posted 11-02-2010 07:53 AM ET (US)
A fairly accurate estimate of fuel consumption for classic two-cycle motors is as follows:At rated horsepower, they will burn the rated horsepower divided by ten gallons per hour.
For a 30-HP engine, this implies 3-GPH. At lower throttle settings, the rate will be proportionally lower. At a nominal cruising speed, we could estimate the engine power will be about two-thirds maximum, and the fuel consumption rate will be in proportion; for your engine that would be about 2-GPH.
The rate of fuel burn is based on the Brake Specific Fuel Consumption (BSFC) of the engine. For a classic two-cycle engine we use a BSFC of 0.6-lbs/HP-hour. For gasoline fuel at 6.25-lbs/gallon, this implies a fuel rate of
0.6-lbs/HP-hour x 1-gallon/6.25-lbs = 0.096-lbs/HP-hour
For 20-HP (cruising speed) this means a fuel rate of
0.6-lbs/HP-hour x 1-gallon/6.25-lbs x 30-HP = 1.92-gallon/hour
