| Author | Topic: Four-stroke-power-cycle Engine Performance, Maintenance, Fuel Consumption |
| elvis |
Hi all, I'm restoring and refitting my GUARDIAN 18, and currently it has an older, 2002 Evinrude 200-HP, which runs well and was rebuilt. But I like having new stuff to start with, so am planning to sell and re-power with a new outboard engine. I love the old tried and true two-stroke-power-cycle outboard engines of years past. My last new re-power and purchase was in 1996 when I refitted an OUTRAGE 18 with a new Johnson 150--a real screamer. Among today's engines I am thinking [of buying] maybe a Honda 200 to 225-HP or an E-TEC. Weight is about 100-lbs more for the Honda, and it looks like it costs a few thousand more. But I hear that fuel consumption is much less on the four-stroke-power-cycle outboard engine. If so, how much difference between an E-TEC [and a Honda], for example? What about [acceleration of the boat from a standing start to plane], performance, and maintenance costs? Has anyone run these numbers already or have experience? I'm in the Augusta, Georgia, area, so plenty of motor dealers to choose from. I just wondered what some of you thought. Thanks much. |
| Peter |
Besides being enormous in size and far out of proportion for the 18 Guardian, the Honda 200 or 225 is TOO HEAVY. If you really need 200 HP on the transom, the best fit for the 18 Guardian is an Evinrude E-TEC 200 built on the 60 degree V6 block. It's nearly 200 lbs lighter than a Honda BF 200. |
BOATING magazine recently made a comparison of the operating and maintenance cost of running a number of outboard engines for the same amount of time. The comparison included the E-TEC and all the popular four-stroke-power-cycle outboard engines. The E-TEC was the least expensive to maintain and operate. You may find that article to be interesting. I think the entire article is now on-line at http://www.boatingmag.com/engines/outboards/ boatinglab-tests-outboard-ownership-costs? That article was also the topic of a prior discussion here, and a summary of the costs was given. See http://continuouswave.com/ubb/Forum1/HTML/022342.html Regarding the fuel economy of any outboard engine, the most reasonable basis for comparison is to use the ICOMIA duty cycle to determine the engine usage. The ICOMIA duty cycle is based on a survey of usage of outboard engines by boaters, and operates the engine at a range of speeds. This gives a good comparison of the overall fuel economy. I think it is a better comparison that the usual ones we see presented. Often one sees a particular engine load and engine speed selected as a point of comparison, usually a load and speed in which one particular engine seems more efficient than another. This single data point is then pulled out and highlighted, giving the implication that a certain engine is significantly more fuel efficient than another. I don't think you will find an enormous difference in the fuel economy of modern engines. That said, however, the naturally aspirated, lean-burn Honda engines do seem to have a small edge in fuel economy, which I attribute to the decades of experience that Honda has gained in production of engines for automobiles, where fuel economy is perhaps of the greatest concern. One must consider the effect of fuel economy on overall costs. In order to obtain a significant cost savings, one has to buy and use a lot of gasoline, and the price of gasoline has to be rather high. If you live in Ireland and pay $9-per-gallon for gasoline, and you operate your boat daily and consume 25-gallons per day, then having marginally better fuel economy may produce some cost savings. If you are buying gasoline for less than $4-per-gallon and only operate the boat for 50-hours per year, the opportunity to save costs by using slightly less fuel is greatly diminished. The trade-off with all of the four-stroke-power-cycle engines compared to the E-TEC is the necessity of performing oil changes and other required maintenance. That subject has been debated for years. It is my observation that there has been a rationalization by the fans of the four-stroke engines which has caused the drudgery of changing the lubricating oil, the oil filter, and disposing of the used oil to be reduced to a non-concern. The E-TEC will eliminate this often messy task of changing lubricating oil in the engine sump. Regarding performance, the E-TEC will typically be better. It will be lighter and produce a wider range of power. The gap is narrowing, and modern four-stroke-power-cycle engines are becoming less heavy. Their power output is improving, too. My general advice regarding buying a new outboard is to select the engine with considerable weight given to the dealer from whom you will buy it and to whom you will go in the future for support. |
Regarding the possibility of saving money on boat operation through improved fuel economy, let me cite myself as an example. From data over the last four years, I can estimate that my engine burns about 3.75-GPH on average. I operate the engine for about 60-hours per year. Gasoline costs average about $4/gallon. This suggests that my annual fuel expense will be: 3.75-gallons/1-hour x 60-hours x $4/gallon = $900 If I could change to a different engine and it would improve my fuel economy by ten percent, then I would be able to save perhaps $90 per year. Compared to the total cost of owning and operating my boat, a cost savings of $90 is actually rather insignificant. I have a very special relationship with my present outboard engine dealer. The dealer provides me with world-class-best service and support. I would never give up that support for the notion that I could save $90 per year in fuel cost by buying a different brand from a differnet dealer. |
