  Variation in Fuel Consumption
Author Topic:   Variation in Fuel Consumption
jimh posted 03-08-2014 08:58 AM ET (US)   Profile for jimh   Send Email to jimh
It is often desired to know the fuel consumed by an engine at a particular horsepower output. By having the fuel consumed and the horsepower, one can calculated the efficiency of the engine at converting fuel to power, often called the brake specific fuel consumption or BSFC.
In another discussion, jharrell points out that variations exist in typical test data. I cited two test reports with the following data of fuel burn at full throttle:
FOURSTROKE 115 = 10.5-GPH
VERADO 200 = 20.03-GPH
jharrell cited two test reports from the same pool of data
FOURSTROKE 115 = 11.1-GPH
VERADO 200 = 18.7
Because the engines are of different horsepower, we scaled the fuel flow of the 115-HP engine by 1.74:1 to be in proportion to the 200-HP engine. The data would then look like this:
FOURSTROKE (200) = 18.26-GPH
and
FOURSTROKE (200) = 19.3-GPH
VERADO 200 = 18.7
By selecting one set of data or the other, various calculations using the fuel flow could be shown to illustrate one theory or another. Clearly there is some variation in the test data on the rate of fuel flow.
It was assumed that a way to know BSFC of an engine was to run it at full-throttle, where it must be producing its rated power, and then to use the fuel flow rate at that power level as a way to calculate BSFC. Yet, we see, just in the above two examples, that fuel flow at full throttle may be variable.
It seems to me there are at least four possible causes for variation in the fuel flow data:
--a random variation in the actual power being produced by the engine,
--a consistent variation in the actual power being produced relative to the rated power
--a random variation in the engine efficiency
--a random error in the measurement of fuel flow
If test data is obtained by using different engines, it is possible that variations in production of the engine cause variations in the actual power the engine can produce. There is a provision for a manufacturing tolerance of ten-percent in power output in the ICOMIA specifications. This suggests that on the assembly line of 200-HP engines, one particular engine might be capable of 210-HP while a second engine made by that same assembly line might only be able to produce 190-HP.
If test data is obtained using the same engine, it is possible that other factors could cause the engine to have variations in the actual power output. There could be environmental influences, such as air temperature, humidity, and air pressure. There could be load influences, such as the load of the propeller.
Because it is difficult to know with precision the exact power of an engine at any load or application, it is often seen in test report comparison that an engine is assumed to produce its rated power when at full throttle (and running in its rated engine speed range). If a particular engine is always producing some power output that is different from its rated power, any calculation based on power would be affected. For example, if an engine is rated at 115-HP but really can only produce 108-HP, calculations that assume it is making 115-HP will contain errors. Or, perhaps the 115-HP engine consistently produces 121-HP. Again, the assumption that the power output is 115-HP will produce errors in any calculation using power.
There is also the notion that a particular engine might have a variation in fuel flow while producing the same power due to some natural variation of its fuel efficiency at various engine speeds and loads. There may be particularly favorable or unfavorable combinations of load and engine speed for a particular engine which causes the efficiency of the engine to convert fuel to power to change. Without having access to carefully measured data for a particular engine, to know these characteristics seems impossible.
Finally, the accuracy of the fuel flow data may be inconsistent. In many modern engines the engine itself is relied on as the source of fuel flow data, as these engines report that parameter as part of the electronic engine instrument data. I believe this fuel flow data is imputed from the actual instructions contained in the engine controller that controls the combustion process. That is to say, the engine is trying to provide itself with the fuel flow rate it reports. The engine does not actually measure its own fuel flow. If there is some variation in the performance of the fuel system, the engine could deliver more or less actual fuel than is being reported. In my opinion, this realm has the least likelihood of being a source of inconsistency. If the engine fuel system delivers the wrong amount of fuel to the cylinders, there will probably be running problems.
Sources:
For my test data:
Verado 200 at http://www.boatpoint.com.au/engine-reviews/2004/mercury/ mercury-verado-8294
FourStoke 115 at http://www.mercurymarine.com/engines/engine-tests/boat-house-bulletin/ ?ID=1129&
For jharrel test data:
Verado 200 at http://www.mercurymarine.com/engines/engine-tests/third-party/?ID=101&
FourStroke 115 [no report cited]
Jefecinco posted 03-08-2014 10:04 AM ET (US)     Profile for Jefecinco  Send Email to Jefecinco
If the tests are done in laboratory conditions variables such as barometric pressure, intake air temperature and humidity are factored into the results using accurate formula to adjust to standard measurement conditions thus factoring out the variables.
