| Author | Topic: OUTRAGE 18, Yamaha F150: Mounting Height |
| Mike Kub |
I am getting [a Yahama F150 outboard enigine] put on [some unidentified boat] this week. The dealer said [the Yamaha F150 engine] should go one-hole-lower than I recall [someone else said in some prior discussion which cannot be found]. Please help. |
| Tom W Clark |
What boat? |
| Mike Kub |
1986 18' Outrage |
| Mike Kub |
Also [seeks a] recommendation for Yamaha propeller. I so appreciate the help. |
| Tom W Clark |
Mount the new Yamaha F150 two holes up: o Use a 14-1/4" x 17" Stiletto Advantage or Turbo 1. If using a Yamaha branded prop use the 14-1/4" x 18" Performance Series 3-Blade. |
| Mike Kub |
Thanks. So glad Spring is here. |
Mike--If you want to find this article in the future, use a search with the arguments: Mike Kub F150 mounting height OUTRAGE 18. It should come up in the first few hits |
