just like with a car, the more it is used the less frequent the oil needs to be changed. Heavy use is not an issue with outboards as they all see heavy use. If you read your car manual it will usually say heavy use is towing or use on dirt roads, etc...which neither applies to an outboard. Lastly in your first post: "If this boat had been powered with a pair of four-cycle engines, and if the recommended oil change service had been performed every 100-hours, these two motors would have had their oil changed 17-times each, or 34-oil changes. They would have had five oil change each, just this season." I did not think my post was out of line, just pointing out that even at $20/gal it is cheaper to maintain a 4 stroke over 1700 hours. Most commercial companies or federal agencies have their own maintenance yards, they do not tow to dealers. Being all the Gov or commercial boats by me run 4 strokes, I know they do not go to the dealer, just like Cop cars do not go to Jiffy Lube. The Army Corps by me runs Hondas. |
| Buckda |
Correct me if I'm wrong. I don't use a synthetic oil in my automobile. My understanding is that even with the prolonged service interval, you still need to change the filter on a set schedule. Synthetic oil still gets dirty and filters still get clogged. Doing so loses some of the oil, requiring you to supplement with a small amount of 'fresh' oil at additional cost. Also, once your motor starts consuming oil (if that happens) you should switch back to standard oil. I rode in a truck burning Mobil1 oil recently - that could be an expensive proposition for the owner. Anyway, if you find yourself paying $40 or more for a gallon of XD-100 oil, you are likely in a bind. Bought right, you can get it for close to $30 a gallon, sometimes less. But what I logged on to ask, really, is the same as was asked previously - what was the take on the overall condition of the motors? Anybody use a boroscope to check out the condition of the cylinders? I think they run the Honda's to about 2,000 hours before cycling them (they being the USCG). It would be interesting to do a long term comparison of overall condition on these commercially used motors - of all makes. Dave |
| Tohsgib |
I don't think you need to change the filters on an outboard like you do a car. Again they are not ingesting dirt, etc. Also at 200 hours is kinda like 12000 miles in a car and they do not recommend filter swaps anymore and usually 12-15k change intervals. Also for the 3rd time I quoted $20/gal, not $40. Read my post again. Lastly...yes Dave I think it would be a great article but not gonna be easy. What paramaters would you use, compression, compared to new, DYNO? |
| Peter |
Where does the operating manual for a 4-stroke outboard say that if you use 100 percent synthetic crankcase oil, the length of the oil change interval is double? |
| contender |
I once worked in an engine shop in Miami,(H.C. Wilcox) The old man that owned the shop was consider the god of the internal combustion engine, he knew more things and could do more things with an engine than anyone I have ever seen or heard of. In his younger years he worked with Mr. Ford, the Chrysler Brothers and others fixing problems they had with their engines. One of things he told me is to do is just change the filter more often and not the oil, say run 10,000(or double the mileage /hours on the outboard) miles on your car change the filter at 5000 and then the oil and filter at 10,000. It really takes a lot of heat for a long time to break down the oil, but the oil does get dirty, so just change the filter and add some oil.... |
Peter--Some owners of four-cycle outboard motors are negligent about changing the oil. When they find out the valve train is ruined and will cost about as much as a new motor to repair, they become more strict in their oil change discipline. |
| whale |
At least E-TEC will not have making oil problem like on four-cycle Mercury motors. |
| Buckda |
I have a perfect test platform for 150 hp motors. If Mercury and Evinrude would each donate a motor, I would mount them and do a long-term comparison of fuel economy, service costs, parts availability and cost, etc. I think it would be a fun project. :) How about it? An OptiMax 150 side-by side with an E-TEC 150? Any dealerships want to partner up for such a comparison? I'd advertise your dealership logo on the same side as your motor; use motor instrumentation to measure fuel flow and use, etc. I'd even compare a Yamaha F150 to a Honda BF150 or Suzuki, if that's who wants to do the comparison. My e-mail is in my profile. |
| Peter |
The Buckda "head-to-head" test offer. I like it. When you test the 4-stroke 150s vs. the E-TEC 150 or Optimax 150, you'll have to use some counterweights on the 2-stroke side of the boat however to balance it out. Also, you'll have to figure out how to handicap the fact that the 2-stroke side has to haul around extra weight that 2-stroke motor wouldn't otherwise have to haul around. |
| Bobber |
Bob Lemay, a full time guide in the Everglades Nat'l Park, is reporting that his 2nd Etec 90 has 1800 hours, running strong. He sold his first at 1200 hours and its still running strong. He will be purchasing his third in the near future. A man whose income depends on his boat and who daily runs into a wilderness 30 miles from the nearest help and cell phone service makes a good spokesman for the Etec's durability. |
| hauptjm |
Since this thread drifted in and out of the topic, do we know what the motors were serviced for and what Lockerman thought about the overall condition of said motors????? |
I believe the only service was the recommended change of spark plugs, gear case lubricant, and filters at 300-hour or longer than 300-hour intervals. I'll double check on that. ASIDE: In one and half seasons with my own E-TEC I have run up 130-hours. At this rate it will take me over 19 years before my engines hit 1,700-hours. |
I checked with LOCKEMAN'S on the service they provided for these motors. The only service was to replace the water pump impeller, spark plugs, and fuel filters at periodic intervals. This season the motors each ran about 550 hours on one set of spark plugs, one water pump impeller, and one fuel filter, that is, no service since Spring until Fall of 2010. When the Corps was previously using traditional two-cycle outboard motors they followed the normal service recommendations to the letter, and they'd bring the boat in for routine service several times each season. The E-TEC engines just ran beautifully all year long, no service was needed. Here is a pair of E-TEC engines that each racked up 1,700-hours of service in three to four seasons. That is 3,400-hours of trouble-free operation. These engines are a good endorsement of E-TEC reliability and endurance. |
| captbone |
The treatment of those engines is not a testament to the engine but instead simply neglect. How is the Evinrude gearlube so different that does not need to be changed as often as others? It has the same grease points as others. The real troopers are the Honda v6's mounted on the back of the USCG 25ft RBS. There are thousands of these v6 225hp with above 2500hours of absolute abuse from 22 year olds that only know two speeds. |
I have to completely disagree with the proposition that all gears require the same amount of lubricant to operate. Evinrude has determined that the gear case of their E-TEC engines can run 300-hours before recommending a change in the lubricant. In 1944 the Oak Ridge gas diffusion plant began operation. The pumps that pressurize the uranium hexaflouride gas cannot be lubricated with oils due to risk of explosion. Those pumps have been operating since 1944 without oil lubricants, or 66-years. It is entirely possible for man to construct mechanical devices which can operate for long periods without having grease or other lubricants. I do not find it incredible that an E-TEC gear case could run 300-hours without a change in lubrication. It is being done all the time. The endurance of these particular E-TEC engines is substantiated by the engine history report obtained from the engine management module. While I have heard anecdotal reports of other brands of engine accumulating high service hours, I have never seen any evidence of this other than some young Coast Guardsman attesting to "thousands of hours." If you would like to discuss the longevity of another brand of engine, please start a new thread and present your evidence. |
| captbone |
If the oil change period for the Evinrude gearlube is 300hours then it just proves that the these engines are neglected. I knew a girl in high school that was given a brand new VW Golf for her 17th birthday. She used to tell her parents she needed an oil change for the car every couple of weeks and then would take the money for cloth shopping. She used to brag that her car has 30k miles on it and never had an oil change. Just because it can run that long doesn't mean it should. |
| Tohsgib |
I do not find 300 hours of use on synthetic foot oil to be neglect on an outboard. I change mine every 100 and it still looks pretty new. |
| captbone |
300 hours is not neglect but if that is the recommended service period then the 550 hours is almost double that period. And if any synthetic gearlube can do that period then what does the Etec do that an Optimax or any other DFI 2 stroke cant do? This thread does not prove that the Etec lasts any longer or costs less to maintain then any other DFI 2 stroke (HPDI, Optimax, TLDI). My arguement is that the time that USACE has put on these engines proofs nothing and is not the definitive evidence that Etecs are any better then anything else. The maintaince period for Etecs is foolish. They require the same maintaince as any other outboard. The propshaft splines need to be greased, water pump does not last any longer, the bolts dont corrode any less.......... This thread if anything just proves the operating cost of a four stroke is significantly less compared to a DFI when you compare th cost of 2 strok oil burned vs oil changes if you do the work yourself. |
