  Horsepower Rating
Author Topic:   Horsepower Rating
grander posted 10-24-2010 10:50 AM ET (US)   Profile for grander   Send Email to grander
[I]s the rated [horsepower] for a 2006 90-HP [E-TEC] measured at the propeller or the flywheel? [An] [E]vinrude technician said the older [E-TEC engines] were measured at the flywheel. What is the weight for the 90 [E-TEC]?
Tohsgib posted 10-24-2010 10:53 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Tech is an idiot...find a new tech please. Outboards have not been rated at the powerhead (any brand) since the mid 80's. All outboards 1986+ are prop rated.
jimh posted 10-24-2010 12:11 PM ET (US)     Profile for jimh  Send Email to jimh
You can get all the information about the Evinrude E-TEC 90 from the Evinrude website. We do not try to collect and catalogue information about every outboard motor and all their specifications. The best source for information about outboard motor weight is from the manufacturer. If you want simple data like that, just look it up yourself on the manufacturer's website.
The rating of engine horsepower for outboard motors conforms with the ICOMIA 28-83 standard. I published a copy of the standard many years ago, and for a long time it was the only copy available on-line. You may be able to find the standard published elsewhere now. You can read the standard at
http://continuouswave.com/whaler/reference/ICOMIA28-83.html
The standard is a bit hard to understand, and even very smart and very well educated readers tend to misunderstand what it says. There is a limit on horsepower rating of six percent deviation from maximum. There is a tolerance of ten percent variation allowed for production variation. These two are often confused.
In my opinion, inclusion of a ten percent tolerance for production variation is an anachronism, a throwback to old production methods. Perhaps in the way-back there was variation in production of engines with a range of plus-or-minus ten percent, but I doubt that is the case today.
Modern production methods produce products that are very consistent, very similar. In many cases there are several engine of various horsepower ratings whose mechanical design is identical. The variation in horsepower is achieved only from variation of stored code in the electronic processor that controls the engine. You can have three models, say a 200, a 225, and a 250-HP version, which are all identical except for the stored code in their control modules. My expectation is that engines of this type will produce very close to the rated horsepower, with little tolerance for variation.
In addition, most modern engines have to met emission requirements to be sold in various places. The agencies which certify the engines as passing emission requirements generally assess the emission output on the basis of horsepower. Therefore, in order to know if an engine meets emission limits based on horsepower, the horsepower of the engine must be established precisely. All engine manufacturers submit certified test data of their engine horsepower to regulatory agencies, and often the data is made public, albeit sometimes in a hard to read form. Also, some manufacturers seem to go to lengths to obscure the data so it becomes very hard to identify precisely what engine is being tested, that is, the normal model designator, say VERADO 250-HP, is not used, and, instead, some obscure family emission limit (FEL) designation is used to identify the engine.
As for your technician who told you that Evinrude used a flywheel rating for the E-TEC perhaps the technician said that Evinrude used a different rating system on outboard motors made prior to 1983. That would be more likely. Usually Evinrude does not certify technicians until they pass several training courses. Ask to see the certificates of that technician where he has attended training at the factory. Evinrude has a long history of excellent training of its dealer workforce. Their factory three-day or longer training programs are very thorough. A technician does not get a certificate just for sitting around drinking coffee for a week. They have a test laboratory in which engines are rigged with intentional bugs and the student must diagnose and repair the problem. I cannot imagine that a trained and certified Evinrude technician would tell you a crazy story like the one you have reported. It is much more likely that you misunderstood him.
contender posted 10-24-2010 12:12 PM ET (US)     Profile for contender  Send Email to contender
Tohsgib: does that mean that engines before 1986 measured at the flywheel are not the same as the engines today? Like would a 1984 40 hp Evinrude compared to a 2010 40 hp Evinrude be different in hp? If this is correct then an engine today would be producing more hp than stated? Meaning a new engine would have to make and produce more hp at the flywheel to make 40 hp at the prop? Yes or no?
tedious posted 10-24-2010 01:42 PM ET (US)     Profile for tedious  Send Email to tedious
Contender, the answer to your questions is yes.
Tim
Tohsgib posted 10-24-2010 11:48 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
The ratings changed between 1984 and 1986. A 1984 OMC "could" be the same as a 2010. A 1984 OMC was 35hp, in 1985 it was 30. The 1983 Merc 40 was a 35 in 1984, etc. A flywheel-rated engine is roughly 10- to 15-percent less in HP than prop-rated. So theoretically a pre-c.1980 something Montauk should only handle a 90-HP with a modern motor, not the stated 100.
jimh posted 10-25-2010 04:57 AM ET (US)     Profile for jimh  Send Email to jimh
The ICOMIA standard says:
"3.3.1--Power shall be declared as Propeller Shaft Power at the propeller shaft of engines sold with complete propulsion units"
Tom W Clark posted 10-25-2010 10:18 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Maybe yes and maybe no. Nick has the dates right; it was the 1984-1986 period that saw the changeover to prop shaft power ratings.
In the case of OMC, not all models changed in the same years. In 1984 and 9185 there were some powerhead rated outboard motors sold by OMC and also some prop shaft rated models.
But while the 1985 Johnson and Evinrude 235 became the 225 in 1986, the 150 stayed at a rating of 150 HP.
I owned both 1983 (powerhead rated) Johnson 150 and a 1990 (prop shaft rated) Johnson 150. Both motors were used on the same boat, my 1983 Outrage 18. There was zero difference in power between those two motors.
There is a misconception that just because an outboard is prop shaft rated, it is necessarily more powerful than its powerhead rated ancestor. Not always true.
face posted 10-25-2010 10:32 AM ET (US)     Profile for face  Send Email to face
Unless we're talking about 13' or 15' classic whalers, I don't find an additional 10-20 hp to make any difference in performance. With my father's 27', 50-100 additional hp doesn't seem to change performance significantly. With 3 different pairs of motors since 1989 the boat doesn't seem to care if it has 200's, 225's or 250's. At least not significantly. When I read perfomance results here at continuous wave for the 18 outrage, I see very little difference in performance with various hp outboards.
captbone posted 10-25-2010 12:44 PM ET (US)     Profile for captbone  Send Email to captbone
I am going to respectfully disagree
10% difference is a valid point.
"But while the 1985 Johnson and Evinrude 235 became the 225 in 1986, the 150 stayed at a rating of 150 HP."
The 1985 235hp was the 2.7 liter crossflow and the 1986 225hp was a completely different engine 3.0 looper. The crossflow was downgraded to 185hp/175hp max for rest of its days.
