| Author | Topic: Rebel vs Enertia Eco up close |
| Teak Oil |
Since the other thread on the Enertia Eco became rather lengthy, I decided to start a new one to show the up close differences between the two props. The Rebel is a large prop, but the Eco is just huge. Other than a bit of cup at the tip the two props are very similar. Here are some pics side by side, both of these props are 19" pitch. http://img.photobucket.com/albums/v735/MontaukBob/phonepics434.jpg http://img.photobucket.com/albums/v735/MontaukBob/phonepics430.jpg http://img.photobucket.com/albums/v735/MontaukBob/phonepics431.jpg |
Very interesting observation! |
| Teak Oil |
I thought the most interesting part was that the blade rake stayed about the same until the last 1/4 or so of the blade, then it has a bit of cup and the rake increases dramatically. |
| Hoosier |
I just got this test report by email. http://www.boattest.com/engine-review/Mercury/ 19500078_Enertia-ECO-Prop_2014 |
| Teak Oil |
Yeah I have seen that test, and Mercury sends another test vs a rev4 with the prop. If it doesn't thunderstorm tomorrow I will be out testing on Saginaw Bay. I had to do some significant grinding to the torque tab just to get the prop mounted. If the diameter had been 16 1/16" there is no way this prop would ever work. Its huge |
| prj |
What is the "torque tab" please? |
| prj |
Ah, trim tab on the anode above the prop and beneath the ventilation plate! Figured it out from another article... |
Re the trim tab on the outboard engine under the anti-ventilation plate: On the E-TEC engines I believe that the trim tab also functions as a water pickup.It sends water into the lower part of the exhaust passage to keep the gear case cooler. Use caution if you take a grinder to it. |
| Teak Oil |
Yes the water pickup which I believe cools the exhaust coming thru the hub is in the tip of the tab. There is a fair amount of grinding that can be done before getting to that. It would definitely be more of an issue if I was going to need a higher pitched prop possibly |
| kitebuz |
Did you grind the standard torque tab, or was it the flat one? |
| Teak Oil |
It was the standard one. Since this engine uses water from the torque tab to cool the exhaust I am not sure if you can run a flat tab on it. |