| Nauti Tauk |
[Silly comment deleted.--jimh] |
| adlert |
I generally agree with your point jimh regarding the ability to engineer devices capabable of long operational periods between lubricant changes. For archival accuracy sake however note that the original Oak Ridge gaseous diffusion plant was shut down in 1964. Additional gaseous diffusion facilities were built on the same site but these were all shut down by 1987. The lubricants used in the K-25 pumps were novel polymers specially developed to provide necessary lubrication yet be unreactive with UF6 (explosion potential) that they would be prone to come in contact with. Being novel and unreactive with UF6 is a different thing than leaving oil in the pumps over the life of the project. Additionally, seals used in the myriad of valves were specially developed due to the explosion hazard associated with standard greased fittings. The material invented for the seals is now known as Teflon. |
| adlert |
Whoops. Off topic but re-reading I could have been more to the point - it is incorrect to say that the pumps used at the Oak Ridge Gaseous Diffusion Plant operated without "...other lubricants." Those pumps were operated with specially developed lubricants. |
| Tohsgib |
Back in the days I used my 13' Whaler about 400 hours a season and it might have been more. I went by an hour per gallon which is what the boat ran at cruise basically. We changed the gear lube every season and this was before synthetics. I also spent most of my days skiing or dredging Barnegat Bay. The lower unit started to skip after 3 seaons or say 1000 hours and had to be rebuilt. This I do not believe was due to my maintenance schedule but more likely due to the EXTREME conditions I put that lower unit thorugh. I would go through 4-5 props per season as well so many hours were spent with a pretty mangled screw. Due to my limited funds which were spent on fuel, there were 4-5 people asking themselves what they hit last weekend when they went to use their boat and had to buy a new prop ;) |
| captbone |
Bigshot I do agree with you and your story highlights my point entirely and even ties into my VW story. The fact that an engine went 550hours without service is not remarkable for a 2 stroke engine. Just about every outboard can make it to that point today. Is it good for the engine? Absolutely not Will it affect the engines lifespan? Yes, but most people will never use that engine long enough to see the death caused by neglect such as that. Outboard engines are rarely worn out, they usually suffer an expensive failure and the cost benefit equation makes it better to repower. An Optimax or HPDI could do the same thing that the Etec did. Comparing a 150hp outboard lower unit to Oak Ridge gas diffusion plant machinery is comparing apples to elephants. |
| Justfishin |
jimh did not say that the E-TEC would outlast any other outboard. It is a good post. No one mentions the fact that most owners of four strokes do not bother with the mandatory checking of the valves at certain intervals. Most manuals say at 20 hours then every 100 or 200 or 500 hours thereafter. This operation cost did not show up in the comparisons. I am not knocking four strokes. I don't have one at the moment, but I would consider one if it fit the purpose or the right deal was made at the time of purchase. |
| captbone |
As a matter of fact it is implied.
Since Evinrude has less than 8% of the OB motor market, there are most certainly more high hour Verados/Optimax's/Yamahas vs Evinrudes. |
| L H G |
About a year ago, I believe "Blue Water Pirate" here indicated his single 225 Optimax had over 3200 hours on it with no problems. It probably has more by now. |
quote: I am afraid that a purpose has been inferred for this discussion which was never intended. My initial presentation of information makes absolutely no assertion that the data proves anything. I am quite surprised that readers made an inference that the E-TEC engine could last longer than any other DFI engine. The material I presented did not assert that claim in any way. I cannot say that the readers who concluded the E-TEC will last longer than an OptiMax, an HPDI, or a TLDI engine are wrong. ASIDE to adlert: Thank you for the additional information about the gaseous diffusion plant at Oak Ridge. It was very interesting. Whether or not the devices used an oil based lubricant, I think their design and operational history shows that it is possible for man to design and fabricate mechanical devices which can operate for more than 100-hours before requiring a complete change in lubrication. This was the point of bringing these devices into the discussion. There was a notion introduced into the discussion which seemed to imply that a limit of 100-hours was somehow binding on all mechanical devices for the duration of their operational period without service or change of their lubricants. I made mention of Oak Ridge as an example where 100-hours was not a limiting factor on the duration of operation of a mechanical device. Even limiting the Oak Ridge example to 22-years, I think it still provides a good counter point to the 100-hour limit suggested. For those who insist on turning this discussion into a financial analysis of the cost of operating a two-cycle engine compared to a four-cycle engine, please stop. Your topic is a fine topic, but it has been discussed at length in previous discussions. If you want to re-open that topic you should start a separate discussion. The topic of this discussion is the longevity of the E-TEC, and by extension, we have a few second-hand or third hand reports from other brands of excellent longevity. We can hash out the financials in another thread. |
| Peter |
What would be interesting to know is what the engines' running profiles have been over the 1700 hours. |
| Tohsgib |
When E-Tecs started hitting the market I told everyone who asked what I thought. My thoughts were(probably on this forum somewhere)that if EVERYTHING they claim comes to fruition, this engine will revolutionize not only the outboard industry but all internal combustion engines in general. Piston coatings that can run without oil for 5 hours...holy smokes! Better emmissions than a 4 stroke....holy cow! Better fuel economy and state of the art electronics...Jesus & Mary! No maintenance for 3 WHOLE YEARS.....LORD ALMIGHTY!!! Sorry but somewhere they dropped the ball. Maybe if they make an E-Tec based diesel for cars we might have something but I don't see the reliability or benefit over a common engine nor does anyone else I guess. |
| Tom W Clark |
Nick -- Where did they drop the ball? |
In regard to the longevity of the gear case on an E-TEC and the recommended change of lubricant at 300-hours: The use of a measurement of hours for the gear case is probably not the most precise measurement of wear and tear. A better measurement would be propeller shaft revolutions. On large ships on which I have visited, I have seen a propeller shaft revolution counter. The speed at which an engine is operated will influence the number of propeller shaft revolutions which occur in a particular time period. Let us examine some variations. If an engine operates at an average speed of 1,500-RPM for 300 hours, we would expect the input shaft to the gear case to make 1,500-Revolutions/1-minute x 60-minutes/1-hour x 300-hours = 27,000,000 revolutions If the engine were operated at 4,500-RPM for 300-hours, we would expect the input shaft to make three times as many revolutions, or about 81-million revolutions. When the manufacturer says to change the lubricant every 300-hours, it is very likely they are planning on the engine operating at an average speed of somewhere in between 1,500-RPM and 4,500-RPM. We might say the average speed could be around 2,500-RPM for 300-hours, or 45-million revolutions. If one were to operate the engine at an average speed of only 1,250-RPM, it could take 600-hours to reach 45-million revolutions. If the change of lubricant interval were increased to 600-hours would it be considered negligence to go beyond 300-hours without changing the lubricant? The notion that 300-hours is an absolute time limit is difficult to rationalize. In my opinion the basis for changing the lubricant would be influenced by the operating speed of the engine. An engine which was mainly operated at low speeds perhaps could go beyond 300-hours, while an engine which was mainly operated at very high speed may need to have its gear case lubricant changed before 300-hours. |
Peter--The work boat which is powered by the E-TEC 150-HP V6 engines which are the basis of this discussion is used by the Army Corps of Engineers to make hydrologic surveys of navigation channels in the Detroit River and other areas. Most of the time when the boat is engaged in collecting hydrologic survey data it is operated at low speeds. Accordingly, the engine history report of these V6 E-TEC engines shows the greatest portion of the operating time is spent between 1,500 and 2,000-RPM. This is not especially unusual. On my own boat, the engine history report for my E-TEC shows a great amount of operating time for the engine at speeds below 2,000-RPM--actually far more than one might think based on the normal impression one makes when operating a planing hull boat. |
| captbone |
[Long cut and paste of the initial paragraph of this article has been deleted--jimh] Using [jimh's] gearcase logic [which correlates the need to change the lubrication in the gear case with the total number of revolutions of the propeller shaft] we then can conclude the same thing for engine oil changes, also. Since the rotating assembly of the powerhead is only turning at [unclear] compared to if the engine was run at [unclear]. So the normal oil change cycle would be increased--it doesn't matter because they don't follow recommended maintaince anyway. Using [that] logic the four-cycle engines would [save] a ton of money [compared to] the two-cycel DFIs. [Please note that it has explicitly been asked that imputing financial savings for the operation of a four-stroke-power-cycle engine in preference to a two-stroke-power-cycle engine should be moved to a different thread because the topic of this thread is NOT ABOUT the cost of operating an engine; the topic is about the engine longevity--Moderator] |
