  1989 18 Outrage, E-TEC 150
Author Topic:   1989 18 Outrage, E-TEC 150
Beaux posted 07-17-2013 12:43 PM ET (US)   Profile for Beaux
I am currently having a new E-TEC 150 installed on a 1989 Boston Whaler Outrage 18, a stock boat with two batteries and stock 63-gallon tank. Got a decent deal as the E-TEC is actually a 2013 150-HP model and is counter rotating 25-inch shaft length. Installation is part of an Evinrude special where stainless steel propeller, rigging, and gauges are included. The dealer is to perform water testing and propeller selection.
Are there choices of propeller brands that would be offered and covered under this rigging special by Evinrude? If so, preferences by the gurus as to what might work best on this combination.
I have read many of the threads on here and understand what to look for concerning anti-ventilation plate level on plane as well as WOT engine speed. Main use will be fishing in Gulf running at fuel efficient plane. I would like good out of the hole performances to get on plane as I fish in skinny water a good bit.
Any educated guesses and preferences on likely propeller and setting? Thanks
Whalrman posted 07-17-2013 01:22 PM ET (US)     Profile for Whalrman  Send Email to Whalrman
Mount engine all the way up, three holes above the bolts. I ran a Viper 17 and did well above 3500. At 2800 or below in rough water would "fall off" plane easy. One battery and 1.8 gal oil tank in the stern as well as the bench seat.
ratherwhalering posted 07-17-2013 05:52 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
I would personally try the Viper TBX 14 3/4” x 19”, based on the article below and my experience that the Stilettos tend to run about 2-inches less than the SST/Viper with similar performance.
http://continuouswave.com/ubb/Forum4/HTML/004957.html
see also:
http://continuouswave.com/whaler/reference/graphics/propellerTestGraphs/ Propeller_SST_vs_Stilleto.png
--Rob--
Beaux posted 07-17-2013 07:42 PM ET (US)     Profile for Beaux
Thanks for replies. I just went by dealer. It's ready. They put a viper 17 on it. Sea trial tomorrow. My old 150 would get me in plane at about 2400rpm. I will check it tomorrow. Thanks
Here are pics of setup :
LINK
Peter posted 07-17-2013 08:31 PM ET (US)     Profile for Peter  Send Email to Peter
Try a Rebel, too. The Viper is not a very efficient propeller at cruising speed.
Peter posted 07-17-2013 08:40 PM ET (US)     Profile for Peter  Send Email to Peter
Also, motor should be raised up one hole.
Qtrmeg posted 07-18-2013 08:09 AM ET (US)     Profile for Qtrmeg  Send Email to Qtrmeg
In the third picture it looks like that engine has been installed in every hole but 2 holes up. Why is that, was this engine installed on another boat?
jimh posted 07-18-2013 10:27 AM ET (US)     Profile for jimh  Send Email to jimh
From the images you provide the present mounting height is one-hole-up. That is a good place to start, but you might find even higher mounting to be advantageous.
On a very seat-of-the-pants approach, I would think a 19-pitch might be workable with your boat and engine.
Regarding brands of propeller available in the promotion, I would suspect that only Evinrude branded propellers would be included. The best source of reliable information about the details of the Evinrude promotion is from Evinrude.
jimh posted 07-18-2013 10:33 AM ET (US)     Profile for jimh  Send Email to jimh
Since the engine is a counter-rotating model, you will be limited to left-hand propellers. The range of models and pitches available may not be as extensive as with right-hand propellers. If you want to get good acceleration, good fuel economy, and run on plane at moderate speeds, try a REBEL model propeller. The REBEL has a lot of blade area, so you might try the 17-pitch.
My impression of the VIPER propeller and its application is that use is intended for high-speed and lightweight boats.
ratherwhalering posted 07-18-2013 01:26 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
I agree with Peter, with a higher performance propeller like the Viper, which also has a modest amount of cupping, you can raise the engine without excess ventilation and decrease lower unit drag. If you were trying the SSP, then the mounting height would be about right. I'm very interested in this thread, please follow up with some performance numbers!
ratherwhalering posted 07-18-2013 01:33 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
Depending on what you are looking for, the model of propeller is a consideration. Speed vs. cruising use:
quote:
ViperTM - Runabouts and General Recreation. If you want speed, you want the ViperTM prop. It's longer swept blades and a larger diameter give this prop a better grip on the water, faster acceleration, and greater top end speed. Excellent on any recreational boat, from runabouts and cruisers to deck boats.
--Versatile 3-blade performance
--Custom high luster finish
--Balance of speed and durability
--V4 & V6 engines
quote:
RebelTM - Offshore and Cruising
The RebelTM propeller is designed and engineered to deliver improved midrange cruising and top end performance on V6 Evinrude® E-TEC®. Large diameter and efficient blade contour provide faster speeds at lower RPMs to deliver significant improvement in fuel economy. Your customers will get more miles to the gallon and a longer cruising range. Standard rotation and counter rotation models are available from 15 to 25 inch pitch. Use the RebelTM propeller on offshore boats, large runabouts, and even large pontoon boats to make them perform to their maximum potential.