| elvis |
Wow, great and helpful info and links, Jim...many thanks. I think your example of operating savings needed to recoup price differences is an excellent point. My previous 18 outrage had a 1996 150 Johnson (about 400 pounds weight) which was plenty of juice, but this guardian weighs in (according to what Chuck Bennett sent me) about 500 pounds extra....1250 vs 1750 pounds. That said, the 200 Rude that's on it IS tall...looks huge, out of proportion, true that...actually. Runs fast enough to make your eyes water, I didn't GPS it when I tested and purchased last month, I would estimate in the 40s, speed wise. Has viper prop. Weight-wise, I've been told it's around 514 pounds, hull seems to handle it fine. I went back and looked at specs on the Evinrude website..New E-tec 225 is around 524 pounds, and the 150, 175, and 200 are all around 420 pounds, indicative that if these 3 all weigh about the same, I'll probably go with the 200 unless the dealer gives me a great deal on another. Personally, I could probably get by with a new 150 on the guardian, but that extra juice of a 200 is nice...if I run the motor with some care and reserve, fuel differences are probably fairly insignificant in the bigger scheme of things. I sure do appreciate the feedback Jim, Peter...good info that makes one think. Thanks! |
| seahorse |
Here is an interesting observation by boattest.com about the 90hp E-TEC fuel economy compared to similar 4-stroke engines on pontoon boats. ==================== Observations Comparison Tests. We have tested 7 pontoon boats over the years with 90-hp 4-stroke engines. Interestingly, when we compared our 4-stroke test numbers from three different brands with the Evinrude 2-stroke numbers, the Evinrude 90s were more fuel-efficient at cruising speeds in five of the seven cases. These are by no means "apples-to-apples" tests and most were done several years ago. Nevertheless, these comparisons do indicate to us that the Evinrude E-TEC 90 Pontoon Series is competitive with 4-stroke 90-hp outboards in the 12 to 14 mph range -- where most of these boats are cruised when not towing -- in terms of fuel efficiency. |
| Don SSDD |
Guardians weigh more and are spec'd for more HP from factory than a "stock" hull. What is your Guardian spec'd for on the hull plate? A good friend has a 1996ish 24 Guaradian, ex-RCMP, twin 2 stroke 150 Johnsons. He contacted Brunswick about his boat, was told by them he was under powered for a 24 Guardian. His boat is quick up to speed, it has shown 50+ MPH on the speedo (which I know is not very accurate) in a 2-3 foot ocean sea. If he stayed with a 2 stroke, same weight, I don't think he needs any more HP. It is a great boat. Don |
| OMCrobert |
The Evinrude E-TEC 200-HP 2.6-liter V6 would be a great engine for that boat. Look at the 150-HP Honda if you are set on installing a four stroke Honda. |
| Peter |
The 2.4L 4-cylinder 4-stroke Honda 150 would be a large step backwards in terms of performance as compared to the 3.3L V6 DFI Evinrude 200 2-stroke that is on the transom now. The current motor is about 215 HP at the prop shaft. There would be a noticible difference in performance between the 2.6L E-TEC 150 and the Honda 150 on that boat. |
| elvis |
Don - there's no capacity plate on it. Whaler checked the serial number for me...brochure they sent me states the weight is 1750 pounds for the 18. It runs good with the 200 that's on it, and I could probably get good service out of it. But I really want all new stuff. I was told it had been rebuilt, and the hour meter shows 225 hours, which isn't bad, but I'm redoing the whole boat, so a new motor is my goal. I like the 200 E-Tec, leaning that direction. Thanks. |
| OMCrobert |
150hp should be more then enough power for most uses on an 18ft Outrage/Guardian. I would take a long look at how you normally use the boat vs just reinstalling another larger then normal outboard on an 18fter. |
| tedious |
Hi Elvis - your original post makes the assumption that 4-strokes get better mileage than 2-strokes. That's wrong, in the sense it's the wrong comparison to be making. Instead, you'd be better off comparing modern outboards with older technology - and no surprise, the modern outboards get better mileage. Modern outboards, either 4-stroke or direct-injected 2-strokes, are similar in terms of mileage, and both get much better mileage than the classic 2-strokes, particularly at trolling speeds. Modern outboards are also much quieter, less smelly, and are easier to start in all weather than the classics. Transitional 2-strokes such as the Mercury Optimax and Yamaha HPDI engines have improved mileage and driveability, but they are just as noisy and almost as smelly as the older engines. The good news is that you have a ton of choices, the more so because you don't have to live within the 150 horsepower maximum of the Outrage version. I agree that the E-TEC 200 looks very good, and the 150HO, now available in a 25" shaft, might also be worthy of consideration. If I was repowering an Outrage 18, limited to 150 HP, that's the way I'd go. Tim |
