Topic: Will a 20" Engine Work on a 210 Ventura?
WhalerAce |
posted 03-31-2014 11:20 PM ET (US)
I am still looking for the perfect engine for our new-to-us 2001 Ventura 210, which specifies a 25" shaft engine. My question is this: will a 20" version work? I ask because it seems that advice lately has been to mount engines up a lot higher than in the past. So would a 20" engine with a four-bladed prop work, or should I just stick to a 25" and raise it a few holes?The 210 Ventura seems to be a pretty heavy boat for its size, and high speed is not a goal -- we mainly cruise, so flying through waves is not what we do. I ask because there are a lot of 20" HPDI Yamahas available, though I am still looking for either that low-hours 250HP OX-66 or 300HP HPDI. Thanks in advance, --- WhalerAce
sraab928
posted 04-01-2014 06:47 AM ET (US)
Sorry cant help with your question but did you see these for sale? http://www.thehulltruth.com/parts-forum/ 573857-yamaha-ox66-250s-super-clean-will-split-3750-each.html |
WhalerAce
posted 04-01-2014 02:55 PM ET (US)
No I didn't but you can bet I am going to check on it now!Thanks! --- Ace |
Teak Oil
posted 04-01-2014 08:33 PM ET (US)
You do not want to put a 20" engine on a Ventura, it will never perform properly |
MattInSanDiego
posted 04-01-2014 10:32 PM ET (US)
I agree that you don't want to put a 20 inch motor on a 25 inch transom. And watch out for HPDI's over 200 hp. They have a bad reputation for catastrophic failure. |
posted 04-03-2014 10:26 AM ET (US)
WhalerAce--With a Boston Whaler VENTURA boat, will you now be known as Ace Ventura?Did this have anything to do with your decision to buy a Ventura? |
WhalerAce
posted 04-03-2014 01:15 PM ET (US)
No, but that is the same question that Gary Frutiger posed. (But I did create a new handle on the HullTruth as that when I was checking on some Yamaha OX-66s).No, the reason for the Ventura was its seating. Amazingly, the Temptation can really only seat four people comfortably (maybe five) for all that boat. Since we have four kids to carry now (our sons and their spouse and potential spouse), the Ventura lends itself more to that kind of sociability. And besides, it really seems to be a hell-of-a-boat. But I am still curious about the shaft length. It does seem like we are advocating mounting engines up so much higher on the transom that a "highly mounted" 25" shaft is beginning to approach the same wetted depth that a "lowly-mounted" 20" shaft would be. I was kinda hoping that Larry Goltz or Tom Clark would have jumped in by now . . . Anyhow, need to hurry up and find an engine so that we can go on the Whaler Bimini trip. This is our 20th wedding anniversary this year, and that is how we began our married life 20 years ago -- in fact, our wedding had to be scheduled on a Wednesday so that we could make it down to Florida by Saturday for the Captain's meeting. But AceVentura or VenturaAce -- not sure which way to go. |
Teak Oil
posted 04-03-2014 03:09 PM ET (US)
Ace I have my E-tec mounted all the way up on the transom right now and I can measure that distance for you when I get home. I am pretty sure it is less than five inches above the transom.The problem is not all hulls like to run with the engine mounted that high, and by going with a 20" motor you will most likely be an inch or two too high, and have no ability to lower the motor. You would also be hurting the resale value of your boat going with the wrong shaft length outboard |
DaveS
posted 04-06-2014 01:52 PM ET (US)
Just curious, would a jack plate work? Would make dialing in the perfect height much easier. |
Teak Oil
posted 04-06-2014 07:17 PM ET (US)
The powerhead would still be 5" lower than it should, increasing the chance of the engine getting submerged. It would also look terrible and still hurt the resale value. |