The 150hp similarity would be because it was at the bottom of the V6 line up and same crossflow engines until they went to the 60 degree looper 150/175 in mid 1990s.
dgoodhue posted 10-25-2010 01:04 PM ET (US)     Profile for dgoodhue  Send Email to dgoodhue
I am sure their are some examples where it the rating didn't change or where a strong x hp flywheel is has more hp than a weaker x hp propshaft motor. In general the propshaft rated motors are stronger than the flywheel equivalents, except in a few .
Tohsgib posted 10-25-2010 02:14 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
The 235 was dropped after 85. The 200 in 1984 became a 185. In 86 as the bone points out they went to a Looper block and made an all new 225 & 200hp so the 185 became a 175 until 1991 when they came out with Looper 150/175's. The early 225 & 200' I think were still 2.7L and it was not until the Ocean Runner and Ocean Pro's in 1993 that they were bumped up to 3L.
Tohsgib posted 10-25-2010 02:20 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Verified the 1986-1992 Looper 225/200 were 2.7L.
captbone posted 10-25-2010 02:51 PM ET (US)     Profile for captbone  Send Email to captbone
Bigshot
This is a case where we are both right and wrong.
I know that the 1990 225hp was a 3.0 liter 3000cc looper, I suspect the 1989 was a 3.0 liter also. I do recall the early loopers were 2.7 like you said until 1987/1988.
The 60 degree v6 150/175 came out in 1991 with the Spitfire series. They also offered the crossflow XP 150/175hp that same year.
captbone posted 10-25-2010 02:54 PM ET (US)     Profile for captbone  Send Email to captbone
I just checked and even the OMC 1988 was a 3000cc 3.0 liter looper for the 225/200.
Tohsgib posted 10-25-2010 03:08 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Ok I only verified the 86 & 87 brochure. You are correct the 88 is a 3.0L. I thought my bud had a 92 2.7L but it was most likely an 87. Weird they made both types of V6's for only 1991.
captbone posted 10-25-2010 03:16 PM ET (US)     Profile for captbone  Send Email to captbone
That is when OMC was the undisputed king.
I loved the standardized 4.0 liter, 3.0 liter, 2.0 liter set up that OMC used to use. It made life real simple.
I wish Yamaha would do that with there modern plasma bore four strokes (v8, v6, v4).
Tom W Clark posted 10-25-2010 09:44 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
quote:
I don't find an additional 10-20 hp to make any difference in performance. With my father's 27', 50-100 additional HP doesn't seem to change performance significantly.
Your dad's boat must somehow avoid the laws of physics then. A 10-15 percent increase in horsepower will increase most Boston Whaler's top speed by 2 to 3 MPH, and that is both significant and measurable.
The variation in power is well with the ICOMIA 28-83 standard. There remains a misconception that the HP rating on the cowl is necessarily the actual power output of the motor.
Trust me, there is no difference between the OMC 48 and the 50...or the old powerhead rated 55.
There is no difference between the 88 HP and the 90 HP models, nor the 112 HP and the 115 HP.
Tohsgib posted 10-26-2010 12:22 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
To go even further...I doubt there is much difference between a 40 & 50hp if same brand and displacement, they could both be 45hp and conform.
L H G posted 10-27-2010 03:08 AM ET (US)     Profile for L H G
Would any of the Evinrude E-tec fans here care to give the actual HP, given by Evinrude in their marketing, of the following Evinrude engines:
200 H.O.
225 H.O.
250 H.O.
Aren't they using the 10% rule, not 6%?
Someone recently stated here that an Evinrude states the 115HO was 127HP. That's +10% plus a little.
jimh posted 10-27-2010 08:38 AM ET (US)     Profile for jimh  Send Email to jimh
There is no "ten percent rule." There is a manufacturing tolerance of ten-percent that is allowed to account for variations among engines produced. It seems to have become axiomatic to assume that this means "ten-percent more than declared horsepower" by some aficionados.
The rated horsepower of an engine is recommended by ICOMIA to be not less than six-percent of the maximum. From the standard:
quote:
6.2
It is recommended to choose the full throttle engine speed range mentioned in 3.1.1 in such a way that the highest power within this range does not exceed the declared power by more than 6%.
I cannot personally give any information on actual horsepower of Evinrude engines because I have never tested or measured the horsepower. I would rely on the certified test data from Evinrude that was used for the EPA testing. You can look up the EPA test data on the EPA website. The Evinrude test data is generally easily located because they use the same engine model name in the test data as they do in their other data.
The Evinrude H.O. models actually do not declare a horsepower, but instead say they are tuned for "high output." Of course, everyone infers from the numbers associated, such as 200, 225, 250, that those numbers are indicative of horsepower. But I do not see anywhere that Evinrude in its marketing declares a horsepower rating. Since there is no declared horsepower rating, there is nothing to multiply by ten-percent.
Tom W Clark posted 10-27-2010 09:42 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Jim -- You have completely misinterpreted ICOMIA 28-83, 6.2. All that is saying is that if your E-TEC 225 is rated at 225 HP at 5150 RPM, it cannot produce more than 238 1/2 HP (225 + 6%) at 5800 RPM. It has nothing to do with what the motor is called or what it says on the cowl.
Owtrayj25 posted 10-27-2010 10:29 AM ET (US)     Profile for Owtrayj25  Send Email to Owtrayj25
quote:
The Evinrude H.O. models actually do not declare a horsepower, but instead say they are tuned for "high output." Of course, everyone infers from the numbers associated, such as 200, 225, 250, that those numbers are indicative of horsepower. [b]But I do not see anywhere that Evinrude in its marketing declares a horsepower rating. Since there is no declared horsepower rating, there is nothing to multiply by ten-percent.[b]
My emphasis added.
This statement is really quite funny. I wonder what Lockemans Hardware would say if I wanted to repower my 19'Boston Whaler Outrage with a max HP rating of 200 HP with a E-TEC 250 HO. When they refused because of concerns of over-powering the boat (as I would expect that they would), my argument would of course be that I am entitled to because there is no declared horsepower rating for the E-Tec 250 HO, and therefor, I would be legal. And I'm sure my insurance carrier would also accept this explanation as well. LOL.
Tom W Clark posted 10-27-2010 10:32 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
You will find the power output of the Evinrude HO models expressed in Kw on a label on the motor's mounting bracket.
Tohsgib posted 10-27-2010 11:12 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Regular 250 is 187KW.
Question: What does a HO say?
Answer: Where's my money!!
jimh posted 10-27-2010 05:21 PM ET (US)     Profile for jimh  Send Email to jimh
I did make a misstatement, but not the one Tom has offered. I meant to say that ICOMIA recommends that the maximum power in the recommended RPM range not be any more than 6-percent greater than the declared power. The difference I am making here is that the six percent is measured from the declared power upwards to the maximum power. What I said earlier was incorrect because it implied the six-percent was measured downward from the maximum.