| Peter |
Elvis actually has a semi-modern 200 on the transom now. That 2002 Evinrude 200 is a DFI outboard which is very fuel efficient and powerful. The one thing it lacks is noise supression. |
| tedious |
Is that existing motor a FICHT? I was not clear on that - if so then yes, I'd expect darn good mileage. I also re-read that his existing motor tips the scales at 514 pounds - if he's OK with that weight, it really opens up the options, all the way to the E-TEC 250 HO if he wants to really go nuts. T. |
| Peter |
A 2002 Evinrude 200 is a 3.3L V6 FICHT. Fuel economy isn't going to get any better with any of the current offerings. |
| tedious |
Yes, exactly my point. Although we all know the FICHT story, from a fuel economy perspective I'd expect them to perform roughly equally to today's E-TEC. Elvis, run what you've got until it drops! Tim |
| mkelly |
I run a 2012 2.6L 200 HP E-TEC on my boat and love it. Boat weighs 2,800-lbs (dry) so yours should get up and go. Mine runs about 43- to 45-MPH. Pay extra attention to the propeller, as well as engine mounting height. You can invest in all the HP you want but if it's not mounted high enough or has a propeller that doesn't run in the optimum WOT range, then you're doing yourself a disservice. Optimum range for that motor is 5,600 - 5,850 RPM under normal load. Mount it maybe three holes up and give it a test. |
| elvis |
Hi all, yes, it's a Ficht RAM, where I read that by 2002 they had fixed the Ficht problems and Bombadier had labeled the engine RAM to signify a new beginning, so to speak. This 200 is mounted I believe 3 holes up as Mkelly suggested, and really has a lot of juice. When I purchased the rig last month, we ran it a few miles up and down the river as a test, and it made my eyes water, I d guess at least in the 40 mph range...has a viper prop, not sure what size. I did t Wally care much about the motor speed and all at the time, as long as it ran good...I wanted the boat (ugly but solid) as it has a dive door, something I'd never seen on an 18, and I absolutely love a dive door for snorkeling, diving, etc., and my dog will love it too... All weights pretty much equal in the E-Tec for 150, 175 and 200, I'd like to do the 200...I'm looking into pricing now to see if there are any deals in all of this Georgia and South Carolina sleet and ice! Thanks too, for the input obey Tedious about 4 stroke fuel consumption, you make a good point. I learn plenty from folks every time I read on this forum...I really appreciate the great feedback! |
| Peter |
The Bombardier built Ficht outboards (2002 and on) had a pretty good reputation. The most important thing to watch out for is clogging of the cooling line for the EMM. If you run in shallow water and you may pick up silt or mud, many times it will clog up the vapor separator which is in the EMM cooling circuit. You will discover this because the motor will revert to SAFE mode and not allow RPM to run above something like 1200 RPM. The EMM will store trouble code 25 when this happens. Usually sediment in the vapor separator can be dislodged using a nylon tie strap poked in the inlet and outlet a few times followed by low pressure flushing. The usual water flushing through the flush adaptor in the back of the motor will not dislodge the accumulated sediment in the vapor separator. That should be a good motor, far more than the boat needs, and I would just run it until it dies. |
| tedious |
Elvis, your post seems to have been molested by a spell checker. I do agree that people should obey me about fuel consumption, and everything else of course - but who's Wally? Sounds like a great boat - always liked the dive doors myself. Tim |
| elvis |
Thanks again for the helpful info. Sorry about the typos...it was early, and this darn iPad auto corrects and sometimes writes things it thinks I meant...I must keep a good eye on it. Will keep you posted as I progress on the motor sell, floor and console removal, and general fix up...I have many hours worth of work left to remove a lot of (cosmetic) ugly on an otherwise classy hull. |
Regarding the performance of four-stroke-power-cycle outboards as compared to two-stroke-power-cycle outboards, the performance will tend to be lacking. The four-stroke engines have typically used three methods to improve their performance: --forced air induction using supercharging, seen only on one engine family, Brunswick's Mercury-brand VERADO; --complications in the valve arrangements and timing, generally called cam phasing or variable valve timing, and enhancements to the intake and exhaust manifolds, all with a goal of improving the performance; and, --very large displacement without the types of performance enhancements mentioned above. The supercharging method actually forces the engine to make a great deal of extra power just to run the supercharger. For a supercharged engine to make, say, 250-HP, at the propeller shaft, the engine has to probably produce over 300-HP in order to run the supercharger and to overcome the gear loss. This generally leads to the supercharger engines have the worst fuel consumption of any engine. I believe the BOATING magazine test bore that out. The complex valve timing, intake and exhaust manifold method of enhancement requires a lot of added mechanical complexity. About