| Author | Topic: Montauk Re-power |
| whalerski |
have not been on with you in a while nice to see same faces on CW short story my 1985 Montauk original owner 85hp Susuki, 1985 has finally given up the ghost. was original engine babied for 30 years Good stuff Bad stuff used original prop and replaced with same over years as would read your performance specs - was relatively satisfied with what I had NOW Thought the answer might be a fictional F90 Yamaha 'soon' to be released at any momnet and worth waiting for , The f70 seemed a bit small but same weight and I have a poling platform to push in the gulf when flyfishing from louisana to key west so less weight is not a bad thing Have not been able to ferret out of the posts if anyone thinks the Montouk 80's do well with the F70 if set up properly reading etec 90's as the CW prefered repower I think - with only 60 lbs additional weight - but get horror stories from guides in the keys from largo to key west on etecs problems with longevity. Yamahas being their answer I will be using this from the UP to Key west salt and fresh as I have for the last 30. Is the Etec the answer and has the reliability improved?? repowering Next week!! thanks in advance and as always |
| DVollrath |
Whalerski, I've had an F70 on my 1988 Montauk for a couple of years now. I think I have around 150 hours on the motor, but I'll need to check. It is a great combination for me. While the 13" prop is a bit short and may take some top end away, it gives nice hole shot. Here is a link to some performance measurements I conducted: http://continuouswave.com/ubb/Forum4/HTML/007793.html
[Fixed bad link--jimh] |
| Alan Heckman |
I repowered my 1999 Alert 17 last spring with a new Yamaha F70 and I love it. With a 13.25 x 14 Yamaha Performance Series propI get a good hole shot, top speed of 38 mph, and unbelievable fuel economy. Put this together with easy starting, quiet running, no smoke, and light weight which is a real plus on a 17 ft Whaler this is a great repower choice IMO. This motor has exceeded all my expectations so far. My boat is used exclusively for fishing on Lake Erie. AL |
| tedious |
Alan, not to hijack the thread, but what RPMs are you seeing at the 38-mph WOT with your 13.25" x 14? Thanks. Tim |
| Teak Oil |
Florida is Yamaha land, so thats what all the locals will advise. Get whatever motor has the best local support. If you boat with a heavy load all the time the extra power of the E-tec is nice, but the Yammy is a good motor |
| contender |
Teak is correct either a Yamaha or an Evinrude... Way to go... |
I don't see where you made the case for the reliability of the E-TEC to be bad. |
| Alan Heckman |
Tim, 6200 RPM. Motor mounted 3 holes up. Al |
| tedious |
Thanks Al, appreciate the info. Tim |
| whalerski |
Dennis /Jim. Thanks for links missed that data before Did you try the 14" prop? Any diff in top end?? When trimmed did you pick up any mph ( vs DF70 Suzuki data) Scott |
| whalerski |
Alan thanks for info looks close Teak to your point of service and support I will need support in multiple locations Have minimized Tohatsu, Suzuki, due to less network Merc and Honda weight puts them on the side as well Did I miss 90 Etec data on 80's montauks? |
| DVollrath |
Scott, I set the trim to a neutral position prior to taking the measurement sequences. This position corresponded to the setting I normally cruise at. I didn't want to adjust trim during the testing because it affects rpm, and that was what I was trying to hold constant. I don't believe I could have gotten any more top end by trimming out further, as I was fairly high to begin with and was rev-limited by the motor. I (most likely) did not have a chance to try out a Yamaha 14" prop. Tom did get me a prop that was supposed to be a Yamaha 14" that he found on eBay, but it performed so similarly to the Stiletto 13" (perhaps even a bit shorter) that we questioned if it was as advertised. At any rate, it is not clear I'd have bought the prop even if it did perform like Alan's. I rarely open it up such that the extra 2mph would be noticed, and I really like the extra pop on the low end. I'm pretty content with my setup. That being said, I'm in the process of repowering a 1985 Outrage 18, but I bought that boat for the extra room it affords vs the Montauk. Dennis |