However, I do not believe that I have misinterpreted the intent of ICOMIA's recommendation. What Tom has offered as a correction is not any different than what I said. If my motor is declared a "225-HP" motor, then it should not produce more than 1.06 x 225 or 238.5-HP at any point in the recommended operating range. However, in addition to this there is an allowance for production variation, and this allowance is even greater, ten percent. Also the correlation between declared power and actual maximum power is just a recommendation.
As for what any dealer, and this includes one of the best dealers for Evinrude outboards in the United States, LOCKEMAN'S HARDWARE AND BOAT, might say about a customer asking for a particular motor to be installed on a particular boat with regard to the horsepower rating of the boat and motor, I cannot predict. Dealers who have been selling outboard motors for a long time are usually quite knowledgeable about their obligations toward customer safety. The rigging and installation manual of the individual motor may provide guidance. I would defer to the manufacturer's recommendation in his rigging manual.
Power rating labels which denote power in kilowatts are perhaps intended to satisfy requirements in other regions besides the United States, where disclosure of power may be required under different rating methods. We have seen in the past that some Yamaha four-cycle outboards, for example, are sold in the U.S.A as 90-HP engines and sold in Europe as 100-HP engines. These variations may be due to regulatory influences, or perhaps they are just due to marketing strategies for a particular market.
captbone posted 10-27-2010 05:46 PM ET (US)     Profile for captbone  Send Email to captbone
There is no one answer to obtaining the exact HP of any given outboard motor without dynoing each engine.
The EPA information provided in KW is not accurate either as they are standard numbers provided by the engine builder to the EPA. There is also difference in HP from engine to engine in a given model.
A 300hp Evinrude could be either 303hp or 309hp even if the manufacturer was shooting for 300hp. The minute differences will not allow for each engine to be 300hp on the nose. This difference combined with the target HP of each engine (different from HP and brand) can make for a large swing.
You can have twin 150hp engines on the back of your boat and have one putting out 157hp and the other putting out 152hp.
Everyone hopes that their brand is one that underrate HP for a given model so are at the upper limits of allowable HP for the decal on the back of the engine.
Alot of people continue to relay information that they have heard on the internet. (F225 Yamaha= 208hp, Evinrude 115hp = 128hp) But the truth is that they are buying into the hype and dont have a clue. Until someone provides you with a dyno sheet done by a third party, you are just guessing.
Tom W Clark posted 10-27-2010 06:12 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Jim -- In your commentary on ICOMIA 28-83 you write:
"The "rated power" is recommended to be presented so that there is no more than a 6% difference between the rated power and the peak power which occurs in the full throttle speed range. (6.2). For example, an engine rated at 225-HP should not have more than 238.5-HP at any speed in the full throttle speed range. In general, the measured horsepower will be greater with engine speed. This means that if the full throttle speed range is chosen to be a wide range, for example 5,000 to 6,000 RPM, it is possible that the engine's peak horsepower will occur near 6,000 RPM, but the rated horsepower must be that obtained at 5,500 RPM. The difference between these two horsepower ratings is recommended to not be greater than 6%."
It is required that the power at the top of the recommended WOT RPM range be within six percent of the power at the middle of the recommended RPM range. What is recommended is the choice of RPM range the manufacturer makes allows this requirement to occur.
I also note that the 10 percent deviation allowed in section 7 could very well be used by a manufacturer to make a motor that produces ten percent more or less power than it's nominal horsepower rating. Why wouldn't it?
L H G posted 10-27-2010 09:57 PM ET (US)     Profile for L H G
Jim, in your article about testing the Evinrude 250HO, you indicate the engine seal says 249.5 HP (which apparently is a lie), but in your "Addenda" section, you say the engine is believed to be 270HP. I would agree. Who gave you that 270HP information? Evinrude or Lockeman's.
You also say the engine was more powerful than the extra 25HP (over your old 225) would indicate. Why not, it IS more than 250HP.
http://continuouswave.com/whaler/reference/ETEC250HO.html
All of these performance models, of all companies (XS, ProXS, HO, Vmax, SHO), use the +10% rule, at least. Since Mercury does it, and has been for years, they all have to, or they'd be left in the other's wake. That's why these performance engines cost more. You are getting more.
An engine can also be shy of it's rated HP using the same 10% rule to the negative. For some examples, Peter has indicated the Yamaha V-6 225 4-stroke is over rated (something Evinrude's advertizing took good advantage of), Nick has indicated the Yamaha 90 2-stroke was over-rated, and many here have speculated that the 90 E-tec may not quite be putting out 90 HP. Even on a lighter weight classic Montauk, it's not as fast as the Mercury 90 EFI is the heavier 170 Montauk.
jimh posted 10-27-2010 11:01 PM ET (US)     Profile for jimh  Send Email to jimh
To clarify what L H G is saying about my lengthy report on testing of an Evinrude 250 H.O.:
--there is a label or emblem on the engine that gives its power in kW. My involvement in this was simply to convert kW to HP using the standard relationship between them. I am at a loss to know how this could be "a lie" as Larry has now accused me of making.
--the notion of 270-HP is mentioned in an addendum added to the article which includes a plot of engine power output versus engine speed. The graph was taken from a similar one presented in some promotional literature from Evinrude, as I best recall. I used that graphic to create my own graphic. I have high standard for plotted data, and I do not like to publish really ugly graphs, or graphs where the coordinate axis are distorted in order to produce a favorable impression. I typically blow up the original, take careful measurements of it, and re-make my own graph.
As for the source, I see I did not cite the source in the addendum when I added it. If I did not recall the source at the time I wrote the article, it is very unlikely I can recall it now, two years later. It was probably from promotional literature. It certainly was not from any dynamometer testing I conducted.
In general if I have a solid source for data that is in the public domain, I will give it. If I have a source which is not generally available to others, I may not cite it, and instead I will say something like "it is believed," or "it may be."
As I noted in the article and as Larry mentions again here, the increase in speed observed seemed to be greater than would be expected if one assumed that the original motor was 225-HP and the new motor was 250-HP. You can attribute that in two ways:
--the old motor had less than 225-HP and the new motor has 250-HP, or
--the old motor had 225-HP and the new motor has more than 250-HP.
Since I did not actually measure either motor's horsepower, I have no idea which case applies. Also, in the article I note other factors which could influence the boat speed results. I cannot imagine how I could have more clearly said that:
quote:
"It would be inappropriate to attribute all of the improvement in speed obtained with the new motor to the greater power of the engine itself. "
Therefore I will repeat to L H G:
Larry--it would be inappropriate to attribute all of the improvement in speed obtained with the new motor to the greater power of the new engine itself.
