posted 10-01-2005 05:14 PM ET (US)
The three small switches under the rubber cover
on the back of the tachometer are dip switches.
Following are the Dip switch functions: SW-1 SW-2 SW-3
Dip switch Trim Sensor Generator Engine
Function Type Type Type
ON * 2 lead 6 Pole 4 stroke
OFF * 3 lead 12 Pole 2 stroke
* number of wire leads on trim sensor
The factory setting for the switches are:
SW-1 ON
SW-2 OFF
SW-3 OFF
This would corresponds to an engine that has a two lead trim sensor (SW-1), 12 pole generator/alternator (SW-2) and the engine would two cycle (SW-3). The tachometer should have had a green hang tag with this information.
John
