Topic: 150 Montauk Prop Selection
jasiu |
posted 05-31-2015 09:54 AM ET (US)
I recently purchased a 2006 150 Montauk with a 60hp Mercury Bigfoot for fishing. It didn't come with the standard issue 13 3/8 x 14 SS prop, but rather with an aluminum prop with no markings on the inside or out. The WOT performance with two guys on board and some fishing gear, with the boat fully trimmed out, fairly smooth water was 30 mph (on board GPS) at 5100 rpm. Does anyone have a suggestion for an aluminum prop that would increase the engine speed closer to 6000 rpm? Or should I just buy the correct SS prop--ouch?
Tom W Clark
posted 06-02-2015 12:51 PM ET (US)
I do not recommend an aluminum propeller for this boat, but to answer your question, if you had to have aluminum, I would choose the 13-3/4" x 15" Mercury Black Max, Part #48-77342This propeller is also available under the Quicksilver brand as the Black Diamond, part #QA2034X |
jasiu
posted 06-02-2015 07:30 PM ET (US)
Thanks for the information Tom. Why do you recommend staying with a SS prop? |
Tom W Clark
posted 06-02-2015 09:04 PM ET (US)
Most stainless steel propellers will perform much better. More speed, better fuel economy, improved handling and they last much longer so that in the long run, they cost less. |
jasiu
posted 06-03-2015 12:01 AM ET (US)
Any suggestions where I can get a good price on the SS prop and a specific hub I should specify? |
jasiu
posted 06-03-2015 12:04 AM ET (US)
Any suggestions where I can get a good price on the SS prop? And, is there a specific hub I should specify? |
Tom W Clark
posted 06-03-2015 07:38 PM ET (US)
Well, the Mercury Vengeance is probably fine for you bat but I am not fan of that model. It is one of Mercury's weakest and oldest stainless steel models.It is also sold as the Quicksilver Silverado. The 13-3/8" x 14" is part # QS5114X and typically costs less than the Mercury branded version. A quick search suggests you could get one for about $300 PowerTech! offers numerous models to fit your motor. I don't have a lot of personal experience with them but I know Ken Reeves likes the SCD3 for smaller boat with he intermediate gearcase. I would use a 13-1/4" x 13" Stiletto Advantage which can be had for $240, maybe a little less. The factory has them in stock against after a long backorder. In all cases, I would use a Mercury Flo-Torq III hub kit to help cut down shift clunk and prop rattle with a stainless steel propeller on that four stroke motor of yours. |
jasiu
posted 06-04-2015 01:29 AM ET (US)
Where can I get a Stiletto Advantage size you suggested? I checked Dan's Discount and a few others, but that size doesn't show up. |