ten years ago this was seen as something unusual and cutting edge, but, now, so many four-stroke-power-cycle engines in automobiles have this sort of technology the inclusion of it is seen as almost something normal or standard. For world-class engine makers like Honda, having complex cam phasing is nothing out of the ordinary. Use of electrically operated valves in the intake path to modify the tuning of the air path is also being done. Getting performance by using a large displacement engine is really technology from the 1930's, but it still works. In some four-stroke engine designs, you will find that very large displacement is being used to get a wide range of power output. The old saying, "there is no replacement for displacement," is really no longer true, but if you limit your four-stroke-power-cycle engine design to 1930's technology, it will be. |
Regarding the maintenance of four-stroke-power-cycle outboards as compared to two-stroke-power-cycle outboards, the maintenance will tend to be greater. On the most fundamental basis, the lubricating oil in the oil sump of a four-stroke outboard must be changed periodically, the oil filter must be changed at that same time, and the used oil and used oil filter must be disposed in a legal and proper manner. Also, most four-stroke engines have belt-driven accessories. The drive belts must be changed periodically. Some four-stroke engines have internal belts and chains that must be periodically checked and tensioned. Some four-stroke engines require periodic adjustment of the valve train components. All of these maintenance tasks are typically in addition to the normal outboard engine maintenance, and do not exist on most two-stroke-power-cycle outboard engines. |
Regarding the fuel consumption of four-stroke-power-cycle outboards as compared to two-stroke-power-cycle outboards, the fuel consumption will tend to be about the same, with perhaps some operating points favoring one type over the other. There is often confusion about the comparison of fuel consumption between the two types of engines because historically the two-stroke outboard engine was not particularly good on fuel economy, and there is a general trend to think that the four-stroke engine will be much better. The use of direct-injection fuel induction in the modern two-stroke outboard has caused a significant change for the better in its fuel consumption. It is now possible to see very comparable fuel consumption rates between two-stroke and four-stroke outboard engines. By careful selection of particular engine speeds and loads, it is possible to show that either type gets better fuel economy than the other. On a generalized and typical overall pattern of use, the consumption of fuel will likely be very close. |
| OMCrobert |
I dont think that many people would agree that large displacement modern four stroke outboards engine are 1930's technology. I think that most people who have seen under the hood of 4.0 liter Suzuki 250hp or 4.2 liter Yamaha SHO 250hp in person would agree that it shares very little in common with 1930s technology. |
OMCrobert--I agree with what you said. but your attempt to attribute what you are saying to be something I was saying is wrong. Let me help you understand what I said by saying it again and perhaps in a different way. In the 1930's the general method used to get more power from a four-stroke-power-cycle engine was to increase its displacement. When in 2014 you use that same method to get more power, you are using a 1930's method. There is nothing wrong with this method. It has been proven to work over the last 85-years. It is really an old-fashioned and proven way to get more power from an engine: increase its displacement. The only way I can see that my characterization could be wrong is for you to demonstrate that prior to 2014 no engines used larger displacement to create more power. I don't think that can be done, even by you, although I expect you may take a run at it for a while. I don't know if you are old enough to remember when American automobiles had engines with 500-cubic-inch or 8.1-liter displacement. Now car engines make plenty of power from engines of 122-cubic-inch or 2.0-liter. This has occurred because in the years between 1930 and 2014 the art of building an engine has advanced, and more power output can be obtained from less displacement. If in 2014 you buy a new engine and it uses no new technology like cam phasing, boosted fuel induction, electronically controlled tuning of intake or exhaust paths, and instead just uses a very large displacement to create its power, you are not getting 2014 technology. Another good sign of lagging technology is to not have direct injection. The modern two-stroke-power-cycles use direct-injection of fuel into the combustion chamber, but most of the four-stroke-power-cycle engines do not. Use of direct-injection technology is coming to automobile engines, such as the new AUDI engines, but so far the four-stroke outboards are not picking up on this new technology. Maybe in another 20-years they will. |
| jharrell |
Since gasoline direct injection was invented in 1902 and the crank case scavenged two-stroke in 1894, would it be fair to say the E-tec is 1900's technology? |
| Peter |