| Peter |
Most boats are in the on-plane transition zone at 2000 RPM. So my hunch is that the bulk of the operating RPM is probably at 1500 RPM. At 1500 RPM, the E-TEC 150 consumes approximately 1.5 GPH. At the TCW3 setting, the oiling rate is probably not more than 60:1. So for every hour of operation, each E-TEC is consuming approximately 0.025 GPH of XD50 lubricating oil. Over 1700 hours of operation, Each of these E-TECS probably used 42 gallons of lubricating oil requiring a fill (adding 2 gallons to a 3 gallon reservoir) once every 80 hours of operation. Assuming these motors are operated 8 hours a day, 5 days a week during the active season, the weekly maintenance for each of these motors is putting a gallon of oil in the reservoir. If these were 4-stroke motors with a lot of low speed operation, they would have to be hauled every other week for an oil and possibly a filter change. |
| Tohsgib |
Tom...do you see BRP putting E-Tecs in their motorcycles? Sure they make a snowmobile E-Tec but snowmobiles and outboards are close relatives since inception(remember Evinrude sleds?). If they would have used an E-Tec (since it is such low emissions) in that funky 3 wheeled bike, maybe some car makers would do the same. Maybe Tesla would be figuring out how to put a 250 E-Tec into their car and get 75mpg than fussing with batteries they can't seem to get manufactured. It is up to BRP to expand their horizons in order to revolutionize the rest of the industries. Have they done so? No they dropped the ball...so far. |
| Tohsgib |
My Honda Hybrid gets roughly 45-50mpg from a 114hp engine and battery combo. Don't you think with the weight savings that a 90 or 115 E-Tec engine in that car could not do the same? If so no batteries to dispose of or buy again. Let's not get started that most of the ingredients needed to produce these newer batteries is found in hostile regions of Africa where God knows how many people suffer just so we can make their Governments rich from the sales of this stuff. |
| WT |
I find it strange that BRP abandoned 2 stroke motors in their SeaDoo line of boats and personal watercraft. I have a 2 stroke SeaDoo but now they only make 4 stroke models and some are supercharged (like Mercury Verados). Warren |
| captbone |
2 Stroke DFI engines do not/can not meet the 4 star CARB emissions standard. The difference between 3 star and 4 star is signicant and requires the use of a catolic converter. The current platform can not meet this requirement and will not unless they change over to a wet sump oil system similar to a four stroke. OB engines are required to meet CARB 4 star rating by 2016. I/Os and Inboard were required as of Jan 1, 2010. The death of the 2 stroke (even DFI) is on the horizon. (I am a 2 stroke fan by the way). |
| Tohsgib |
I do not follow jet boats...interesting point though Warren. |
| Peter |
Getting outside of the E-TEC longevity theme here but Captbone would you be so kind as to point us to the regulations that "OB engines are required to meet CARB 4 star rating by 2016." Have not seen that before and given that all outboard motors DFI and 4-strokes will be regulated out of existence by 2016 because neither will be able to meet this standard, I'm surprised we have not heard more about this. |
| captbone |
http://www.arb.ca.gov/cc/ccms/ccms.htm The EPA almost without exception follows CARB. Outboard motors of the future will have cats on them. Off the top of my head, the 4 star emission requirement means cutting emission another 30% over the existing requirement 3 star requirement. Its is coming. |
| L H G |
Evidently Orbital is already working on this, and feels that they can meet the 4-Star requirement with the Optimax and TLDI air assisted DFI 2-stroke outboards. No catalytic converter will be required, but for 4-stroke engines, they think it may be needed. Salt water is the problem with current catalytics. Somewhere I read that the Verado was designed to be able to handle catalytic converters if needed or mandated. |
| Peter |
Captbone -- Thank you for the citation. Did you happen to notice the title of the page -- "Clean 'Car Standards - Pavley, Assembly Bill 1493"? FYI, the emissions of outboard motors are not regulated to the same standards as cars. For your further reading enjoyment regarding the CARB emissions regulations of outboard motors, I refer you to www.arb.ca.gov/msprog/offroad/recmarine/recmarine.htm . Based on what I've read there, I believe that there is a very good chance that one will be able to buy a 150 HP E-TEC motor in California in 2016 and put it on the path towards 1700 hours of usage in 3 years. |
| captbone |
I do not have the direct link. 2011 requires all new boat have [low-permeation] fuel lines and carbon canisters to collect vapor. This is another fact that is little known. It is almost like they are trying to [destroy] boating. Don't get me started on the pending E-15. I am done with my rant. |
I disagree with the theory of Mister Bone regarding the interval between lubrication oil change in four-cycle motors being proportional to the total number of crankshaft revolutions--he did not say it that way but I believe that is what he intended. The owner's manual of four-cycle engines often defines certain conditions which, if they occur, will cause an increase in the frequency of the oil change. One of the conditions is periods of extended idle speed operation. There are many reports that four-cycle outboard motors which have been operated at idle speeds for a long time are prone to contamination of their oil from exhaust product blow-by. This condition, known as "making oil," usually prompts for faster oil changes. In any case, the theory does not affect the longevity of the E-TEC because there is no lubrication oil sump and no dirty oil. The E-TEC uses fresh oil for lubrication. This crucial difference may help explain the longevity of the E-TEC engines reported here. |
| Tohsgib |
Jim...that is a farce. None of my 4 strokes have EVER "made oil". Engines that make oil were probably not broken in correctly or have some other "issue". |
| seahorse |
quote:
The outboard manufacturers have already notified thier dealers in service bulletins and other literature. |
Nick asserts that reports of four-cycle engines contaminating their oil from exhaust blow-by are a farce. I disagree. The reports seem to come from concerned owners of four-cycle engines. I do not believe they intended them to be farcical. That Nick has not experienced this problem does not foreclose others from having experienced it. Thus I believe that oil contamination is a proper concern for owners of four-cycle engines. |
| Owtrayj25 |
This discussion has certainly drifted off topic, but if we are discussing the infrequent problem of 4-stroke engines "making oil" and try and correlate it to longevity, I would suggest a 2-stroke blown powerhead is of much greater frequency and far greater concern than a 4-stroke engine "making oil". |
Let's not forget the topic was initially quite simple: a report on the hours of reliable operation of two engines over three or four seasons. I find the reaction to this to be quite complex. It appears that simply mentioning this fact has stirred up a hornet's nest of controversy. This thread has inspired new discussions on: --cost of operation There have been several prior threads in which it has been mentioned that a HONDA engine ran up a lot of hours, and I don't recall those announcements provoking such a curious reaction. What is there about an E-TEC that brings out such curious attacks? |
| ratherwhalering |
2004 E-TEC 90. # 7 off the production line. Warranty expires in 2011. -$167.00. XD 100 Oil. This is an approximation. |
| Tohsgib |
The last report I saw about "making oil" was a faulty fuel pump or stuck injector in the Mercury 4 strokes. The other making oil stories are from long idle periods in colder conditions. This probably occurs because people did not read their owner's manual. Mine clearly states that in colder weather you need to go to a thinner oil. This probably allows the oil to thin faster and allow better lubricity and proper functioning of the rings. I would much rather change my oil more often if I DID have that problem than replace a powerhead from a clogged injector. I have NEVER heard of an engine "making oil" in my neck of the woods. However I do know of about 1/2 dozen blown E-Tec powerheads, some not covered under warranty. |
| captbone |
I was born and raised an OMC man from the day I was born. I have owner at least 8 Evinrudes and 1 Johnson. The problem that I have with modern Evinrudes is the marketing gimmicks that people use to explain why Evinrude is the best on the market. The XD100 oil is expensive and not nearly as common as TCW3. The cost is pretty much equal to standard TCW3 when you figure out the total cost. I would also rather have my engine over oiled vs running lean on high tech oil. I dont see any benefit in the XD100 oil. The three year maintaince period is just foolish IMO. Can the engine go 3 years without maintaince? Sure it can but any other 2 stroke engine can do the same thing. A four stroke can even do the same thing if you want to neglect it. I want to lube my driveshaft/propshaft/check for fishing line every year. Prevention goes a long way and this 3 year maintaince gimmick gives the owners a false sense of what is needed. I do like the self winterization feature but then again it just neglects normal maintaince.
