posted 10-26-2014 11:43 AM ET (US)
The fuel burn rate of my boat at a speed of 25-MPH is about 9 to 10-GPH. I am not sure how that helps you as we have different boats and different outboard engines.For a two-cycle classic outboard engine you can figure the fuel consumption will be about 0.55-lbs/HP-hour--at best. This is known as the brake specific fuel consumption.
To convert BSFC in units of lbs/HP-hour to gallons/hour, you need to know the horsepower and the density of the fuel. For gasoline you can use 6.25-lbs/gallon as a reasonably good figure for fuel density. This suggests the G/HP-hour will then be
0.55-lbs/1-HP-hour x 1-gallon/6.25-lbs = 0.088-gallons/1-HP-hour
To know the fuel burn you plug in the horsepower. For example, if you are running at full throttle and making 150-HP, the fuel burn would be
150-HP x 0.088-gallons/HP-hour = 13.2-gallons/hour
It is hard to say with any certainty what horsepower will be necessary to put your boat onto plane at a certain speed.
It is also common that BSFC varies over the engine speed and load range, and it can be higher than 0.55-lbs/HP-hour for some engine speed and load combinations. This is particularly true in older two-cycle engines.
A very simple approximation is to take the horsepower and divide by ten to get GPH for that power. Thus a 150-HP engine would burn 15-GPH.
