ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Wiring Nightmare on 1983 SPORT 17
Author | Topic: Wiring Nightmare on 1983 SPORT 17 |
biggums1 |
posted 03-15-2006 08:11 PM ET (US)
I'm having fun rehabilitating my newly acquired 1983 SPORT 17. There's wire going every place and splices with twist connectors by the dozen. Electrical stuff is foriegn to me. What is the best way to clean up the wiring mess? Do new harnesses exist? Should I perform a do-it-yourself wire by wire replacement? I see twist connectors, soldered connections, crimpt connections and every other U-Haul looking devices. Looks amateur! Thanks for the advise Dave |
carl lazar |
posted 03-15-2006 08:33 PM ET (US)
You can obtain a wiring diagram from CONTINUOUSWAVE. Post an article with the TOPIC: "Wiring Diagram For Boston Whaler" [Actually, look in the REFERENCE section and you will find all the drawings that are available on CONTINUOUSWAVE and other web hosts--jimh.] I used buss bars when I rewired my 1982 Boston Whaler boat and [they] worked well. |
dfmcintyre |
posted 03-15-2006 08:49 PM ET (US)
Dave - The best thing I'd advise, is go to your local marine supply store, West, US Boat, etc., and look for a book on small boat wiring and information in the wiring section of the store. Use marine grade wiring, and I'd lean towards using a small circuit breaker panel rather then the factory standard push/pull switch with fuse. It's a cleaner install. Don |
Tom W Clark |
posted 03-15-2006 09:07 PM ET (US)
Dave, Your question is really too big and broad to answer in a single thread, but let me offer you some advice and encouragement: - I suggest you rewire everything. Period. You will then know everything is new and you will also understand what everything is because you will have done it yourself. - I suggest you do some studying first and look at how other boats have been wired. This is not really a difficult job, but there is a learning curve. - For a first book I suggest: The 12-Volt Bible for Boats by Miner K. Brotherton and Edwin R. Sherman |
Chuck Tribolet |
posted 03-15-2006 09:33 PM ET (US)
First thing to do is to poke around a bit and figure out what goes where. Then draw a wiring diagram of what you have NOW. And tell us what the boat has. Presumably running/anchor lights. But VHF? Fishfinder? GPS? other electronics? The whaler wiring diagram will tell you what the boat came A good rule on boats is to never use any electical parts that The 12V Bible has a good rep, so does Nigel Caldwells book,
biggums1 |
posted 03-15-2006 09:36 PM ET (US)
Thanks for the suggestions from all of you! Tom, I just ordered the book from Amazon ($11.02). I'm learning a lot from this little boat (gel coating, 2-stroke engines, bait tanks, wheel bearings, on and on. Fun to do while newly retired! I'm preparing this boat for action on Ft. Peck Reservoir in Montana this summer. |
posted 03-16-2006 12:34 AM ET (US)
As far as I know there are no pre-made wiring harnesses which are designed to be retrofitted into a 1983 Boston Whaler 17 SPORT. If your outboard motor needs a new wiring harness, contact the manufacturer of the motor. They may have a replacement part available, However, it would be unusual that you would need to replace the engine engine wiring harness. When the boat was delivered to the dealer it had a very simple but workable electrical power distribution system. The haywire you see now was probably added by dealers, installers, and previous owners. Providing a comprehensive course of instruction in marine electronics is beyond the scope of our discussion, and I think you are wise to purchase a good book on this topic. There is nothing like a well written, nicely illustrated technical book to provide information and an organized presentation of information and learning. Good luck with your renovation. When you have a specific question about the electrical system, please post it in the SMALL BOAT ELECTRICAL discussion area. |
biggums1 |
posted 03-16-2006 12:13 PM ET (US)
Thanks for the great advise! Dave |
sosmerc |
posted 03-25-2006 09:28 PM ET (US)
I agree with Tom. Rip out all the old wiring and start from scratch. It's actually much easier and faster this way...and you will know what you have when you get done. Take your time, do one component at a time and use only marine grade materials. I would also advise keeping everything related to the engine (keyswitch and harness, engine guages, etc) seperate from any wiring for boat related items such as compass, fuel guage, sounder, gps, etc. Run a seperate positive and negative cable to a terminal block as your source of power and ground for all non-engine related items. Keep it simple, and keep it neat! |