| seahorse |
quote:
You are asked to pull the prop and lube it annually in salt or brackish water conditions. Also in salt water environments, lubing the grease fittings is suggested. It's in the manual. The 3 year/300 hour service is for dealer required servicing in normal recreational use in fresh water. For commercial use, salt water use, and high performance use they recommend more frequent intervals. It's the same as with automotive owners manuals. Some say to change oil at 7500 miles or more often if you do a lot of high speed driving, or a lot of low speed driving, or if you drive on dusty roads, or if you pull a trailer. Luckily here in the USA we don't have armed maintenance police on every dock or boat ramp so we have a choice of when to service our motors. |
| macfam |
My experieince with XD-100 is that it is smokeless. None, nadda, zip! Even after starting after winterization, there is very little smoke. Yesterday morning was 40 degrees. My E-TEC hadn't been started in 3 weeks. Just a slight turn of the key, and it started instantly. I'm confident that the lubrication was adequate because of the XD-100 viscosity. In fact, BRP recommends ONLY XD-100 for low temperature operation. It pours easily even below 32 degrees. I'm willing to bet that virtually any new DFI 2-stroke outboard can go 3 years with little or no maintenance. |
| captbone |
I can see your point but respectfully disagree and I stick by my commment "Prevention goes a long way and this 3 year maintaince gimmick gives the owners a false sense of what is needed."
I am not trying to be agruementative but I dont see how this engines maintaince period is anything less then any other DFI engine. The gearcase/lube are not radically different, the filters, fuel pumps, water pumps all require the same service as any other DFI. |
Mister Bone asserts that all engines require service of their water pump at the same intervals. I disagree. I know of a c.1992 Yamaha 150-HP that was run for over ten years (and probably 1,000-hours) without service to the water pump. The water pump worked fine and provided good cooling. Other engines specify the water pump be replaced every year, and those engines need that level of service. I do not find it unreasonable that an E-TEC engine can run for 300-hours without service to its water pump. |
| captbone |
I never it said it couldnt do it. Its called maintaince. Please refer back to my VW story with 30k miles between oil changes. We do maintaince so we dont have issues. If a manufacturer wants to push the limits of normal maintaince its fine but expect me to believe that any other engine couldnt do the same thing. Does the Etec use a waterpump made of any special material that makes it better then a waterpump in any other engine? Your example calling for yearly replacement is those of high pressure low volume waterpumps. Modern waterpumps are floppy vane high volume low pressure impellers that last much longer. Respectfully Captbone |
| sblack |
I have owned a 27 Whaler W/A that had twin 2005 E Tec 250's and their fuel economy was TERRIBLE! The boat averaged a little less than 1 MPG and they sucked down the top of the line HD-100 Evinrude two stoke oil that was $40/gallon grossly adding to the running expense of the engines. The E Tec's also have a bad habit of getting eel grass and debris in their water take in units. I fish in the West coast kelp forests and I always had the E Tec's overheating due to clogged intakes. I sold that dog of a boat and kept my 25' Revenge with a single Yamaha 225 four stroke that is unbelievable! I repowered in 2003 and now have 1250 hours on the motor and average 1.75-2 mpg depending on the load and I never have a problem running through the kelp to clear water. I would never recommend an E Tec over a Yamaha four stroke. Outboard ignorance is not something to advertise in my opinion when you run 100 miles offshore... I would think being forced to pay attention to your engine will help prevent any potential problems. |
Thanks to sblack for the report that his Yamaha four-cycle motor has been run for 1,250-hours over seven years, dating from 2003. He must have one of the first Yamaha 225-HP four-cycle engines made. sblack says the following:
quote: I am afraid I have no idea what you are talking about. Please elaborate on "outboard ignorance." I am not familiar with that term.
quote: Explain what mechanism the eel grass uses so it knows only to foul the water intakes of E-TEC engines? I would like to know how that happens.
quote: The fuel economy of a 27-foot boat with 500-HP of gasoline-driven engines is probably typically around 1-MPG. Fuel consumption depends greatly on the horsepower being used and the efficiency of the hull being driven. The fuel economy of a motor is best described by its brake specific fuel consumption. We have seen that in outboard motors the brake specific fuel consumption for direct-injection two-cycle motors tends to be slightly higher than the best possible figures of naturally aspirated four-cycle engines. This is a well-known fact. The naturally aspirated four-cycle motors, however, are generally lacking in low-end torque, reserve power, and strong acceleration. In contrast the direct-injection two-cycle motors excel in those areas. The marginally better fuel economy of the four-cycle comes at a cost of reduced performance and increased maintenance. In any case, the focus here is not on comparisons of the E-TEC to four-cycle engines, but simply a report on excellent longevity of the E-TEC. If you wish to begin a discussion in which the brake specific fuel economy of two-cycle direct-injection motors is compared to four-cycle naturally aspirated motors, that would be a wonderful topic for a new thread. We have already touched on this many times, but I think a fresh look would be interesting. |
| sblack |
Jim, I think you are correct in starting some kind of new thread regarding this topic and I personally embrace the competitiveness of everyone's personal experience regarding how their motors perform on the best hull ever made, which are the classic Whaler's before Reebok took things over.