It is difficult for me to imagine much variability in modern engine manufacturing, but that is my assumption.
Measurement equipment is frequently calibrated so that SHOULD not be a variable.
I am ignorant of how loads are applied to outboard engines in laboratory tests. I've seen a special propeller arrangement used to subject engines to a load for tank testing at repair shops but would expect something more precise to be used in an engine laboratory. I suspect connection of the propeller shaft to a variable load device is used for consistency.
It's quite a puzzle.
jimh posted 03-08-2014 10:19 AM ET (US)     Profile for jimh  Send Email to jimh
Regarding the use of particularly chose data points to make a certain outcome in calculations occur, which has been described as cherry picking the data, I have looked at the data use by jharrell and myself, and I have compared the data chosen by us to a larger sample of available data.
I choose the sample by choosing the first 16 test reports presented in the library of test reports for the Mercury FOURSTROKE 115-HP engine. The average GPH value reported in those tests is 10.3-GPH.
I now compare the average of 16-values to the values chosen by me and jharrel:
For my comparison, I used a value of 10.5-GPH, which is actually above the average value. In choosing this value I actually hurt my comparison. It would have better for me to choose a lower value. For example, if I had been cherry picking the data, I would have chosen a value of 7.3-GPH, which is contained in the data set and is the lowest value.
For jharrell's comparison, he chose a value of 11.1-GPH, which is also above average. Choosing a value above average helped jharrel's comparison. It would have been better for jharrell to use an even higher value. For example, he could have cherry picked the value of 11.3-GPH, which is contained in the data set and is the highest value.
However, if the average value of the data is used, my comparison is sustained and jharrell's comparison fails.
My conclusion from this: since there is a variation in data, to use a larger sample and take the average is a better method than selected individual data.
(If anyone wants pointers to the 16 boat tests I used to reach an average GPH, just send me an email. I will send you the reports.)
jharrell posted 03-08-2014 11:16 AM ET (US)     Profile for jharrell
http://www.mercurymarine.com/engines/engine-tests/boat-house-bulletin/ ?ID=629&
http://www.mercurymarine.com/engines/engine-tests/boat-house-bulletin/ ?ID=1099&
http://www.mercurymarine.com/engines/engine-tests/boat-house-bulletin/ ?ID=668&
http://www.mercurymarine.com/engines/engine-tests/boat-house-bulletin/ ?ID=769&
I agree averaging is a better way of getting data. However your report of 7.3GPH shows even an average can be severely skewed by incorrect propeller selection. So the larger the sample size the better.
This should also be applied to the Verado did you gather multiple samples and average it as well?
I would also like to reiterate a point that taking a 115 and scaling it up to theoretical 200 with no supercharger is dubious. The 1.7L 115 cannot produce 200 hp without a supercharger or increase displacement, efficiency is not non-linear, simply scaling the 115 fuel consumption up by the horsepower difference will result in questionable results.
jimh posted 03-08-2014 12:54 PM ET (US)     Profile for jimh  Send Email to jimh
I agree that in scaling the fuel consumption of an engine to a new horsepower may contain some errors. In the case in point, the Verado and FourStroke are using the exact same block and displacement, same valves, same alternators, and thus are about as similar as one could get. That suggested to me that the fuel burn of the engine without a supercharger and the fuel burn of one with a supercharger could be compared.
I have not yet studied a wide range of fuel burn data for the Verado. If I do study that data, I will post my findings here. You are also welcome to report on the same.
ASIDE: Does the FourStroke engine using the Verado block also employ the dry sump method of lubrication?
jharrell posted 03-08-2014 01:32 PM ET (US)     Profile for jharrell
They are as similar as one could get except the 115 is not able to produce 200 horsepower, nor would it be possible for it to without adding increase parasitic loss.
I went ahead gathered data from 2 200 hp engines and produced an average for each:
Mercury Verado 200: 19.66 GPH over 39 engine reports
Evinrude E-TEC 200: [18.26] GPH over [22] engine reports
[Data corrected; see author's note below--jimh]
I would like to point out your choice of 20.03 was above the Verado 200's average as well. There are also over 20 reports of the 115 consuming 11 GPH or more. There is also a report of the Verado 200 only consuming 14.9 GPH, I guess I should have picked that one.