Direct injection is not coming to automobile engines, it is now widely used in automobile engines. The following major manufacturers use it: Audi (since at least as early as 2005) Toyota has mostly resisted using it claiming that it cannot justify the cost versus benefit. I think the same is probably true for 4-stroke outboard motors -- the cost probably does not outweigh the marginal benefit for a motor that gets a typical average use of 50 to 100 hours per year. Compare that to the typical automobile engine that runs 400 to 500 hours per year and to which the production volumes are orders of magnitude higher than outboard motors. In contrast, for the 2-stroke, the benefit of DFI is significant -- its the difference between the 2-stroke being extinct and alive and quite viable under the current emissions regulatory scheme. |
| Jefecinco |
I owned a sixties era Mercedes Benz 230SL. It had a direct injection gasoline engine. I was surprised to see that before buying the car. The fuel injection system looked very much like the ones in use by Caterpillar at the time. The gasoline was pressurized and metered by the in-line injection pump and injected by pop off valves in each combustion chamber. The valves (technically injectors) could be seen next to the spark plugs. The engine was very reliable and sweet running. I toured all over Italy and Europe with it in the mid-seventies. Butch |
| OMCrobert |
The old saying, "keep it simple," is really no longer true, but if you limit your two-stroke-power-cycle direct injection engine design to 1900's technology, it will be. |
Yes, the E-TEC is a two-stroke-power-cycle engine. If that dates to 1902, that is the epoch. Did you think the four-stroke-power-cycle was something invented in 2014? |
Peter--Many thanks for good data about the use of direct injection in four-stroke-power-cycle automobile engines. I guess in fields where there is really some innovation the product designers are moving toward this new technology. A friend of mine is driving an AUDI with a 2.0-liter engine. It has direct-injection, turbo-charged fuel induction, and (probably--I am not certain) cam phasing. |
The notion of keeping a device simple is fine with me. I don't think you can make a good argument for complexity unless there is a benefit from complexity. If two devices provide the same performance or outcome, I'll take the simpler device. I think OMCrobert has tried to make that argument by taking something I said and attempting to construct a parallel argument, with the notion that he is going to score points against me. Sorry, I am all in favor of simpler is better, as long as simpler gives you the same outcome. For example, consider three engines: --Engine One has a complex cam phasing arrangement for its valve train --Engine Two has fixed valve timing for its valve train --Engine Three has no valve train All three engines make the same power at the same fuel economy. Simpler is better. |
| OMCrobert |
The argument that I was making was to illustrate how comparing a modern large displacement outboard engine to 1930s technology is pure nonsense. |
Yes, your argument was pure nonsense. Please understand I never made your argument, you did. I simply pointed out that the notion that the power of an engine can be increased only by increasing its displacement was a 1930's method, and in 2014 there are newer methods of increasing the power output of an engine besides making its displacement different. If you want to argue with me you are going to to have to disagree with what I have said, not what you want me to have said. If you invent things for me to say and then argue against those things you invented, you have a lot better chance of winning the argument with yourself. If you want to disagree with what I said, you just have to demonstrate that no one thought of making an engine more powerful by increasing its displacement until c.2014. As I said, I don't think you can succeed in that argument. I did not really doubt that you would try, but I thought you'd do better than you have. |
| OMCrobert |
Your comment (attached below) is nonsense if I may say so with all due respect. "The old saying, "there is no replacement for displacement," is really no longer true, but if you limit your four-stroke-power-cycle engine design to 1930's technology, it will be." No modern four stroke outboard engine design shares any thing significant in common with 1930s technology. If you are going so far as to say the displacement/piston/rotating assembly is the engine design then you can go so far as to say that a DFI two cycle engine take its engineering from 1800s locomotive technology. Pure nonsense. |
I am sure that under the cowling of a really simple 2014 engine you will find technology that did not exist in 1930 or not in a form that could be used on an outboard engine, but that is not contrary to anything I said, What you will find under the cowling of some 2014 four-stroke-power-cycle outboard engines is the basic engine is similar to 1930's engines in that the only way to get more power has been to increase displacement. You see this in many of the early generation four-stroke-power-cycle outboards such as the Yamaha F225 of c.2002. That engine was about as plain-jane as you could get, and its performance suffered. Suzuki tended to improve performance by increasing the displacement. Their engines were larger displacement, but they still tended to suffer in performance. Suzuki has evolved, and their engines use other methods to