Regarding the high flow water inlates, both the standard and the high performance water intake grates that I was given by Grant Tipton from Bombardier both performed poorly as they would easily draw up Eel Grass and other floating debris leading to engine overheating alarms when we fished through any kelp beds. They are not flush mounted units which is my guess is why this problem would stand out. I also had to unscrew the rear motor cooling stream unit to clear any passed strands of Eel Grass. Whalers are built to fish and I fish mine hard, including Kelp Forests plus long distance trips and the flush Yamaha water intake never give me any trouble of fouling, and it's my experience that E-Tec's do not like this kind of environment. I had worked with Grant Tipton and Michael McBrady from BRP on why one of my twin 250 E Tec's was burning 12.5% more fuel than the other and with the help of our local BRP dealer, we could not find a solution regardless of a new binnacle, gauges, wiring etc., the bottom line was that the twin 250 E-Tec's were burning extra fuel that mounts to a big fuel bill on the long trips where I would normally take my 25 BW Revenge. The last trip I took on the 25 Revenge was to San Nicolas Island from San Diego when we ran 330 miles round trip and burned 170 gallons of fuel on the 225 Yamaha four stroke @ 1.94 MPG. I would not have been able to even consider that trip with the E-Tec's on the 27' BW W/A. And if you would like some clarification on a 27' Whaler W/A's fuel economy, perhaps you can ask Cap't Billy of the Toy Too who just repowered his Whaler with a set of twin Yamaha 300HP HPDI's who used to get 1-1.25MPG (with the old Yamaha 250's) and is now quoted as getting 40% better fuel economy with his Yamaha's that would put him in the 1.4-1.75 MPG range, better than the 1 MPG you mentioned with a standard 27' Whaler. My 25 Revenge is the "Smallest boat that makes the longest trips" in my Marina and I will always take that Whaler to San Nicolas Island, San Quintin and everywhere in between for the simple reason that she can make it there safely. Whalers are made to push the limits, not just to sail to their safe boundries. Trailer your Whaler out here and let's make a true run for some true fishing. Not a get together on a Lake Poway. Let's plan a run to San Quintin, Geronimo Island or better yet, Cedros Island. I think I may be able to get Cap't Frank Lo'Preste to help set us up with fuel for the ride home. I'm all in. Oooh I love this competitition... All in good spirit Jim...your a Whaler man even if you think I'm a total Putz. Find more recipes @ www.sportfishingmag.com. Respectfully, |
| Peter |
Steve -- You need to tell the whole story rather than just bash E-TECs based on your short experience -- where the boat came from and what kind of condition it was in when you got it. Given this is a thread about longevity not performance and that "[o]utboard ignorance is not something to advertise in my opinion when you run 100 miles offshore..." if you have not already done so, you should consider having your 2003 Yamaha F225 checked for exhaust system corrosion. From the accounts that I've read, it can lead to overheating, which is not good if you are 100 miles offshore. |
It is not meaningful to compare fuel economy of different boats, let alone boats of completely different size. Fuel economy results are a combination of the boat, the motor, the propeller, the loading, and the conditions. Attempts to isolate the influence of the motor are difficult. When I gave information about changes in fuel economy that resulted from changing my engine to an E-TEC, the only thing that changed was the engine. The boat, propeller, loading, and to the greatest extent the conditions were the same. This permits a reasonable comparison. I could tell you that I get better fuel economy with my E-TEC than Steve gets with a Yamaha four-cycle, but since that comparison involves a completely different boat it has no meaning. Even among boats that are believed to be identical, variations in the hull condition and the hull weight can produce variation in performance. Operating a motor in water with heavy weed or grass growth may be the defining criterion for Steve, but it has little influence for me. I do not find the design or performance of the cooling water intakes on my E-TEC to cause problems. Due to the water temperature in most of the Great Lakes in which I operate my boat, we do not have much weed growth at the surface. |
| sblack |
Ok, I've had my fill here. You love your E Tec, I love my Yamaha, but we all love Classic Boston Whalers and I cannot dispute with my fellow brothers. Oct. 1-4th I took the 25 Revenge out to San Nicolas Island, 135 miles west of San Diego. We made it there safely, caught Halibut, Calicos & Yellowtail. We had great meals and watched a few DVD's and slept in total dry comfort in the small cabin. Those memories are what keep me working until the next trip. The round trips was 330 miles, burning 170 gallons of gas. Long live your E Tec, stay safe and take good care of that Whaler. Remain Well, |
| L H G |
Now, if Steve was complaining about Mercury engines here, either Verado or Optimax, instead of Evinrudes, we'd be having a no holds barred, free-for-all. |
The topic here is not my E-TEC, but the pair of E-TEC engines owned by the U.S. Army Corps of Engineers. They each ran over 1,700 hours of trouble free operation. Just mentioning this seems to have sparked a lot of controversy. I hope I can put 1,700-hours on my current engine. At the rate I am using it, about 75-hours per year, that means 23 years more to go. I'll be 83-years-old. Check back with me then. |
Also, Larry will be 90.... I should acknowledge Larry's contribution here, too. Thank you for letting us know that Orbital has already solved any Four-Star related emission qualification problem. And ditto for Mercury having the foresight to include provision for a catalytic converter in the VERADO. I would attribute the ability of the OptiMax and VERADO to continue to meet future emission requirements that herein are reported to be the death of the E-TEC as being a result of the massively larger funding that Mercury had allotted for research and development, while Bombardier hangs on by their fingernails and depends of public assistance from Quebec. Did I get that right? |
| L H G |
Almost, but not quite. I said Orbital was already working on, not that they solved, 4-star technology for DFI outboards (Optimax and TLDI). It does appear they can do it, however, if and when the requirement is mandated. |
| Tohsgib |
Being that Canada is the #1 exporter of pot to the US, don't hold your breath on public assistance from them....they are STONED! |
| Tom W Clark |
[ Nick -- Actually, Mexico is...by far. ] 1700 hours of trouble free operation of an outboard motor is remarkable for motors which are 24 years old. It is entirely unremarkable for motors that are only three years old. Outboard motors rarely wear out; some component usually fails leading to a catastrophic failure of the motor, or the accumulated burden of fixing numerous little problems with old outboard motors causes the owner to replace them. Outboard motors in daily use can easily go thousands of hours without trouble. Outboard motors in daily use by government agencies often accumulate a lot of hours because they spend the vast majority of their time at idle speeds, a very low stress mode of operation. |
| Tohsgib |
Just going by what Playboy said...Canada #1. |
| adlert |
I certainly agree with Tom in that thousands of hours on well cared for outboards is not remarkable. I do however have a different perspective. I'm please to see the E-TECS reaching 1,700 hours. It's a good sign of good things to come from these direct injection engines. I don't see it as "remarkable" within the broader context of outboard engine use, but given the conditions they work under I do find it impressive. Opposite to Tom's view I find it quite unremarkable that my 24 year old cross flow V4's have gone, or will go many thousands of hours. All of the spinning and sliding parts are bathed in a freshly atomized (read "cool") bath of large quantities of fuel laden with gobs of oil. All of the parts in the crankshaft side of my engines are literally dripping under a constant and fresh stream of cool lubricating fluids 100 % of the time they are spinning. Touch the intake side of the crankcase of an old 2-stroke and it is usually cool, or at very worst tepid to the touch even after a long high speed run. It's a beautiful, sloppy thing. This cool, high-flowing lubricant shower then runs up the engine's side and soaks the tops of the pistons and the entire cylinder walls. Just for good measure, my engines drain some over and out those ever-so-hot exhaust portions of the pistons and cylinder ports keeping them oh so happy. Comparatively, all of the direct injection engines live life on the edge in almost every aspect of outboard engine power generation. And they do it with class (far less polution, far better efficiency). I am very pleased and impressed when I hear good documentation of any of the direct injection engines living lives approaching the longevity of those set by their cool crude ancestors. |
| Owtrayj25 |
quote: I too thought the claim of 1,700 over 3 years as considered having good longevity to be curious. I think outboard engines often run better when they get regular use. And I would hardly consider 3 years of use, even at over 500 hours/year, as having exceptional longevity, or a 'long life'. Show me the engine in another 10 or 15 years and we'll talk. |