I do not recall that I stated in my article that the engine I tested had any particular horsepower or more horsepower than its supposed 250-HP as inferred from the decal and the regulatory label that indicated 249.9-HP.
But all that aside, it would not surprise at all that an E-TEC 250 H.O. might have more than 250-HP output. The motor was really a powerful motor, and I have to say that flying along at 47-MPH was quite fun when the water conditions permitted it.
Also, thanks to L H G for mentioning my article on the 250 H.O.--I hope others who have not read it will now take a look at it. However, pour a big cup of coffee as it is a lengthy article and is packed with information about the Evinrude E-TEC H.O. motor. By the way, I love the picture of my boat with the blue E-TEC which appears in the article. Bombardier loved it too, and asked me if they could use it on the cover of their dealer-only publication a few years ago. Considering the courtesy of LOCKEMAN'S in loaning me the motor, I thought it only proper to permit Evinrude to use my picture of their motor. I hope that does not get me into too much trouble with the E-TEC FUD patrol.
jimh posted 10-27-2010 11:07 PM ET (US)     Profile for jimh  Send Email to jimh
Tom--I am going to get the CONTINUOUSWAVE legal staff (elaelap and K Albus) to carefully parse everything in ICOMIA and see if something I said is wrong. I will read your comment over a few times and see if I can figure out what the difference is in our interpretations.
jimh posted 10-27-2010 11:19 PM ET (US)     Profile for jimh  Send Email to jimh
'bone--I agree there is likely some manufacturing variation among engines which are given a particular power rating, but I do no think the variation is as wide as the ten-percent tolerance might permit. Let me explain with an example:
In 2010 if an engine manufacturer produces an engine that is rated at 200-HP, it could very well be that most engines it makes have, say, 205-HP, and that the variation is on the order of perhaps one-percent. This means that almost all engines made as "200-HP" engines would lie in a small range of say 203-HP to 207-HP. My basis for this is just my simple faith in the consistency of modern manufacturing. The methods used for quality control in modern manufacturing also tend to reduce random variations in the product. Products are now very uniform. It may very well be that some manufacturers are not delivering this kind of consistency, but I would also suspect that their products would also tend to have more variation in quality, too. Consumer are very demanding in 2010, and any manufacturer that is turning out products with wide variations in quality will soon be out of business. If you are not 99-percent consistent in manufacturing, you will have too much warranty cost, too much scrap material, too much re-working.
Now my faith in modern manufacturing methods may be flawed, and I may be completely wrong about variations in the amount of power produced by similar engines.
Tom W Clark posted 10-27-2010 11:23 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Jim -- Go back and read ICOMIA 28-83. It's plain English.
In a nut shell, your theme is that an outboard cannot vary from its nominal horsepower rating by more than six percent based on section 6.2. I think you are misinterpreting section 6.2 and ICOMIA 28-83 accommodates a variation in actual horsepower of ten percent.
jimh posted 10-27-2010 11:55 PM ET (US)     Profile for jimh  Send Email to jimh
Tom--Do you mean a ten-percent variation as allowed by production variation?
Or, do you mean a ten-percent variation between what the motor is rated and what it actually produced in the tested motor used for establishing the rating?
Again, perhaps an example of my thinking:
If I manufacture a motor and it makes between 199-HP and 208-HP in its recommended full throttle range, say, 5,000 to 6,000-RPM, my understanding is that I have to declare a rated power for the motor that is such that 208-HP will not be more than six-percent higher. The lowest power I could declare for the motor would therefore be:
208-HP/1.06 = 196.2-HP
This means the manufacturer could declare this motor to be a "200-HP" motor, but he could not declare it to be a "175-HP motor.
Once he goes into production of the motor, he is allowed to have actual production variations of the motor of as much as ten-percent. This means he could produce motors with a 200-HP decal on the side which could turn out to be as powerful as 220-HP, or as weak as 180-HP.
Now--what is different in Tom's interpretation? I assume Tom means the 10-percent applies from the start. Or, in other words, a motor that was going to be declared as a 200-HP could actually exceed that by ten-percent, which would imply 220-HP peak power. When this "200-HP" motor that actually cranks out 220-HP goes into production, does it get another ten-percent variation allowed, too? That would imply it could crank out as much as
220-HP x 1.1 = 242-HP
L H G posted 10-28-2010 12:30 AM ET (US)     Profile for L H G
Jim - I was only referring to Evinrude's label of 249.9 HP as a lie, nothing you said. Don't know how they do that on an engine clerly producing higher HP? Maybe Seahorse knows why?
I have always thought Evinrude wants customers to think of an HO as more than rated HP. Ohterwise, why pay more for it? Nor do I think they would want you to be saying, and proving, the 250 H.O. is ONLY 250HP. That could kill sales. I think they sell those into the bass market on the basis it is really a 270-275HP engine. Mercury and Yamaha do the same thing, so I'm not picking on Evinrude. I used them because you had tested one, and did indicate 270HP, which you evidently did pick up from Evinrude's marketing literature. I also liked the look of the dark blue engine on your boat, better than the white one you now have. Closer to the ultimate, Mercury and Suzuki black, of course!
In spite of all these rules and regulations, all of the engine manufacturers seem to be getting away with +10% HP when they want to, whether it's legal or not. Mercury has advertized that the 250XS is a 275HP engine also.
jimh posted 10-28-2010 08:23 AM ET (US)     Profile for jimh  Send Email to jimh
As far as outboard manufacturers and power ratings, they all seem to be cagey about publishing real figures for power and torque. I recall that several years ago, when the VERADO was first being introduced by Mercury, George Buckley was making a presentation to financial analysts. In the course of this presentation he showed a slide that had the horsepower and torque curves for the new Verado compared to competitor engines. Generally these presentations are available for viewing on-line afterwards, and there is an audio recording of the presentation along with all the graphics. Well, of course, I was very interested to see that slide of the power and torque curve of the Verado. Of all the graphics in the presentation, that was the only one not available!
Why engine manufacturers do not publish hard data about engine power output and engine torque is beyond me. I would guess that perhaps they are reticent to give out that information because they consider it a secret. As a customer, you'd think you could get that sort of data, but you seldom can find it.
Without hard data, the power output and torque for a particular engine get tossed around in web discussions, and usually someone contributes some numbers, which were probably taken from marketing literature that the manufacturer gave to its dealers to use in selling the engine but did not release to the public. Someone says, "Hey--this new Verado 250 Pro makes 277-HP," and then soon afterwards that becomes the accepted figure. I suspect that all the engine makers have internal literature they have cooked up to use as selling points, and this literature becomes the source of some of the numbers that people come up with.