enhance performance, although they still tend to use a high displacement to give them a head start. For a manufacturer to come out with a new engine in c.2014 that has none of the typical performance enhancements--see my listings above for what I consider performance enhancements--you have to face the fact that you are getting an engine with 1930's technology as its basic approach to generating power. As I said before, there is nothing intrinsically wrong with older technology, and making larger displacement does lead to more power as a general rule, but in 2014 that is not the only way to get more power. Again, if you want to disagree with me, just show me a four-stroke-power-cycle engine from the 1930's with complex cam phasing, electronically tuned input manifolds, and supercharging. I think you have some sort of strong personal interest in the Mercury 150-HP FOURSTROKE, and you want it, a very simple, very basic, large displacement outboard engine without supercharging, cam phasing, electronic tuned intakes, and all the other refinements, to be considered to be a modern engine, apparently on the basis that the handle of the oil sump gauge is painted yellow and there is a two-dimensional machine code decal. But when it is pointed out that this engine lacks all the refinements of modern engines and really is not much different than one from 1930 in its approach to enhancing power output, you declare the obvious to be "nonsense." You need to get out of this denial. I know you want to champion the Mercury 150-HP FOURSTOKE, but stick to the good things about it, and don't get upset that it has the same sophistication as a 1930 four-stroke. |
| OMCrobert |
You took the words right out of my mouth. You can not compare a modern four stroke outboard to 1930s technology. Please "show me a four-stroke-power-cycle engine from the 1930's with complex cam phasing, electronically tuned input manifolds." I edited out supercharging because that like any forced induction engine could warrant no increase in displacement and would not make sense in this argument since it is about making more power without it. I can see that this will just be another round and round discussion but I stick to my point that comparing a modern four stroke outboard engine to 1930s technology is nonsense. I feel your arguement and hidden tone is to put down four stroke technology since you own and operate a DFI two stroke. I digress, comparing a modern four stroke outboard engine to 1930s technology is nonsense. |
| jharrell |
quote: I never mentioned the invention date of the four-stroke, infact you are the one who brought up the epoch in which certain four-stroke technology was developed. Since you did, I thought it might be relevant to post when certain technology used in the E-Tec was invented to give perspective on your remarks. When you say quote: One could also say quote: Both statements are correct. |
I don't have any problem with your statement about the two-stroke engine. As a marine engine in an outboard configuration, the two-stroke-power-cycle engine has a very long and rich history of outstanding performance and durability. There is nothing to be ashamed about that. The E-TEC is an evolutionary improvement on the classic two-stroke outboard engine, using a lot of patented new technology and millions of transistors. But it is still, at its heart, a two-stroke outboard engine. That is why it has such great power over a wide range of engine speed, is light, simple, and durable. The E-TEC is an Evinrude, which was the first outboard engine and the brand that has introduced many of the major refinements in outboard engines over the past 100-years. It has, as one might say, good genes. |
OMCrobert:
quote: You should stick to that point and look for someone to argue with about it, because I am not arguing about that point and I am not making any claim that conflicts with that point. I already explained this once, so just go back a few posts are read it again. |
OMCrobert speculates about a hidden agenda of mine:
quote: There are two problems with this accusation. First, "arguement" is misspelled. But let's overlook that. Next, the agenda: there is an agenda here. The agenda is to get accurate information. As for what engine I own, I have to remind OMCrobert of the many times I have mentioned my theory of what engine to own: own the engine sold by the dealer with whom you feel most comfortable doing business and and with whom you can anticipate having a good long-term relationship. I happen to have the good fortune of finding a great dealer that is very local to me. That dealer has been in business at the same location for over 90-years. That dealer has been selling the same brand for 90-years. That dealer is a certified top-level "Platinum" service center for the brand. That dealer and its service department is held in the highest regard by engine brand maker. That dealer has won my confidence and my business. If that dealer sold 225-HP four-stroke-power-cycle outboards there would probably be one on the transom of my boat. However, all that said, I am very certain that I would not be very happy about changing the lubricating oil and the oil filter of a 225-HP four-stroke-power-cycle outboard on my boat on a cold October weekend as I prepared the engine for winter lay-up. That is accurate data. That is what the website tries to collect. |