I am afraid that the E-TEC cannot meet the criterion of being 24-years old. I think the oldest of the E-TEC motors are now only about five to eight years old. We will have to wait two more decades for E-TEC motors to reach their mid-twenties. I disagree with the notion that 1,730-hours of trouble-free operation is not remarkable. The measuring stick being used for these E-TEC motors seems to be completely different than the one used on other motors. We have had legions of stories about motors that cannot run one season without repairs. Here are two motors that have run a combined 3,400-hours without any repairs and with very minimal scheduled maintenance. Let me lay this out in more specifics. These motors did NOT have any unscheduled service or replacement to their: --starter motors We have many reports of motors with less than one-tenth the hours of operation where components like those mentioned above have needed service. Feel free to pay no attention to these engines. Feel free to ignore their 3,400-hours of trouble-free operation. But please do not call in "unremarkable." |
| Perry |
The USCG Safe Boats here have Honda BF225's on them. My mechanic services them and most of them have over 2000 hours on them. Now the USCG does some serious training and really puts these motors through the ringer. Lots of the hours are at idle speeds but may are hard use in rough SALT water conditions. That is remarkable. What does the Army Corps of Engineering do with their boats in the fresh water there? Nothing near the kind of use the USCG sees. |
| jharrell |
1700 hrs does seem less remarkable next to the Honda's on the USCG Defender class that see 5000 hours of salt use: http://www.lighthouse-marine.com/safeboat.html I wonder if the repair data on these boats is public record so we could obtain it for some non anecdotal reliability statistics. They have been in service since 2002 with mostly Honda engines: http://en.wikipedia.org/wiki/USCG_Defender_class_boat |
| Perry |
Those defender class boats are the ones I referred to as SAFE boats built by SAFE Boats International (Secure All-around Flotation Equipped). They really get abused in rescue missions, law enforcement and training excercises. |
| Basshole |
1700 hours may not be that remarkable compared to other outboards, however it's very encouraging news for ETEC owners who love their motors. ETECs are a relatively new product and it's good to see that some of the older one's are still providing good service to their owners. I have been using mine for two seasons now and wouldn't want anything else on the transom of my boat. |
| Peter |
The measure of longevity for an outboard motor is the following: 2500 hours spread over 25 seasons, with the season of use consisting of most operating hours being accumulated in 2 of the 7 days of the week over 5 to 7 months of the year, the remaining 5 days the outboard motor hangs on the transom, tilted up, unused, unflushed in a saltwater environment, the other 5 to 7 months of the year the motor hangs on the transom, outside, out of the water, tilted down, exposed to several months of periodic freezing and thawing weather. NO commercially used outboard with ultra high hours EVER sees these conditions. NO motor that hangs on the transom of a trailer queen ever sees all of these conditions. The current King of Longevity is the "sloppy" OMC cross-flow V4. I don't believe that any of the modern motors will knock the King off the thrown. |
| Owtrayj25 |
Sometimes I think folks on this board think they are seen in a better light personally or take some personal satisfaction when they speak highly of their precious Evinrudes. Just an observation from a relative newbie |
People like to toss around fourth-hand anecdotal reports of high hours on a Honda outboard. I have never seen any evidence. Not a shred. Just the usual fourth-hand mention like jharrell makes to a third-hand mention of a photo caption. It would be more convincing to me to have someone actually have a first-hand report of a Honda with high hours. The information I am providing here about the E-TEC is absolutely reliable. It comes directly from the engine's themselves via their history report. No second, third or fourth hand recitation. I have the engine reports. The engines speak for themselves. Most boat owners tend to like their boats, their motors, and their accessories. If they don't like them, they get rid of them and get ones the do like. That's my observation. |
| Perry |
I have some first hand data for you Jim. I was in Homer Alaska this summer and talked to a USCG auxillary crew aboard a SAFE boat. The boat and BF225 motors were delivered to them in 2002 and each hour meter had over 2700 hours on it. The crewman I spoke to said they average over 300 hours a year. Here in Hawaii they log more than 300 hours a year but I have not had the opportunity to view the hour meters on a SAFE boat yet over here. But, like I said, my mechanic services the Honda motors on the SAFE boats and he has told me that all the older boats have well over 2000 hours logged on the BF225 motors. Do you doubt reports of high hours on a Honda outboards? Do you have to personally see evidence of this to believe it? Is it a coincidence that Honda Marine is a perennial winner of the JB Power award or that Honda outboards are widely viewed as very reliable motors? I know this is a thread about the longevity of a pair of 3 year old ETEC's run in fresh water. You insist that this is remarkable. I have nothing against Evinrude and I am sure ETECS are fine motors but I am just putting things in perspective here. |
Perry--Thank you for the first hand report of the observation of the hour meter on a boat with a Honda engine. However, unless the hour meter is also changed when an engine is changed, there is not a strong correlation between a particular hour meter and the actual engine hours of the engine on the transom. For example, the hour meter on my boat shows about 650-hours, but my engine actually has only about 130-hours. If someone observed that meter they would get an incorrect impression of the number of hours the engine had been run. My hour meter has been accumulating the time that the boat's ignition key was switched on, except for the 50-hours of time that it was not installed in the boat a few years ago. The E-TEC motors that are the topic of discussion here are 2007 model year motors and have only been operated for three or four seasons. The 2002 Honda motors mentioned have had eight years to accumulate running time. It would not be surprising that they have accumulated more running time inasmuch as they are more than twice as old. At no time have I made any assertion that these E-TEC motors with over 1,700-hours of flawless operation represent any sort of record for running time of an outboard motor. Readers who made that inference should not be confused. The fact that the E-TEC engines we are discussing have operated flawlessly for 1,700-hours does not necessarily foreclose engines made by other manufacturers from being able to also operate for a similar amount of time. However, as I mentioned in the initial presentation of this information, four-cycle engines will necessarily require a great deal of additional labor and maintenance due to the need to change the lubricating oil and replace components in their oil system like the oil filter. In general I have to observe that several readers have made several unintended inferences about these E-TEC motors with three or four seasons of flawless operation and over 3,400-hours combined operation. I am not sure why so many readers have replied with remarks which are intended to dismiss or minimize the significance of engines which are capable of running for over 1,700-hours with no maintenance or service other than the manufacturer's recommended 300-hour service items. Based on the blasé reaction of some, you'd have to conclude that all outboard motors run flawlessly for their first 1,700-hours of operation. Is that really the case? |
| Utik |
Jim is right. I can assure you that all outboard motors do not run flawlessly for the first 1,700 hours of operation. In fact my 2 cylinder 2007 BRP Evinrude E-TEC 40hp required the replacement of 3 fuel injectors in the first 150 hours of operation. I was happy with the excellent warranty service I got from BRP, but that does not change the fact that I remain concerned about this. There was no indication that there was ever any water in my fuel. I do use fuel with 10% ethanol, but I use the exact same fuel in 3 ATVs, 2 snowmobiles, 2 lawnmowers, 1 chainsaw, 1 string trimmer, 1 generator, 1 snow blower and 2 automobiles. None of these other devices has ever had a fuel related issue. Some of them sit for extended periods of time. I use fuel stabilizer 100% of the time in everything except the automobiles. On my 2 cylinder 2007 BRP Evinrude E-TEC 40hp, I use an external Racor 10 micron water separating filter in addition to the internal filter. The fact that 1 or 2 engines were capable of accumulating a large number of hours in a short period of time is not proof that all these engines can be expected to duplicate this. At the same time, I would not infer that my experience with my 2 cylinder 2007 BRP Evinrude E-TEC 40hp is proof that these engines are trouble prone. I don’t believe that either of these examples proves anything other than that these BRP Evinrude E-TEC engines are capable of long trouble free hours or lots of trouble in a short time. We all know that there are examples of engines of every brand that have demonstrated both of these characteristics. |
| captbone |
[That these E-TEC motors ran 1,700-hours without any service or repairs other than the minimal scheduled maintenance] [is] not that significant. Any modern DFI two-cycle outboard should be able to do the exact same thing with the same lack of maintaince. You [means jimh] also harp of the cost of the maintaince of four-cycle outboards compared to these engines. USACE did not follow the recommended maintaince period of the [manufacturer]. If they had four-cycle outboards what makes you think that they would have followed that [manufacturer's] recommended maintaince period? You can't compare the recommended service period of four-cycle outboards to the 550-hrs that the [E-TEC motors] were run, which is almost double the recommended service period. I am also confident that a four-cycle outboard could have completed the same amount of hours with the same service--period. It would be bad for the engine but USACE does seem to care. The engine would not just fall apart at 100-hours.
