ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Humminbird Matrix 27 w/ Garmin 76C
Author | Topic: Humminbird Matrix 27 w/ Garmin 76C |
JBG777 |
posted 04-28-2006 03:47 PM ET (US)
Is anyone running the Matrix 27 with Garmin 76C GPS. I'm having the hardest time getting the fish finder to recognize the gps for plotting. I know I should have went with a Lowrance Combo unit from the get go. LIVE AND LEARN! |
Chuck Tribolet |
posted 04-28-2006 04:40 PM ET (US)
Humminbird doesn't seem to have the manual for their GPS connection cables on their website. If you can post what the wires are, I can walk you through hooking it up. The wires will be labeled something like NMEA OUT + (white( Which Humminbird GPS connection cable do you have? Chuck |
Chuck Tribolet |
posted 04-28-2006 04:41 PM ET (US)
And some similar discussion in http://continuouswave.com/ubb/Forum3/HTML/007496.html Chuck |
bspencer |
posted 04-28-2006 04:56 PM ET (US)
I'm not running the same system, but in connecting my Garmin GPSMAP 76 to my Standard Horizon VHF I had what may have been a similar problem. Garmin units are set by default to use their proprietary communication method. I had to manually change the setting to use NMEA Output. I won't tell you how long it took me to figure this out. Brent |
JBG777 |
posted 04-29-2006 08:43 AM ET (US)
I'm pretty sure I have all the right wires and the connections are correct. I have the proper Humminbird/garmin cable and y-adapter installed. I just can't seem to get them recognize each other. Any useful tips would be greatly appreciated. |
Chuck Tribolet |
posted 04-29-2006 11:27 AM ET (US)
The manufacturers have made NMEA interconnection WAAAY more complicated than it has to be. Different terminology, different color codes, and two different but compatible electrical interfaces. So don't immediately assume you have it right. It took me a half day to get my first one working, and I have a masters degree in electical engineering. I tracked down some info what I think is your cable. GPS Serial Data Out (Brown) to FF NMEA IN (Green) The last connection is optional, but will cause the GPS to Now you need to setup the GPS: Go to the Setup Menu, Select Interface And now setup the fishfinder: OH. The Matrix 27 is a fishfinder only. It is not a chart