So what those this data tell us? Both the E-TEC and Verado are less efficient than a non-existent 200HP 1.7L naturally aspirated Mercury FOURSTROKE that only consumes 18.26 GPH.
jimh posted 03-08-2014 01:37 PM ET (US)     Profile for jimh  Send Email to jimh
I am glad I whetted your appetite for collecting and averaging data.
Re the "nonexistant" FourStroke: if Mercury had chosen to make a six-cylinder non-supercharged engine from the Verado six-cylinder block, we would have another candidate for comparison.
ASIDE: Which E-TEC did you use for the 200-HP? The 3.3-liter block?
jharrell posted 03-08-2014 02:52 PM ET (US)     Profile for jharrell
The only E-TEC rated for 200 Horsepower, the 2.5L, right?
I did not use the 3.3L E-TEC rated for 200 HO units.
You did prompt me to review the data and there is an error, Evinrude listed 4 225HP engines under the 200 hp performance reports. This brought the average down to 18.67 GPH over 22 reports, still above the 18.26 GPH 1.7L NA 200.
jimh posted 03-18-2014 12:59 PM ET (US)     Profile for jimh  Send Email to jimh
I sampled 20 reports of fuel consumption published by Mercury about their 115-HP FOURSTROKE model. The average fuel consumption of the twenty engines at full throttle was 10.5-GPH.
jimh posted 03-18-2014 01:09 PM ET (US)     Profile for jimh  Send Email to jimh
It happens that the average GPH of the 115 at 10.5-GPH was precisely the average I used in the calculations I made in the first article in this thread. (Some cherry picking of data, eh?)
jharrell sampled a number of reports about the 200-HP Verado version of this same engine block, and found the average GPH was 19.66-GPH.
I now re-calculate the fuel flow difference as in my first example. First, I scale the 115-HP engine fuel flow to 200-HP, using a factor of 200/115:
"200" FOURSTROKE = 18.26
When comparing to Verado, we see that 1.4-GPH more fuel is burned.
If we assume that the conversion of fuel to horsepower is done at the same basis in the Verado as in the FOURSTROKE (since they are identical engines other than the supercharger), we see the rate of horsepower per GPH is
115-HP/10.5-GPH = 10.95-HP/Gallon/hour
Thus suggests that when the Verado burns an extra 1.4-GPH, it ought to be turning that fuel into
10.95-HP/Gallon/Hour x 1.4-Gallon./1-hour = 15.3-HP
We attribute this lost power to the supercharger. This suggests the total power is about
200 + 15.3 = 215.3-HP
and the percentage of total power consumed by the supercharger is therefore
15.3/215.3 = 7-percent
jimh posted 03-18-2014 01:31 PM ET (US)     Profile for jimh  Send Email to jimh
Regarding the scaling of the fuel consumption of the 115-HP FOURSTROKE to the 200-HP level, this certainly affects the comparison.
There has been a notion put forth that production of a lot of horsepower from an engine of small displacement is somehow more efficient than production of that same horsepower from an engine of larger displacement. If one accepts this notion, then the implications are:
--when the Verado is making 200-HP from the 1.7-liter displacement, it must be taking advantage of more of this efficiency than when the FOURSTROKE is making 115-HP from the 1.7-liter displacement;
--due to the above increase in efficiency, it is likely that when we note the difference in fuel consumption, we should actually attribute more than just the noted difference in fuel to the load of the supercharger;
--the calculation of the load of the supercharger with the method I have used is likely to be lower than the actual load.
On this basis, I am satisfied that the calculated value of supercharger load shown above, 7-percent, is probably somewhat below the actual load. I am further reinforced in my initial belief that an allowance of 10-percent for the load of the supercharger is probably a very good estimate. In the absence of any other demonstration of a method to calculate this value, I will continue to use 10-percent as the estimate.
jharrell posted 03-18-2014 07:55 PM ET (US)     Profile for jharrell
Using your formula the E-TEC 200 wastes 4.39 HP compared to the hypothetical FOURSTROKE 200.
Where does this 4.39 HP go?
jimh posted 03-19-2014 08:56 AM ET (US)     Profile for jimh  Send Email to jimh
I don't see the same basis for comparison between the engines I have studied and the E-TEC. They are radically different:
--displacement is radically different (3.3-liter versus 1.7-liter)
--design is radically different (two-stroke-power-cycle versus four-stroke-power-cycle)
I don't see much comparable. My comparison is between engines that are identical except for the supercharger. This tends to make the supercharger the variable.