Fellas--Let's keep this stone turning so more of you can grind your axe. |
| Owtrayj25 |
Back in the mid 1990's, my work partner at the time had a 1986 18' outrage. The the original Johnson engine had catastrophic failure in 1989, so he had a new Yamaha 150 installed in 1990. We did not boat much together, maybe once or twice a year, but he (or his boat ownership partner) was on that rig from March through November and would put a couple hundred hours on per season. We were talking about the weekend one spring Friday, 1996 I believe, and I said I was headed down to de-winterize my Whaler. He looked at me funny and said "de-winterize, what do you mean?". I said you know, blow out all the fogging/winter store oil, put the props back on, etc. He then said I don't do any of that. I asked when was the last time he had any service to which he replied never and the engine ran like a top. So I'm thinking 5 seasons with no water pump, spark plug, lower unit oil changes...nothing. So I offered to service his engine, and did all of these things and more. The lower end lube was like black molasses in the winter, plugs moderately fouled, water pump impeller chewed up, but he maintained it was running like a top before they pulled it out of the water before Christmas the year before. So I figure 1,000-hours over a five year period with four month lay-ups when it was really cold out, with no service at all. Gas in the gas tank; oil in the oil tank...that's it. Now that's longevity. |
| Nauti Tauk |
No..... that's stupid. |
'bone continues to astound me by saying things like this:
quote: There is little statistical significance to any report about any single sample result when the population is large. There are thousands of E-TEC outboards, so a report about one or two is not statistically significant. However, what 'bone means to say here is that he has interpreted this outcome in the exact opposite way. He means to say that this sample is not "significant" because he wants us to believe that the entire population of outboard motors will produce this same result. In other words 'bone thinks this outcome is nothing unusual. This is a preposterous conclusion and is supported by no data. To conclude with any certainty that all outboard motors will never need any repair or service for the first 1,700-hours of operation because these two motors did is not supported by the data.
quote: 'bone restates more clearly his astounding proposition.
quote: I never mentioned the cost of maintenance. Actually I started a separate discussion on the cost of maintenance when others began to introduce that topic into this discussion. Please do not confuse me with the people who wanted to discuss the cost of maintenance. I never made any assertions here about the cost of maintenance.
quote: It is true that the Army Corps of Engineers in the 2010 season stretched the maintenance interval from 300-hours to 550-hours, a deviation of 1.8:1. However, we see comments regarding four-cycle engines where the oil change interval is suggested to be from 50 to 200 hours, a deviation of 4:1.
quote: I have not made any assertions about how the USACE would have scheduled maintenance of motors in the future that they might own.
quote: This leaves me completely confused. I don't know why a huge fuss has been made about the 550-hour service interval if we are now told it cannot be compared to anything else.
quote: This means 'bone now seems to say that four-cycle outboard oil changes can be stretched to 550-hours when the recommended interval (for the type of operation in use here) would be 50-hours. 'bone proposes a deviation from schedule of 11:1, but he has condemned the USACE for a deviation of 1.8:1. To me, a better comparison would be if a four-cycle engine called for service at 50-hours but was run to 80-hours. Would anyone make a fuss about that? No, actually people have proposed running to 200-hours, and seem quite content with that.
quote: I think the people at the U.S. Army Corps of Engineers are very professional. 'bone appears to have made a leap of logic of enormous distance. Because the E-TEC motors were run without a change of their spark plugs or gear case oil for 80-percent more than the recommended interval, he has condemned them all as careless.
quote: 'bone saved the best for last. After going on and on about the neglect of running the E-TEC for 550-hour before performing service, he now asserts that a catastrophe will not automatically occur if you run beyond a specified interval. |
I believe what has caused such an uproar in this discussion is my assertions that: --the E-TEC engines ran for 3,400-hours without needing any repair or service other than the specified 300-hour service, which is just a change of gear case oil, spark plug, and internal filters. --that 3,400-hours of operation of another type of motor which specifies service every 100-hours would have meant 34 service intervals had occurred. On the first point I am supported by the avowal of the dealer who provided service for these engines. He has stated there was no other service or repair necessary. I do not believe there is any possible contention about this, unless someone wants to call the dealer a liar. On the second point I am supported by arithmetic. If service is required every 100-hours, in a period of 3,400-hours you need to perform the service 34 times. If my calculation is wrong, I will be glad to admit my error. These are the two points I made in my initial article. After making these two observations, this thread has carried on for more than 70 comments in which an astonishing number of alternative theories of the universe have been presented. Frankly, I am amazed by what has happened. What gets under the skin of so many readers about my two simple observations? |
| Tohsgib |
Honestly Jim...it is NOT that amazing, matter of fact it is not remotely amazing at all. Somebody buy me ANY outboard new and supply the fuel and I will run the engine night & day for 1700 hours without ANY service for 71 days nonstop and I will guarantee she will be fine even with 1700 hour oil in the crankcase and gearbox. Neighbors will probably hate me if they already don't. As far the oil change interval you mention above try and think about this: Synthetic oil does NOT break down like conventional oil. 10W40 will still be 10W40 after 5,000 or 50,000 miles. The only reason you change the oil is because it gets dirty. Diesel trucks(not F-250's) run synthetic oil and can go well over 40,000 miles between changes as stated in my friend's Freighliner manual. With the right filter, you can go farther. The reason your car, even if it mandates synthetic oil, states to change every 12,500 or 15,000 miles is because that is what the average driver puts on their car per year. You will also see where it says 15,000 miles OR every year. If you were to run it 30,000 it would be fine. I know people who go 30-50k between changes but have it tested periodically and change the filter...to me that is just being a retard looking for bragging rights. Lastly Mobil 1 was designed for racing. A single race is equiv. to 100,000 miles of normal driving(look it up). They HAVE to do this on the same oil. Think about that for a while before you condemn my above statement or the fact you can go 200 hours on synthetic...or once a year. |
| captbone |
JimmyH So many places to start. This entire thread you compare apples to oranges. You wont compare the Evinrude against other DFI engines. You just skip over this fact time and time again. You have bought into Evinrudes marketing and cant see past it. Why couldnt any DFI outboard accomplish the same thing as these Evinrudes? You will only compare it against four strokes and when you do that you compare the 550 hours against the recommended maintaince period of the four strokes instead of the recommended period for Evinrude. I have never stated that catastrophic failure will occur by neglecting your maintaince period. In fact I provided a story illistrating the exact opposite. My point stated before and now again is just because it can run that long doesn't mean it should. In your first post you start off with.
You started the maintaince vs four stroke issue your first post and the implied cost. You are shocked that an outboard motor went 1700 hours, this just shows your lack of insight into commercial OB engine use. When someone compares a Evinrude against Honda which have hundreds of documented OB engines with over 2000 hrs on U.S. Coast Guard boats you dismiss the report. You bury your head in the sand and refuse to believe it. The duty cycle of these boats alone is enough proof. They would be swapping these engine annually if they could not do it. The reason everyone gets up in arms is because your posts are biased and you twist numbers and create ratio/figures to ensure you always come out right. You wont entertain others ideas, thoughts and insight nor will you allow someone to inject logic when it goes against you idea. I have been nothing but respectful this entire discussion. |
Nick--I have not condemned your statement about oil change intervals. I simply pointed out that in this discussion there have been proposals that the oil change interval for a four-cycle outboard could be increased to 200-hours from a recommended interval of 50-hours, and further I have observed that this was a variation of 4:1. My point in making this observation was to contrast it with the denouncement of operating an E-TEC engine for 550-hours when the recommended interval was 300-hours, a variation of 1.8:1. The variation of the E-TEC service by 1.8:1 prompted some observers to claim neglect. We now review your suggestion in this same light. Nick suggests that oil change intervals could be stretched to 1,700-hours, a variation from the recommended 50-hour interval of 34:1. To accept Nick's assertion that a variation in the service interval of 34:1 would not be harmful, it seems reasonable to conclude that a variation of the service interval of 1.8:1 would similarly not be harmful. As I mentioned previously, it is possible for the owner of an outboard to modify the service interval as he sees fit, and to adopt his own philosophy about what service should be performed and at what interval. I do not think my announcement that these E-TEC engines ran without any repair or server for a combined 3,400-hours should be interpreted as being contrary to that notion. If owners of particular motors do not want to change the oil in their motor at intervals longer than recommended by the manufacturer, or if they want to use lubricants other than those recommended by the manufacturer, I do not stand in opposition. I never made any statement that could reasonably be interpreted to mean otherwise. As for whether or not any and all new engines can run for 1,700-hours without breakdown, I do not have a clue. I am not making that assertion. |
