| Author | Topic: 1961 13 STANDARD Engine Shaft Length |
| 19snooky63 |
[Some dimension of the] transom [of a 1961 Boston Whaler 13-foot STANDARD boat] is 17-inch. The anti-ventilation plate of the recommended short shaft or 15-inch shaft outboard will be 2-inch above keel. Will this affect performance? I am getting a 25-HP. Thanks. |
| macfam |
That's about right. You want the anti-ventilation plate ABOVE the keel, never equal to, or below. The best performance and control, and least porpoising occurs when plate is 1-inch to 2-inch above the keel. |
The transom of the older Boston Whaler boats is designed for outboard engines with a short shaft or 15-inch shaft. There really is not any particular dimension on the transom that is supposed to be precisely 15-inches. Having an outboard engine with the wrong shaft length affects performance. |
| dg22 |
When measuring the transom, you need to take a vertical measurement. It should be closer to 15 inch. |
The vertical height will be shorter, but it won't be 15-inches on a transom of 17-inch height with the usual transom angle of around 13-degrees. It will be more like 16.5. The trigonometry will be vertical height = COS(transomAngle) x (transom height) vertical height = COS(13) x 17 vertical height = 16.56 |
| dg22 |
I read a post here that the actual transom angle of the 13-footer is 20-degrees. I borrowed my daughter's calculator and this works out to a vertical height of 16 inches using the formula Jimh provided. If I remember correctly that is close to what I measured a few years back. http://continuouswave.com/ubb/Forum4/HTML/005272.html |
| 19snooky63 |
thanx a lot folks you were realy helpful,i,m doing a total redo outside is buffed out,inside is blocked to 220,shold buff it out this weekend,came with orig brass and stainless,will post pics if I can fig it out,thanx again. |
