Topic: 15 Whaler - Yamaha F60 Propeller
mkelly |
posted 02-28-2013 10:20 PM ET (US)
You guys all seem to be very savy with properly "propping" a certain boat & motor. I have a 1986 15' Whaler recently repowered with a new four stroke Yamaha 60. It came with a stock aluminum prop & turns a bit over 6,000 rpm wide open, maybe a bit too much? Anyway, we need to go stainless
zotcha
posted 03-01-2013 01:10 PM ET (US)
Contact Member Tom W Clark, he is THE man! I'm running a Turbo Hot Shot 13.25 X 15? I believe. Never hits the rev limitor. Unless he's got something new up his sleeve. zot. |
mkelly
posted 03-01-2013 04:10 PM ET (US)
Is there a way to contact people direct? |
tedious
posted 03-02-2013 09:40 AM ET (US)
Do a search using "F60 AND 15 AND prop" and you'll get lots of results, including this from Tom Clark:10-1/2" x 15" Stiletto Triad 3.5, part # C 802315 with a C-014 Guardian hub kit. Tim |
Tom W Clark
posted 03-02-2013 12:19 PM ET (US)
15" pitch is a little tall, but zotcha seems to make it work. Correct me if I am wrong, but his motor is on a jackplate and his boat tuned for top speed.For general purpose work, I would probably use the 10-1/2" x 14" size. It doesn't matter you select the Yamaha Performance Series 3-Blade, the Turbo Hot Shot or the Stiletto Triad, they are all the same propeller. If you tow water skiers and tubes a lot, the Yamaha Pontoon Performance Series (a.k.a. Turbo Pontoon 1, Stiletto Star) might be the way to go. |
mkelly
posted 03-02-2013 02:04 PM ET (US)
No jack plate but willing of course to move it up or down, thanks for the info, looks to be clear |
tedious
posted 03-02-2013 02:50 PM ET (US)
Not to be pushy, but because I hate to see people spend money they don't have to, you should be looking to pay around $200 or a little more for the prop and hubkit at an online retailer.Tim |
zotcha
posted 03-03-2013 02:34 PM ET (US)
Yes I am running a jack plate and most happy with my performance, but I do not pull anything other than baits and an occasional stranded boat. zot.As far as price goes, shop yourself nuts, than contact Tom W Clark. |