| Tom W Clark |
You guys settled this one yet? This thread has dragged on for 100 posts...but 25 of them are from Jim himself! ;-) |
The comparison of recommended maintenance and recommended intervals for that maintenance is completely consistent. It is precisely "apples to apples." I don't think I have expressed "shock" [about the engines] at any time. I simply mentioned that two E-TEC motors ran 1,700-hours each in a period of about three and a half years. What shocks me is the reaction of people to this announcement. Let me characterize the reaction; it is either: --"ho, hum, every motor can do this," which, I have to say, surprises me, as my own experience with outboard motors in the last ten years has shown me that they typically require much more non-scheduled repair and service; In addition to my own experience, we have the many, many reports of unscheduled maintenance, repair, or breakdown of many new motors of all types, contributed here in threads begun by their owners seeking advice, counsel, or retribution; or, --"the recommended maintenance intervals for this motor published by the manufacturer are wrong." This was the initial position of some respondents who decried that no motor could operate at 300-hour service intervals because their favorite motor could not. Later these same respondents reversed themselves and adopted a position that their favorite motor could also operate at 300-hour service intervals, even though the manufacturer suggested 50-hour service intervals. |
Tom--Your observation is cogent. If readers would stop accusing me of saying things which I have not said, I would not feel compelled to correct them. |
| Tohsgib |
Where does any owner's manual tell you to change the oil at 50 hours? All I have read say 100 and 200 if synthetic. |
Nick--I don't know where it says that. I have heard 50-hours mentioned for service interval on four-cycle motors by many owners. A large commercial fleet operator in the Pacific Northwest where I visited in 2002 was following that regimen for service on his fleet of Yamaha four-cycle engines. Perhaps the 50-hour interval is just a figment of that fleet owner's imagination, and by transference, mine as well. In my automobile engine owner's manual it recommends the oil change interval be increased to twice the frequency for operating in certain conditions, and one of the conditions is periods of extended low-speed operation or idle. The USACE operation of their motors is precisely in this sort of routine--lots of slow speed operation. That is how I made the conclusion that the oil change interval might be as frequent as 50-hours. However, in my initial article, I stayed with the 100-hour figure, and calculated that only 34 oil changes would have been necessary. At no time have I suggested that 68 oil changes would have been necessary for a four-cycle motor used by the USACE, although I suspect that in many cases it might be prudent, considering the service. |
| Buckda |
Well, I have to agree with Nick on this one (mostly), JimH. An engine that is run frequently, and for long intervals at each operation are likely to run much longer in terms of hours than recreational use motors that are run infrequently. Look at a Crown Victoria that is run and maintained by a "normal driver" versus the miles you see on them in Cabs in American cities. I've been in many cabs (in Chicago) where the driver reports 275,000 or more miles on the vehicle. The suspension is loose, the thing feels like it's falling apart, but the engine is running smoothly. Amazing. Not really. A four stroke outboard in commercial use is likely to outperform (in terms of hours) a four stroke in recreational use, and the same is true in DFI 2-strokes. I think it's great that these motors have 1,700 hours on them with less than scheduled maintenance. What do I think it shows? That the E-TEC DFI platform is a reliable, stable platform that can provide good durability. It does not provide a platform for a superiority claim - it just provides evidence/verifiable proof that the motor system is as reliable as others. At this point, I hope/think Evinrude is beyond the need to justify this point to the public, but these reports are good additional evidence when discussing such matters with other brand faithful who may still be trying to introduce or spread FUD about the E-TEC platform. |
Dave--I do not dispute (with either you or Nick) about the likelihood that an engine run on a daily basis and for long periods of time will be able to accumulate more hours of operation without service than an engine run in very intermittent and very limited service. I would agree with that assertion. I also agree with Dave that even after years of strong performance, there is a cadre of people who introduce fear, uncertainty, and doubt about the E-TEC motor whenever it is mentioned. |
| jharrell |
Since the moderator recommends a 50 hour oil change interval for 4-strokes under commercial or heavy use, what is the moderators opinion of the following note in the E-tec owners manual on the 300 hour service schedule: "(1) Average recreational use. Commercial use, heavy use, or use in salt or polluted water requires more Would USACE use not reasonably be considered "heavy use"? What should be the service interval on a Etec in commercial, heavy or salt use? |
| captbone |
Actually you do dispute it Here is the quote from just a few line above ho, hum, every motor can do this," which, I have to say, surprises me, as my own experience with outboard motors in the last ten years has shown me that they typically require much more non-scheduled repair and service; In addition to my own experience, we have the many, many reports of unscheduled maintenance, repair, or breakdown of many new motors of all types, contributed here in threads begun by their owners seeking advice, counsel, or retribution; or, |
| prj |
Respectfully, there is also the repeated conflation of hours from two engines as evidence of the durability of an ETEC, and in comparison with the number of maintenance cycles required by a four-stroke. It reads quite a bit like this: In the fine print, it is clarified that those 20,000 hours were spread over 40 engines. Factual, but unnecessarily misleading which brings into question the marketer's, ahem, author's motive or agenda. |
Readers were well informed in the first article about how many hours were on each engine. I can't imagine a more simple statement of facts than the one I made. And, again, with these E-TEC engines only 2007 models, they have not had a chance to accumulate 1,700-hours in recreational use where they are run only 50-hours per season. If they were typical recreational engines, they might have been run only 200-hours. I can only imagine the hue and cry from the peanut gallery if I posted an article that said an E-TEC had run for 200-hours and this was an example of longevity. I have no idea what Bombardier considers "heavy use" and exactly what they recommend. They seem to just say to move the maintenance interval up to "annual" based on what jharrell has quoted. I will say I am astonished that jharrell has gone digging through Bombardier literature looking for something to use as a "gotcha" to dispute something I've said. You normally don't get that sort of research from the casual axe-grinder. Very good work. Most engine manufacturers alter their policies about warranty and maintenance if an engine is used in commercial service. That this is done with the E-TEC is not particularly unusual. Again, taking a cue from my automobile, four-cycle engine maker seem to follow this rule, too. Again, the facts I have presented here are not really subject to very much dispute. Let's review: --the engines hours come directly from the engines themselves, via their engine history report; --the flawless running and lack of unschedule maintenance and repair comes from the dealer and the mechanics, whom I know well. I also said that if a four-cycle engine manufacturer required oil change at 100-hour intervals, here would have been (a total of) 34 oil changes performed on these two engines with 1,700-hours of running time (each). I am confident in my math. I don't think there is any dispute. The dispute seems to be all about the concept that this event should have even been worthy of notice. Apparently some people think that engines which run flawlessly for 1,700-hours in three seasons of boating are not worthy of even mentioning. I think this is noteworthy, obviously, which is why I posted my simple announcement about these engines. |
| Tom W Clark |
quote: Jim -- I think that sums up this thread very nicely. However, I am a bit discouraged at the thought that you apparently think we should expect flaws to occur in the first three years of ownership of a new E-TEC. My assumption had formerly been that after paying $15,000 or so for a new outboard motor I might expect it to run flawlessly for three years. I did not know I should expect it to not run flawlessly for three years but, if it does, then express great surprise and cultivate a prolonged online discussion about how remarkable it is. |
Tom--we cannot limit ourselves to just talking about the bad stuff. Once in a while we have to talk about the good stuff. You can only talk so much about fuel pumps or Fuel System Modules ruined by ethanol, thermostats that are frozen, poppet valves that leak, voltage regulators that catch on fire, starter motors that won't start, water condensing in the fuel tank, and all the other grist for the mill. Once in a while someone has something positive to say. And, besides, when someone says something positive it gives the nay-sayers and boo-birds a chance to jump in. |
| Tohsgib |
Ok...My Honda Hybrid has over 90k in less than 3 years and has been flawless...brake pads are original. 2 sets of tires and God knows how many wiper blades but no problems. Next time you want to post something "astounding" please feel free to do so. This however is far from astounding, amazing, pretty much short of a dry fart. Jim you started it, I hope you can handle it....this thread is STUPID and not worthy of bandwidth!!! I mentioned my neighbor with a 50hp Honda with over 5000 hours on it years ago...nobody gave a squirt...why should we over 1700? |
| Clark Roberts |
I am disappointed that readers/contributors to this forum are reffered to as "axe-grinders, catres of people, peanut gallery, nay-sayers, boo-birds...etc"!!! Beam me up! Clark |
OK, OK, from now on, no one can say anything good about a motor unless they heard it fourth-hand, saw it in a caption to a picture on an obscure website, or just plain made it up. The crowd has spoken. [Thread closed.] |
