posted 06-27-2014 06:53 PM ET (US) Went with a buddy to check a 1997 OUTRAGE 17 with a 2008 Mercury Verado 135. The engine is huge. At 510-lbs is it too heavy?
george nagy
posted 06-27-2014 07:48 PM ET (US)
Did you sea trial this boat? I think it may be very stern heavy with that Verado. I have seen this boat setup with a 115 v4 johnson and the static trim was level. I know that many were rigged with 135 to 150 OptiMax motors when they left the factory which weighed nearly 100-lbs less than the Verado.
george nagy
posted 06-27-2014 07:53 PM ET (US)
http://continuouswave.com/ubb/Forum4/HTML/008069.html
In the link above there is a post with the same boat rigged with an E-TEC 135 V6. Read this; if you haven't yet you will get some idea of the boat's performance regarding stern weight, with the exception that the engine is much lighter than the verado.
Jerry Townsend
posted 06-27-2014 08:36 PM ET (US)
I bought the same boat new, but with a 115 V4 Johnson which weighs 319-lbs. The static trim is level. ---- Jerry/Idaho
masbama
posted 06-27-2014 09:12 PM ET (US)
Have yet to sea trial. That is the next step. Will be interesting. It does have trim tabs. Thanks!
mkelly
posted 06-27-2014 10:42 PM ET (US)
I have a 1994 Outrage 19 with a 405-lbs engine. It still has porpoising problems. My opinion way too heavy. I have tabs, which help, but I don't think it would take care of everything you would need. Navy or black 150 E-TEC would be perfect for that boat, weighs 420 lbs.
posted 06-28-2014 02:59 AM ET (US)
[Moved to PERFORMANCE.]
Teak Oil
posted 06-29-2014 09:34 PM ET (US)
That boat will be much too stern heavy and could have porpoising issues at speed as mentioned above. Also in a following sea it will have a much greater tendency to take water over the stern.
There is no way I would want a 135 that weighed 500 lbs on an Outrage. For that weight you could have a 250 E-Tec!
