| Author | Topic: Outrage 25 Whaler Drive with 250-HP Single-engine |
| cc378 |
I would love opinions [from] owners of the classic Outrage 25 WD in terms of the performance characteristics of the boat with a single 250 on it. A Revenge 25 WD would also be of interest.. Let's assume the boat is used for cruising and fishing. Given the weight of 3600-lbs plus fuel and motor, it would appear that 250-HP from a modern four-stroke-power-cycle outboard engine would be plenty to cruise at 28-MPH and to fish. But real world experiences are what I am interested in hearing about. I recognize I could put a 300-HP engine on the back but, I am hoping to avoid this, unless I can be convinced that the boat will be really under-powered. I also recognize that I could put twins on the back but the modern four-cycle engines appear to be too heavy for that option. Twin 200's gets one up to about 1,100 lbs. I would also like to avoid the extra maintenance costs. Thanks--Stephen |
| macfam |
Stephen--we had a 1988 Revenge Walk-Thru with a Yamaha OX66 250hp. This boat had the STANDARD Transom. The boat ran and handled fantastic. Cruising speed was between 23 and 30-MPH, and topped out about 40 to 42-MPH, depending upon conditions. If I were to re-power, and considering it had a Whaler Drive, my opinion is that it would need a 300-HP to compensate for the Whaler Drive. Good choices available: 300 E-TEC (my first choice), 300 Yamaha, 300 Suzuki, 300 Verado (my last choice). I know the E-TEC is NOT a 4-stroke, but I have an E-TEC 30 on our 13 Super Sport, and love it. Plus, a friend has a 23 Grady Gulf Stream (very heavy and wide) with the 300 E-TEC replacing a OX66 250, and he LOVES it. They idle nearly as quiet as the four-cycle engines, have no smoke, have better acceleration, and have less maintenance. But [the choice] all depends on the dealership network near you. |
| peteinsf |
Similar discussion: |
| peteinsf |
My vote would be a single Evinrude G2 250-300hp. Power and great fuel mileage. Can't go wrong with that single setup. I ended up with 2 e-tec 2.6l v6 units but it was not my first choice. |
| cc378 |
Thanks. Why did you go with the 2 V2.6 and why wasn't it your first choice? |
| peteinsf |
eBay bidding error, I thought I was buying two 3.3l 200s. |
| peteinsf |
For a different boat. |
| Tom W Clark |
250 HP is more than enough. I have 300 HP (twin 150s) on my Revenge 25 Walk-Through and think it would really be a better boat with a single 250 or even 225 |
| cc378 |
Tom, Assuming the new engine is a Honda 250 do you have any propeller recommendations. Thanks Stephen |
| Tom W Clark |
14-5/8" x 17" Mercury Revolution 4 |
| John from Madison CT |
If I was to repower my 25' Outrage Cuddy/ Whaler Drive, I'd probably consider a single 300hp, but I'd bet a 250hp would still hit close to 40mph at WOT. |
| Jeff |
For your reference These are Jamie's performance numbers with a Suzuki 300 |
MACFAM writes:
quote: It is better to look at a 25-foot hull with a Whaler Drive as a 27.5-foot hull. That is why you need more horsepower. The boat has more hull in the water, and that is because the boat is longer. |
| cc378 |
I spoke with Chuck at BW. He thought a 250 even with a WhalerDrive would be a nice combination. |
| Tom W Clark |
While the addition of a Whaler drive does indeed add two feet to the Outrage 25's length, it is nothing like the same-length Whaler 27 which is 2 feet wider and a thousand pounds heavier. I expect an Outrage 25 Whaler Drive with a Honda BF250 to be good for 44 MPH. Is that fast enough for you? |
| cc378 |
Plenty fast enough :) |
| macfam |
Wait a minute! Sure 44 mph is fast enough. But are we to conclude that the Whaler Drive version and notched transom need equal power for equal performance? Extra drag, extra weight that enhances top speed? Really? My 25 Revenge WT with the Yamaha 250 OX66 was set up beautifully, with perfect rpm range at wide open, and several trials with various SS props. Tthe ONLY time it ever saw 44mph was on a trailer being pulled by an F-150. Are we to assume the Honda 250 is more than 250? I can buy that a Honda 250 can get 44mph on a notched transom, but I don't buy it can with a Whaler Drive. Approach 40, yes. Above 40? I really doubt it. Don't. Get me wrong.....around 40 mph is more than adequate. I just want to know where the "magic" is coming from. Are today's props THAT much better? |
| cc378 |
Even if it does 38 that is fast enough for me. I really don't understand the need for additional speed. |
| dgoodhue |
One big advantages of having a higher top speed is higher cruising speeds. Beside a rare short blast, I don't drive at WOT (6000+ rpm) or near WOT for any significant period of time. My boat top speed is 47-48mph and my cruise speeds at 3800-4200rpm are 27-34mph. A couple times I have wanted to get back quickly to avoid a quick moving storm and have bumped my rpm up to 4500 rpm. The difference is a top speed of 38 to 44 mph is likely a 4 difference in cruise speed (assuming the same rpm.) |
To move a boat at a particular speed, whether the top speed or a cruising speed, requires a certain amount of horsepower. If you want a boat's cruising speed to increase by 4-MPH, you will have to use more horsepower at cruise. You don't get more horsepower at cruising speeds for free just because your engine is more powerful. You still have to burn more fuel. |
| cc378 |
I had the opportunity to chat with one of the guys who helped design the WhalerDrive in Rockland in the 1980's. He did not want his name shared. His point of view is that a single large engine on a WhalerDrive makes sense for the 20' and perhaps the 22' but not the 25. He agrees that a single on the notched 25' Outrage makes sense but when you add the WhalerDrive the boat and drive really want twins. His suggestion is twin 150's. His thought is this is the best compromise for weight, horsepower, and performance. Stephen |
Unless you were talking to Bob Dougherty, you probably were not talking to the designer of the Whaler Drive. |
| Peter |
An Outrage 25 with a Whaler Drive is nearly a 27 foot boat. Single outboard on a 27 foot boat? Not for me. I don't recall seeing a single picture in a Whaler brochure from that era showing an Outrage 25 WD powered by a single outboard. |
| bwguardian |
I have had a 25 Outrage with twin 150 Mercury outboards and High Five props. That was the best combination for that boat here on the gulf coast as I could either take it offshore or shallow bay fishing. Offshore it always had great sea keeping abilities and inshore could still get up on plane from rest in thigh deep water! I have sea trialed other 22's and 25's with and without the Whalerdrive. The 22 has twin 135 Mercury outboards hung on a Whalerdrive and does quite well. The 25's I have been in were all notched transom hulls with anything from a single 200 to 300 engines, two and four strokes. My suggestion for you would be twins with the Whalerdrive. If you are looking for economy, go with twin V-4 engines, and if more power is desired go with twin V-6 engines. With the four stroke V-4 engines you will be able to keep the weight down as desired but personally I still like the two strokes. |
I don't think there are any four-cycle outboard engines using a V4 configuration. All the four-cycle outboard engines seem to be using an in-line four-cylinder configuration. |