--High polish stainless steel
--Designed and engineered for efficient midrange cruising
--Improved fuel economy with longer cruising range
--Use on offshore boats, large runabout, and pontoon boats.
Beaux posted 07-18-2013 05:12 PM ET (US)     Profile for Beaux
My old 1996 evin 150 motor was mounted all the way down. I never even tried to adjust it when I bought it. It was setup by previous owner. Originally, my etec dealer mounted new etec to the similar setting I had on the boat. He then tested it and quickly changed and settled on where it is in pic after running the boat.
As to motor, it was brand new. It was in the showroom on display. I have the printout during his setup dated yesterday for warranty. Printout Shows zero hours runtime. I'll try and scan when I get home.
Dealer really recommends viper prop for my setup. I talked with him about what i want and my useage patterns a good bit today over the phone and at the weather shortened test run. I ran it briefly with a viper 17 today but weather prevented a good long trial. It really ran well with the viper 17 on it. Of course, I'm a novice and admit to also being in the "just happy to have a repower on my baby" mindset.
After discussing with dealer about advantages and disadvantages with each( viper vs rebel) prop and my boat weight/setup ... I told him I would take his recommendation. As a novice and laymen, it's hard to go against a professional when he did make excellent points. Haha. This was not a waste of time for me, and I hope nobody that gave an opinion feels that way. I am very comfortable knowing options and the decision was made as informed customer. Thanks
I truly believe I will be happy with the boat as it sits... As I am smiling typing this just waiting to finish my last patient and go run her a little after work.
seahorse posted 07-18-2013 05:38 PM ET (US)     Profile for seahorse  Send Email to seahorse
What was your top rpm and speed with the 17" Viper prop?
You mentioned that the weather wasn't the nicest, but did you get a full throttle reading by chance?
L H G posted 07-18-2013 05:57 PM ET (US)     Profile for L H G
A 150 with 1.87 gearing on an Outrage 18 generally requires a 19" prop.
Beaux posted 07-18-2013 06:02 PM ET (US)     Profile for Beaux
I was in a bayou so reaching top speed was not something I was comfortable doing. Seriously. Haha
I did quickly run it up to @5200 a few times with what seemed to be PLENTY left to go . I just wasn't comfortable running in tight waterways with sharp bends to allow myself to run it any harder.
I was able to drop it down to my normal cruising range rpm ( 2900-3200) without dropping off plane. The lack of ability to run smoothly in that lower range was my main concern with VIPER propeller after reading opinions. My boat seemed to ride fine. Of course, I haven't been in open water/waves yet in that scenario.
I will get the max engine speed and boat speed numbers for you when I get it onto back bay.
Peter posted 07-18-2013 06:10 PM ET (US)     Profile for Peter  Send Email to Peter
"A 150 with 1.87 gearing on an Outrage 18 generally requires a 19" prop."
This is true for a motor with a 5500 RPM maximum. The E-TEC 150 has a 6000 RPM maximum so that rule doesn't apply.
Whalrman posted 07-18-2013 08:23 PM ET (US)     Profile for Whalrman  Send Email to Whalrman
Glad you got to check her out for a little run. I think you will enjoy the set-up for a long time to come. Good choice in power and hull. Tight lines in the Bayou.
seahorse posted 07-18-2013 09:15 PM ET (US)     Profile for seahorse  Send Email to seahorse
There are no model years anymore for Evinrudes, just like Yamahas and Mercs. Everything is by model number.
What are the last 3 letters in the model number sequence on the serial number plate?
Beaux posted 07-22-2013 12:44 PM ET (US)     Profile for Beaux
Model : E150DCXAA
Serial #: 05361707
Beaux posted 07-22-2013 12:47 PM ET (US)     Profile for Beaux
Sorry for late reply... I've been offshore hunting tuna in a friends big boat. Hopefully can get the live well off the back today and put her in the water early this week.
Beaux posted 07-24-2013 09:39 AM ET (US)     Profile for Beaux
Ran the boat yesterday... A few notes:
1- as recommended, the motor needs to come up at least one more hole position on the transom. The cav plate was underwater even at high rpm and trimmed out.
2. With 60 gallons fuel, full ice chest, fishing gear, and 500 lbs of people on board... Boat topped out at 46.2 mph with analog tach showing 5600rpm
Whalrman posted 07-24-2013 10:54 AM ET (US)     Profile for Whalrman  Send Email to Whalrman
The E-TEC 150 is an awesome engine as you are finding out! Raise the engine when you get the chance and reseal the bolts after wards.
ratherwhalering posted 07-24-2013 05:21 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
With a light load and corrected engine height, you'll probably be just under the 6000 RPM maximum. Perfect if you usually have more weight and don't typically run WFO throttle. Good to know :-)
Beaux posted 07-27-2013 11:08 PM ET (US)     Profile for Beaux
I ran her today. I had 3/4 tank of fuel, 2 kids (70lbs each) and two adults ( 300 lbs total).