In some model years, as I recall, there was a difference in the rating of some engines as shown in kilo-Watts on their certification labels compared to the engine cowling decal in horsepower. However, that practice seems to have stopped, and it is typical now that the rating in horsepower and kilo-Watts is more or less the same power.
Peter posted 10-28-2010 08:41 AM ET (US)     Profile for Peter  Send Email to Peter
I know in the reference article there is an assumption that outboard motors are ungoverned. But what is the basis for the assumption? Most if not all outboard motors made today have a rev limiter. Would that not make them governed?
face posted 10-28-2010 10:07 AM ET (US)     Profile for face  Send Email to face
"Your dad's boat must somehow avoid the laws of physics then. A 10-15 percent increase in horsepower will increase most Boston Whaler's top speed by 2 to 3 MPH, and that is both significant and measurable."
Sorry but I don't find that very significant. Really doesn't avoid the laws of physics...it's just a lot of boat. 27 with whaler drive is basically a heavy 30' boat that takes a lot of power to move. Most of the boats discussed here are 45mph boats regardless of power.
Tom W Clark posted 10-28-2010 12:09 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
No, that is not the case. We can see the certified power of any outboard my looking at the EPA certification data they present on their web site. You can download the data here and peruse it:
http://www.epa.gov/otaq/certdata.htm
Looking through this data we can lay to rest some of the assertions made above including…
...the Yamaha 90 2-stroke was over-rated, and many here have speculated that the 90 E-TEC may not quite be putting out 90 HP. Even on a lighter weight classic Montauk, it's not as fast as the Mercury 90 EFI is the heavier 170 Montauk.
No, the E-TEC 90 puts out 89 HP as does the classic three cylinder Mercury 90 and the Mercury four stroke 90 as well as the two stroke Yamaha 90.
The E-TEC 300 puts out 276 HP which is interesting because that is more than six percent less than 300 HP. So much for Jim's interpretation of ICOMIA 28-83 section 6.2
Tom W Clark posted 10-28-2010 12:16 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
No, you misunderstand section 6.2. If you manufacture a motor and it makes between 199-HP and 208-HP in its 5,000 - 6,000 RPM recommended full throttle range you have to make sure that the power at 5500 RPM is not more than six percent less than 208 HP. That is all. It has nothing to do with what the nominal horsepower rating.
Tohsgib posted 10-28-2010 12:36 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Tom you are probably right but I have driven many 17's and the 90 Yamaha is weak and performs more like 80hp. This is just an observation from myself and nothing else and all that I have stated here. Maybe the other 90's are just stronger but my 70hp almost kept up with it performance.
Tom W Clark posted 10-28-2010 12:52 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
My nephew has an old Yamaha 90 on his Montauk. I've used that boat when I've ben on the Cape. It is more or less as fast as any other Montauk with a 90 but there is not the same acceleration as there is with, say, an old V-4 OMC motor.
We have to remember that an outboard's "power" as used in this discussion, is the power it puts out at WOT.
It is not a measure of throttle response, acceleration, sound, fuel consumption or anything other quality beyond the simple physical definition of power (work = force x distance or, specifically in this context, torque x RPM).
Tohsgib posted 10-28-2010 01:35 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Where I came up with "80hp" is from performance numbers collected here and from my own experiences. A 17 with a 70 will do about 38. With a 90 Yamaha about 41, and a V4 about 44. This puts the Yamaha in the middle which would be "80hp" roughly. Now I know this is getting off topic but my point is this is going to be harder to notice on a boat that is rated for 250hp. The performance between a 200 & 250 might not be as easy to define. Take a look at say a big Whaler, the performance from twin 250's to trips is not that great and we are talking about an extra 250hp. The difference between a 225 and a 250 in my book would be very small.
Tom W Clark posted 10-28-2010 01:45 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I agree with that, but a percentage gain (or loss) is what it is. I think face is confusing "significant" with "large". Open a dictionary.
Tohsgib posted 10-28-2010 01:50 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
True and how often are we at WOT and for how long? If a bass boat, 3mph is LARGE even though % is small at 75mph. With a Whaler is 42 or 44 really THAT important? Heck I can run 2-3mph difference between 95 degree heat and 60, even with EFI.
face posted 10-28-2010 02:22 PM ET (US)     Profile for face  Send Email to face
a : having or likely to have influence or effect : important <a significant piece of legislation>; also : of a noticeably or measurably large amount
No need to be rude Mr. Webster. In the example I mentioned on a large whaler, an additional 100hp is an additional 25%. That said, I don't see 2-3 mph as significant. This is without considering the additional price of this extra horsepower.
I also prefaced my thought with "unless we're talking about 13' or 15' classic whalers."
For most classic whalers I don't see a 10% difference in hp as significant in terms of performance, that's all.
L H G posted 10-28-2010 03:35 PM ET (US)     Profile for L H G
That's very interesting information That Evinrude/BRP admits 276HP, Tom, for the E-Tec 300HP. I had read that same infomration somewhere else, which is why I advised "onlyawhaler" to get the 250HO instead in another thread.
Talk about a deceptive selling and marketing practice! Why don't they just sell it as a 275? If they can't make an engine that puts out a true 300HP to compete with Mercury, Suzuki and Yamaha, so what. Makes you wonder what else is being fudged.
jimh posted 10-28-2010 10:09 PM ET (US)     Profile for jimh  Send Email to jimh
What is the basis for the recent conclusion that the E-TEC 300-HP only produces 276-HP? I must have slept through that part of the discussion.
dgoodhue posted 10-28-2010 11:25 PM ET (US)     Profile for dgoodhue  Send Email to dgoodhue
He is getting the data from this site
I downloaded 2007-2011 file from the Marine SI section.
On the first tab (family) of the excel file, the motors are listed by manufacturer however they are not always easily translated. The power ratings in column S are in KWH, if you convert them to HP (multiply by 1.341, I create another column and converted all the values) BRP has a D300, 2 stroke DI from listed kwh that convert to 276.3hp, they also have another D300 listed as 296hp.
I was looking at some of the Yamaha's,The new F70 was rated at 69.8hp. It looked like the old Yamaha 70 carb was listed at 65hp which I have read has been know as weaker 70hp. I also noticed the Yamaha F225 was tested at 208hp, my Dad has that motor and he always thought it was on the weaker side. Anyways some interesting info if you don't mind doing some deciphering.
jimh posted 10-29-2010 01:08 AM ET (US)     Profile for jimh  Send Email to jimh
If there is data that says the 300-HP E-TEC makes 296-HP, how do you decide it only makes 276-HP?
dgoodhue posted 10-29-2010 11:12 AM ET (US)     Profile for dgoodhue  Send Email to dgoodhue
It was a different motor and probably tested at a different time for certification (the test results are from 2007 to 2011). I have no idea how the data was enter in terms of time period, but the the new Yamaha F70 was towards the top, so that may indicate the newer tests are towards the top of each manufacturer. The 276hp E300D was towards the bottom of the results, the 296hp E300D was higher.
