| Author | Topic: SPORT 13 Engine Weight, Horsepower |
| msethsmile |
Is [the 175-lbs weight or the 50-HP of a 1972 Mercury 500 outboard engine] too much weight or power [for the transom of a] 1968 SPORT 13? |
The rated maximum power is 40-HP, so 50-HP exceeds the maximum rating. There was no rating for maximum transom weight, so it is hard to say if 175-lbs will be too much. |
| dg22 |
The transom on my 1967 13 footer has held up with my 1973 50-HP Evinrude on it. My motor weighs around 185 lbs. I've used it now for 5 summers and pull the kids skiing and tubing and no problems so far -- touch wood. No additional stress cracks since I purchased the boat about 6 years ago. This is how it sits in the water with the 50hp on it. http://i1004.photobucket.com/albums/af166/dg22/Whaler/WhaleratLaunch.jpg I think the ideal motor for this boat is the older 35hp Evinrude or Johnson from the 70's and early 80's which only weighs around 120 lbs. Note: People re-powering with newer 30hp motors weigh around 160 to 170 lbs so you are not too far off with your Merc 500. |
dg22--Re your digital image: nice boat, cute kid, wet dog, cool boat house. |
| dg22 |
Thanks Jim, that was the day we launched the boat for first time after fixing it up. My father-in-law thought I was nuts fixing up this old boat but it turned out nice. CW is a great resource for information. |
| msethsmile |
The 13 must not have too maany hours on it. No stress cracks in the transom. Original rub rail, steering system, gel, etc. I suspect the 500 has been on there since 1972. I have a 86 Rude 20 and agree that series (20-25-30-35) would be dandy on a 13. Unforetunately, that motor is a 20 inch and on a pontoon. |
| dg22 |
I would just make sure everything is in good working order, particularly the old steering system. I replaced the wire rope with my original steering. |
