posted 08-29-2014 11:24 AM ET (US)
My 2004 Merucry OptiMax 135 is not achieving full throttle. The butterfly flap on the air intake is only opening maybe 3/4-ths of the way (or 45 to 60 degrees). I can manually move the throttle asssmbly by the air intake an inch or so by hand such that it is vertical and fully open (or 90 degrees). The swing arm linkage assembly on the block atttached at one end to the throttle cable, and at the other end acuates a rod to the throttle body, has a stop screw on both the idle side and the full throttle side. The full throttle stop has a bolt with lock nut, I loosened the lock nut but was unable to unscrew the stop bolt. Is it the case that the bolt has some kind of thread lock? (It looks clean and spotless.) Should I be able to adjust it? Or is this possibly a factory setting? Seems odd to me for it to be a factory-type setting. But if the same throttle body is used for higher horsepower models, some restriction would be in order such that opening the air flap too much would result in a overly lean supply.
I removed the little rubber tip from the stop bolt and gained about 200 to 300-RPM. It seems there is more in the offing if I can adjust the full throttle stop.
I have read that the 135 is the same block as the 150 and 175. Is this a crude method to govern full throttle on the OptiMax 135? Would it be a bad idea to monkey with it?
jws