I wouldn't put my complete stock in the hp ratings, I imagine the ratings are 2nd priority when doing these tests, emission is probably top priority when the manufacturer is bringing/selecting a motor for test.
Tohsgib posted 10-29-2010 11:37 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Can anyone tell me what the KW is on a Suzuki DF115 and a 2 smoke Yamaha 90? I thought all brochures had to state the KW like Evinrude does?
captbone posted 10-31-2010 10:00 AM ET (US)     Profile for captbone  Send Email to captbone
I dont put any value in those EPA KW values.
Do we know where they get the values or if they are dynoing these engines while testing?
The EPA would be a great source for the actually HP of these engines but there are too many variable that we must know before we conclude that these are the max hp produced on a water dyno. I surmise that these are values provided for emissions testing from the manufacturer.
jimh posted 10-31-2010 02:25 PM ET (US)     Profile for jimh  Send Email to jimh
A bit of simple logic will suffice to completely nullify the argument just made by 'bone which suggests that somehow the engine power used in emission testing is not the maximum power of the engine. Let me explain:
Emission output limits are set based on horsepower. The more horsepower produced, the higher the emission allowed. As we have seen, manufacturers tend to struggle to produce engines which meet the limitations. The re-rating of a number of Mercury engines to Two-star from Three-star is a good example of how a manufacturer tends to struggle to meet emission rating limits. When emission is tested, an engine manufacturer has every reason to use the highest possible horsepower rating for the engine, simply because that provides the highest possible amount of emission that can occur and still be under the limit. If this makes no sense, I will further illustrate with an example:
Say an engine produces 110-HP. If the manufacturer declares this engine as a 100-HP engine, it must produce a certain amount of emission based on that horsepower. Let's call this 1.00-units of emission per horsepower, for a total of 100-units of emission. That's the limit for this engine.
Now, if the engine is really 110-HP, it still has to pass the test of only 100-units of emission. Since the engine has 110-HP, its emission must be lower, at a rate of 0.909-units per horsepower, in order that it only produces a total of 100-units of emission. This means the engine must be cleaner than the standard requires.
We see that manufacturers have trouble just meeting the standard, and it is not reasonable to think they would be able to surpass the standard and produce even cleaner engines at will. What would be the purpose of doing this? To intentionally produce an engine with more power than declared? I think not.
These days we have seen how the same engine with the same components and the same cost to manufacture can be turned into three or four different engines of different rated horsepower by the simple change of firmware in the engine controller. It seems much more reasonable to conclude that engines produce their rated power, because if they made more power they would be sold as a higher-power model and cost more. Buyers who think that they are automatically getting some free extra horsepower because they bought a certain brand are living in the past. The emission regulations apply to all brands, and they have resulted in more consist engine power ratings.
captbone posted 10-31-2010 02:58 PM ET (US)     Profile for captbone  Send Email to captbone
Jimmy
You are guessing.
My question stands
"Do we know where they get the values or if they are dynoing these engines while testing?"
If the EPA is testing the HP via a dyno then it would not matter what the stick on the back says.
Example: Evinrude gives the EPA a 250hp Evinrude. They dyno (or so you think) the engine. If it dynos at 275hp it must meet the requirement for a 275hp not the 250hp sticker. If they have the requirement by the HP group or the decals on the back of the engine then it would be in the best interests of the manufacturer to provide a weak engine that in theory produces the least emissions.
The Verado actually gained MPG and performance by dropping from a 3 star engine (Gen 1) to the 2 star (Gen 2).
jimh posted 10-31-2010 03:54 PM ET (US)     Profile for jimh  Send Email to jimh
Boney--You are making me laugh. You just provided a perfect example with your Verado citation. When Mercury derated the Verado to Two-star, the engine was allowed to produce more emission. Mercury could re-tune it for more power, precisely because they no longer had to get under the emission limit for the Three-Star rating. Your example is verification of what I said--engine makers have trouble meeting emission limits. That they would use the maximum rating possible is just a simple deduction of logic that follows.
jimh posted 10-31-2010 04:02 PM ET (US)     Profile for jimh  Send Email to jimh
I am sure that the test methods and techniques required for EPA certification are spelled out somewhere. To suppose that the EPA is so stupid that the outboard manufacturers could easily game the system is fanciful. Do you really think a whole building full of EPA engineers in Ann Arbor can be easily fooled and it just takes a guy posting to a website to show up their deficiency?
I also suspect there are some big penalties for manufacturers who falsify test data.
I look at it this way: the EPA engineers may not be smart enough to figure out how to sell 700-lb outboard motors for boats built for 350-lb motors, but I have to think they're smart enough to know how to enforce their own emission regulations without getting tricked.
captbone posted 10-31-2010 04:18 PM ET (US)     Profile for captbone  Send Email to captbone
Jimmy
Your still guessing and have not answered my question. You dont know the answer and try to come up with any logic to prove your point.
The Verado improved MPG the implementation of the Gen 2 engines?
Also breaking down the data from the EPA testing you can see from the data that they are not dynoing the engines.
Here is the example
E-tec E200 149.14KW@5250 = 200HP
E-tec E250 186.00KW@5150 = 250HP
Honda BF200 149.1KW@5500 = 200HP
Honda BF225 167.8KW@5500 = 225HP
Do you really think these engine made the exact posted HP on the nose? Not 1hp off?
If the EPA is dynoing all of these engines then the information should be available under the freedom of information act. You should then in theory be able to get the HP and torque sheets for all of these engines for free.
My point is that the EPA is not dynoing these engines and you dont know how the EPA is coming up with these numbers.
SJUAE posted 10-31-2010 04:36 PM ET (US)     Profile for SJUAE  Send Email to SJUAE
Jim
Talking of which, here is some numbers from the recent post classic thread on engines at higher altitude. From the linked article on the Verado development I have overlaid the 3 curves from the Evinrude ETEC test programme data (legend at the top)
http://i707.photobucket.com/albums/ww76/SJUAE/Stern%20and%20misc/ torqecurves.jpg
Read in to it as you wish :)
Regards
Steve
jimh posted 10-31-2010 05:48 PM ET (US)     Profile for jimh  Send Email to jimh
'boney--Why are you asking me how the EPA tests? Ask the EPA. I am not the EPA. I have simply mentioned that I rely on the EPA test data as a good source of engine horsepower information. If you don't want to rely on it, that is fine.
