posted 04-14-2006 07:44 PM ET (US)
I have just finished installing a converter/trailer light harness on my 99' 4Runner. This will be my 3rd one in 3 years. The first one due to heavy waves at the ramp. The second due to bad install by Uhaul.The install is a bit of a bear since it is hidden inside the trunk side wall trim. Given this and the cost/effort to install, can/should I install inline fuse(s)?
If I added an inline fuse, which of the 4 wires should get one?
Any estimate on appropriate fuse rating? My Load Rite has conventional tails, center rear marker light bar, fender and tongue lights.
I plan to disconnect the harness prior to launching but would feel better knowing a fuse will blow prior to the $40 converter.
Thanks.
Phil