I didn't run WOT, but I ran several longer runs at constant rpm settings. System check tach and Garmin [chart plotter with a GPS receiver] for speed. Long straight runs to decrease [error from the point-track method of speed deduced by the GPS receiver] and on calm water with no wind. I trimmed out differently each run trying to maximize efficiency but I tend to be conservative on the trim.
3000 rpm 21.4 mph.
3000 rpm 21.5 mph
3500 rpm 28.3 mph
3500 rpm 28.8 mph
3500 rpm 29.1 mph
4000 rpm 33.0 mph
4000 rpm 33.3 mph
4500 rpm 37.9 mph
4500 rpm 38.1 mph
4500 rpm 38.2 mph
I took picture of lower in water at 3500 rpm. As one can see, it can definitely be raised.
http://i1363.photobucket.com/albums/r711/Jbeaux2000/image.jpg
Tom W Clark posted 07-28-2013 12:53 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Yep, the advice offered at the top should have been taken: Mount the motor all the way up (two holes higher than it is now).
The optimal WOT engine speed range for the E-TEC 150 is 5500-5600 RPM. You will need to exchange the 17" Viper for an 18" or 19" model to achieve this.
RobertRibley posted 08-01-2013 09:51 PM ET (US)     Profile for RobertRibley  Send Email to RobertRibley
On my Outrage 18, when I had the stock Evinrude 175, I tried many different prop combinations. Of course my use may be a little different, but I also wanted it to get on plane quickly, have a low planing speed and get as much hole shot as I could out of it. We use it a lot for skiing. Also a concern was sharp turns at the end of the ski course. What I found that worked best, and I worked with Tom Clark on this, was a Stiletto 15 Advantage. I also run a Cobra Edge Pro stainless steel stabilizing plate. Engine height is three holes up. I can plane as slow as 17 mph with a light load with no blow out on turns. Then I did a repower to a Yamaha F150 and had to drop a hole on the motor but used the same prop with excellent performance. We had to machine out the prop to fit the four stroke, but achieved the same results with the same prop. The two stroke seemed like they could run a hole higher. Here is a picture of my 15 on a 5" set back running all the way up which provides great performance and economy.
http://i215.photobucket.com/albums/cc249/RobertRibley/ Outragecenterconsole014_zps98b8060a.jpg
This is running at 3000 rpm and planing. It would be hard to drill holes in a new motor but it's something to think about.
Good luck,
Robert
stefan posted 08-09-2013 11:09 PM ET (US)     Profile for stefan  Send Email to stefan
2 holes up, 19 rebel prop.
Perfect for my 1982 18, with 2006 etec 150
Man i miss that boat.
Beaux posted 09-11-2013 07:45 PM ET (US)     Profile for Beaux
I've got a lot more use out of my baby since this thread was started. I decided to tinker a little with prop options. Just got a new Rebel 17-pitch. I still haven't raised motor up. I still have two holes I can go. I'm going to get really accurate data with my 17 VIPER. Then put on REBEL and see what [the boat] can do.
My data will be better as I have a [NMEA] 2000 network with E-TEC and Garmin 547xs. I can now see extremely accurate speed, 10hz-update, digital RPM, GPH, MPG, and exact throttle position by percent. I will post results when I get the data. Then I'll try to get to raising E-TEC one hole higher.
jimh posted 09-12-2013 01:09 AM ET (US)     Profile for jimh  Send Email to jimh
I am not sure your GPS receiver deduced speed is going to be more accurate. A GPS receiver deduces speed from the point-track method. I don't know that calculating the speed more frequently makes it more accurate. [I have made that topic the topic of another discussion] Speed as deduced from a GPS receiver is reasonably accurate for propeller comparisons, especially when made at almost the same time, same place, same conditions.
prj posted 10-29-2013 04:37 PM ET (US)     Profile for prj  Send Email to prj
Evening Beaux.
Any updated performance data for your rig with the new props?
Beaux posted 10-30-2013 12:50 PM ET (US)     Profile for Beaux
I have been using her a good bit, but haven't gotten around to running for numbers and then changing props. What little time I have had, I fished in. The marsh. I had her in heavy seas coming back the other weekend and must say it was nice knowing my etec would not let me down.
I will definitely record the numbers/data for everyone and also do the same with the rebel 17p prop. Thanks for reminder....
With hunting season work days and two kids in travel soccer, boat time is limited on the weekend..haha. When I get some, I fish.
prj posted 10-30-2013 01:03 PM ET (US)     Profile for prj  Send Email to prj
Thanks for the follow up Beaux, and indeed, use the time available wisely. When you do get the opportunity, we look forward to seeing the results of the testing.
Patrick
