posted 02-22-2014 03:01 PM ET (US)
How on Earth did that motor get mounted so low? When the boat left the factory, the Mercury on it was mounted two holes up and was equipped with a 15-1/2" x 17" MIRAGE propeller if the motor were a 200 HP model.The Yamaha 200 two stroke shares very similar gear ratio and RPM range and would make use of the same propeller.
I would raise that motor at least two holes, and maybe even three (which would be a high as it can go) and use a 15-1/2" x 17" Mercury MIRAGEplus or Enertia propeller.
If you want a Yamaha branded prop try a 17" M Series, either Saltwater Series II, Reliance or Painted Stainless Steel models.
