Topic: 1985 Outrage 22, Yamaha 200-HP HPDI
half shell |
posted 04-22-2014 06:27 AM ET (US)
I have a 1985 OUTRAGE 22 with a Yamaha 200-HP HPDI outboard engine. Is anyone here running that set up? What performance can I expect? I will look to see what hole mounting and propeller it is set up with. I bought the boat winterized late fall, so no idea as to performance. Thanks Rob
posted 04-22-2014 09:55 AM ET (US)
A Boston Whaler OUTRAGE 22 with a 200-HP engine should reach a top speed above 40-MPH. |
Tom W Clark
posted 04-22-2014 10:01 AM ET (US)
Assuming the motor is in tune, the boat should be good for 42 MPH with a 16" or 17" pitch propeller.The motor should be mounted at least two holes up on the transom leaving approximately 1-1/2" of space between the top of the transom and the motor. Some models of propeller will allow the motor to move up another bolt hole leaving 2-1/4" of space |
half shell
posted 04-22-2014 06:05 PM ET (US)
Thank you I hope to go by the yard and check soon |
half shell
posted 04-27-2014 02:36 PM ET (US)
Engine mounted two holes up Prop is currently mounted to engine 17m is stamped on hub area Painted black feels like aluminum with some minor nicks on edge of blade Any suggestions are appreciated |
half shell
posted 04-27-2014 03:09 PM ET (US)
GRAND NUSSIE
posted 04-27-2014 05:29 PM ET (US)
Some of the mid 80's Yamahas included a painted stainless prop in the price of the motor. At least my 1986 90 hp did.Dick |
MattInSanDiego
posted 04-28-2014 01:10 AM ET (US)
I have a 1980 22 Outrage with a 2002 Yamaha 200 HPDI. I love the setup. http://s279.photobucket.com/user/MattInSanDiego/media-full//DSC_0938-copy_edited.jpg.html Here is the discussion I started in 2007 soon after I bought the boat. http://continuouswave.com/ubb/Forum4/HTML/005550.html I ended up with the Stiletto 15". I can turn 5600 RPM at about 42 MPH. The motor is still mounted one or two holes too low. The HPDI needs very clean fuel. I had a problem with my VST filters clogging and replacing the fuel tank fixed the issue. That was about three years ago and it has been running great since then. In 2007 the engine had 367 hours on her in 2007. Now it has over 1800. Matt
half shell
posted 04-28-2014 08:13 AM ET (US)
Thanks Matt good info and happy to hear about the high engine hours and still going strong I'm guessing you follow service instructions properly to get that kind of longevity put of the engine I'll know shortly what the engine hours are after the mechanic gets it ready Thanks Rob |
MattInSanDiego
posted 04-28-2014 11:29 AM ET (US)
I change the filters regularly (external, VST, canister above the VST) and add Ring Free to every tank of gas. I also have only used Yamalube 2M oil.Enjoy your new rig. Matt |
half shell
posted 07-20-2014 10:08 AM ET (US)
[I f]inally got the boat in the water [but] did not do a full run down of numbers. [H]owever, with 1-to-2-feet of choppy conditions and five adults onboard, the boat liked 3,500-RPM, 7.5-GPH, and 25-MPH cruise, according to the Yamaha gauges. I cannot believe the ride this boat gives--much better than expected. From what [I have] seen so far, Boston Whaler got [the boat's ride] right with this hull. Regards from Rob |
half shell
posted 09-19-2015 12:48 PM ET (US)
[Post a listing of notice of FOR-SALE in MARKETPLACE. This area of the forum is for information about boat performance, not boat sales. Thanks--jimh] |