It not necessary for me to convince you about the EPA data in order for either me, the EPA, or the manufacturers to be happy with the data. If you are not happy with the data, please feel free to make no use of it. However, because you have decided the data has no value, this does not automatically mean the data has no value until you become convinced it does, nor does it mean that my new mission in life is to convince you.
If you think the EPA data is meaningless, proves nothing, and has no value, feel free to declare your free thinking about the EPA data. However, if you don't mind, could you please tell me what other data you will use to discover the engine horsepower? Is something you read on a website more valid than the test data the federal government is using to certify the engine for sale?
You are under no obligation to answer, but, if you feel like it, just let me know where you can get better and more reliable data about engine horsepower. Thanks.
captbone posted 10-31-2010 06:09 PM ET (US)     Profile for captbone  Send Email to captbone
I am not trying to argue
But you admitted in your answer
"I have simply mentioned that I rely on the EPA test data as a good source of engine horsepower information. "
My point is that you rely on this information and you know nothing about how its obtained and quote it as fact.
You claim this is the actual engines HP but you have nothing to back that up. I wish that the EPA did dyno all Marine engines and posted the emission info/HP and dyno sheets. All the evidence points to the conclusion that they dont dyno the engines and instead post the KW provided by the manufacturer.
dgoodhue posted 11-01-2010 07:03 AM ET (US)     Profile for dgoodhue  Send Email to dgoodhue
I disagree that the evidence is leading to the EPA not dynoing the motor. I don't work for the EPA and or don't have experience with marine emissions. I work with industrial sensor and often deal with EPA emissions in industrial environments.
The EPA is already putting the motor on a Dyno to load the engine to run its emission output tests. The data is the spreadsheet is very specific, and I don't think they are collecting manufacturers data just for the heck of it. I have a hard time believing the EPA wouldn't Dyno the motor to verify the motor being tested is the motor the manufacturer says it is.
jimh posted 11-01-2010 07:44 AM ET (US)     Profile for jimh  Send Email to jimh
'bone now questions whether or not information like the horsepower of an engine in an EPA publication can be accepted without knowing the precise method of obtaining the information. I liken this to saying that one should not trust NOAA to give the temperature until one knows precisely how it was measured. If NOAA says the temperature is 71-degrees, I have never heard anyone question the accuracy and demand that a third-party explain to them the measurement technique.
As I said already, it is not necessary that I satisfy 'bone that data published by EPA is accurate in order for that data to be considered useful by others. I am a third party in the fight between 'bone and EPA. I will leave it to those two to settle their differences.
I do have to observe this anomaly: 'bone thinks that it is odd that an engine rated for 250-HP produces 250-HP in a test. I have to think that it would be much more odd if an engine rated at 250-HP produced some other horsepower in a test. Exactly what horsepower should an engine rated at 250-HP produce? Should it produce 245-HP? 246-HP? 247-HP? As far as I can tell, the notion that an engine rated as 250-HP produces 250-HP is the least odd outcome possible. We have also seen that among all the test results, there are instances where the measured horsepower was not in precise agreement with the rated horsepower. To make his argument 'bone has carefully selected his data. To defeat 'bone's argument, one has only to select some different data.
I will also observe that the EPA has no particular self-interest in fudging the data, and, indeed, the EPA has a great deal of self-interest in being neutral, scientific, and fair in reporting the data. The outcome of emission testing can affect millions and millions of dollars of commerce in the United States. Therefore, it seems reasonable to assume the EPA conducts itself in a professional manner. In any case, it seems reasonable to require someone who wants to throw out their data as meaningless, as 'bone suggests, to offer something in the way of substantiation of his accusations.
I notice that my challenge to 'bone for an alternative and more reliable source of information about horsepower has gone unanswered. From that silence I infer there is no alternative source. Let me help out 'bone a bit. I will suggest some alternative sources. Perhaps we should trust what we read on websites. Perhaps ScreamAndFly or TheHullTruth are the real source of horsepower information, and what is posted there should be considered as more accurate than anything the EPA puts out.
Peter posted 11-01-2010 07:51 AM ET (US)     Profile for Peter  Send Email to Peter
The data in the spreadsheet is the emissions certification data submitted by each of the manufacturers. The EPA may dyno a motor now and then but that is only for the purposes of determining whether the manufacturer is in compliance with the certification data that the manufacturer submitted.
The different output data for the Evinrude 300 appears to be related to different test cycles. One is identified as a "5-Mode" the other as "Discrete Modal".
I think the last thing we want is a government agency running the only dyno shop allowed for emissions reporting.
captbone posted 11-01-2010 08:03 AM ET (US)     Profile for captbone  Send Email to captbone
JimmyH can keep dancing around the situation but he wont admit that the has no clue if the EPA is dynoing these engines,getting engine specifics from the manufacturer or just using a test wheel/cut down prop in a test tank.
How can you put so much stock into information that you have no idea about what it means/hows its collected/where it comes from?
I will restate my ORGINAL post to this topic
"I dont put any value in those EPA KW values.
The EPA would be a great source for the actually HP of these engines but there are too many variable that we must know before we conclude that these are the max hp produced on a water dyno. I surmise that these are values provided for emissions testing from the manufacturer."
There is no real good source of information for actual outboard engine HP (I never stated there was???). The fact still remains that no one here is certain that EPA is in fact dynoing all of these engines or just using a test wheel/cut down prop in a test tank.
jimh posted 11-01-2010 08:09 AM ET (US)     Profile for jimh  Send Email to jimh
'boney says I am dancing. Actually, I am not. When I dance I do so with great style and passion. Here I am just speaking logically and in a calm tone of voice.
'boney keeps insisting I have to prove something to him. I do not feel the obligation. As I said, 'boney and the EPA will have to work out their differences. I don't have any problems with the test data. I don't have any "bone to pick" with the EPA--and isn't that a nice figure of speech?
captbone posted 11-01-2010 08:13 AM ET (US)     Profile for captbone  Send Email to captbone
Keep dancing
What do you think about Peter's post?
face posted 11-01-2010 09:32 AM ET (US)     Profile for face  Send Email to face
Jim is usually more scientific in the sense that he wants confirmed primary source information. I agree with Bone:
Do we know where they get the values or if they are dynoing these engines while testing? "
and would like to know where the data is coming from. I'm not sayin the values are false but where are they coming from?
While we're on the figure of speach topic, I think Jimmy has his feathers ruffled here.
