| Author | Topic: 15-Footer Performance |
| elvis |
Hi all. I completed the restoration on my 1985 Boston Whaler 15-foot boat. I bought it at a government auction. I found a great deal on a motor: a 1988 Mercury 70 in good condition with trim and tilt. What top speed can I expect [from a Boston Whaler 15-footer with a 70-HO outboard engine]? The outboard engine has the original factory propeller. My buddy has the same year and size Whaler with a Johnson 50-HP; it runs about 32-MPH. I plan to buy the 70-HP today. Thanks! |
| wannabe |
My friend had a 15 footer with a [70-HP; that boat went] around 40-MPH. It feels faster sitting so close to the water.--Drew |
[Moved to PERFORMANCE] |
Please look at the REFERENCE section article on the Boston Whaler 15-footer. The article has a table of estimated speeds for different engine horsepower which was published by the factory. Below is a hyperlink to the beginning article of a series of five articles in the REFERENCE section on the 15-foot boat: |
Also be sure to read the article on testimonials to the 15-footer; that article contains a great deal of commentary about boat speed and horsepower: http://continuouswave.com/whaler/reference/15/testimonials.html |
| dgoodhue |
42-45mph with motor mounted 2-3 holes up on the transom with a proper SS prop. Some of the testimonies in the link above are using speeds from pilot tube speedometers (those speedos are known to be inaccurate.) I have a hard time believing any 70hp motor would do more than 45 mph without a jack plate. |
| Peter |
I had a 15 Super Sport with a Yamaha 70 2-stroke mounted as low as it could go on the transom. The Yamaha 70 turned a 3-blade Yamaha aluminum 13 x 19 propeller. With me and a single tank of fuel I consistantly saw 42 MPH and sometimes 43 MPH on the GPS. Prior to the Yamaha 70 I had a Johnson 48 SPL on that boat and it would get to 37 MPH under same load. |
| elvis |
Awesome info. Thank you. |