Joe (and feel free to call me Joey, my friends do)
Tohsgib posted 11-01-2010 10:21 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Why does'nt somebody ask the EPA and shut the hell up already?
jimh posted 11-01-2010 11:23 AM ET (US)     Profile for jimh  Send Email to jimh
facey says
quote:
"While we're on the figure of speach topic, I think Jimmy has his feathers ruffled here."
I don't see anything particularly avian about "jimh." I think you missed the point of my figure of speech.
face posted 11-01-2010 11:38 AM ET (US)     Profile for face  Send Email to face
Touche Jim, and my feelings are hurt by "facey". In all seriousness would be nice to know where this data comes from. You don't usually accept information just because you were told so.
jimh posted 11-01-2010 11:42 AM ET (US)     Profile for jimh  Send Email to jimh
It is not necessary for me "to have a clue" about whether or not the EPA has individually tested every outboard motor made in the last ten years on their own equipment. I simply said I find the EPA published data to be useful in determining horsepower.
'boney has constructed a new hurdle and keeps insisting I must jump over it, that is, he insists I must have personal knowledge of how the EPA has tested every engine it lists in its EPA test data file. Simply because 'boney insists on this does not mean I must satisfy his arbitrary demand.
It has been suggested that someone ought to obtain information under the Freedom of Information act. That is a great idea. Let someone do it. (By the way, to get the information you have to pay for the reasonable cost of the government to gather the information; they do not do it for free.)
In reply, I have asked 'boney to cite an alternative source of horsepower information, if he wished to discard the EPA data. This is not a particularly onerous task, and yet he keeps declining to cite an alternative source.
'boney now wants to have my comments on Peter's article re EPA test data. My response:
My understanding of the process is the same as Peter's. I would not be surprised if there isn't some independent laboratory that specializes in testing for this data and manufacturers hire them to test. I am not overly concerned with the details of the process. The EPA says an engine is certified for a particular emission level compliance. They base it on the test data submitted.
'boney sounds like a defense lawyer who wants to attack the credibility of the laboratory that tested his client's blood-alcohol level. You can knit-pick this sort of thing, if you want.
What is the conclusion we are to reach if we accept 'boney's basically unfounded assertion that the EPA data has no meaning. Does that mean the entire notion of the EPA regulating emission is meaningless? Where is this going?
jimh posted 11-01-2010 11:43 AM ET (US)     Profile for jimh  Send Email to jimh
[Oops--posted twice. Deleted duplicate.]
captbone posted 11-01-2010 12:18 PM ET (US)     Profile for captbone  Send Email to captbone
JimmyH
I give up
I have made my points and anyone reading this can realize that you have no idea what those KW numbers mean, where they come from, if they are peak HP or if they are just given to the EPA by the manufacturer.
My question stands from my very first post on this thread
Please continue to quote information from the EPA when you dont have any clue what it means.
Thank you for listening to me rant everyone.
jimh posted 11-01-2010 01:01 PM ET (US)     Profile for jimh  Send Email to jimh
I stated quite clearly where I think the test data comes from. Anyone who can read understands where I think the test data comes from. It comes from the EPA, for goodness sake.
L H G posted 11-01-2010 05:02 PM ET (US)     Profile for L H G
Jim - you may be in over your head in this one. I would let it go. I had the pleasure of meeting "captbone" while out on the water one day, and without revealing his identity (per his request), suffice it to say that I would consider him a credible source of information.
jimh posted 11-01-2010 05:17 PM ET (US)     Profile for jimh  Send Email to jimh
I am not over my head--I am not even wading in the water. In case you haven't noticed, I am not the public information officer of the EPA. I simply mentioned that a source of information on engine power is available from the published EPA test results. Here is exactly what I said:
quote:
"I would rely on the certified test data from Evinrude that was used for the EPA testing."
It is entirely arbitrary that 'boney insists I provide evidence to him about the EPA data, that I have first-hand knowledge of every test, and that I authenticate the data to his standard. Look--the data is authenticated to the EPA's standard, and that is good enough to determine whether or not the engine can be sold in the U.S. When did 'boney become more important than the federal government?
If 'boney wants to go toe-to-toe with the EPA, he can be my guest.
As for L H G attesting to the authority of ol' 'boney, about all I can conclude from that is when Larry met him he had a Mercury motor on his transom. If any other motor was on that transom, Larry wouldn't be vouching for him.
jharrell posted 11-01-2010 07:18 PM ET (US)     Profile for jharrell
Maybe we can all pitch in a purchase one of these: http://www.land-and-sea.com/prop-shaft-dyno/marine-dyno.htm
Imagine the arguments put to rest across the internet if we actually had real dyno results for various outboards.
Imagine the traffic this site would get, if it had a library of outboard hp and torque curves to reference.
The outboard market is in dire need of real unbiased motor reviews and comparisons with dyno results.
Tom W Clark posted 11-02-2010 01:37 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Boy, I leave town for a few days and expect you guys to have this all sorted out but now there is more confusion now than before!
We are, of course, completely off-topic as the question posed was a simple one and the answer is: The E-TEC 90 (and all other outboards made since the mid 1980s) are rated at the propeller shaft, not the powerhead.
But let me throw some more logs on the fire:
The EPA data that I have pointed to above is very interesting and somewhat confusing. I noted that the E-TEC 300 is shown putting out only 276 HP but dgoodhue correctly points out that the E-TEC 300 is also shown putting out 296 HP, so I may have been wrong in my interpretation.
It should be noted that the E-TEC 300 tested is the same motor, not the same model of motor but the same motor as shown by it serial number. The variation of power output corresponds to the test cycle which is listed as "5-Mode" for the higher power output and "Discrete Modal" for the lower power output.
The test cycle refers to very specific controlled methods of measuring the emissions of the motors.
The EPA is not testing these motors, the manufactures are, but they are doing so in very particular ways outlined in this original EPA document:
http://www.epa.gov/EPA-AIR/1996/September/Day-19/pr-23668DIR/Other/ maine.txt.html
They most certainly are NOT just making up data as captbone may be suggesting nor are the power outputs exactly the same as the decals of the motors being tested. Here are a few examples:
Evinrude E-TEC 300 -- 296.96 HP
Yamaha F225 -- 208.39 HP
Yamaha HPDI 300 -- 276.52 HP
Mercury OptiMax 225 -- 221.94HP
Mercury Verado 250 -- 246.61 HP
Suzuki DF200 -- 197.26
Tom W Clark posted 11-02-2010 01:48 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I need to correct something I posted last week. [ Nick - You were right. ]
The old Yamaha two stroke 90 is shown to put out 83.3 HP.
The F90 (four stroke) is shown to put out 91.32 HP.
