Topic: Mercury warning horn
bloller |
posted 04-06-2007 12:27 PM ET (US)
Does the warning horn for a 1993 Mercury 75-HP detect an overheat? Or is it just for low oil condition? If it does warn of an overheat would it sound differently [than it sounds when warning of an oil problem]?
gss036
posted 04-06-2007 02:23 PM ET (US)
[On a Mercury outboard motor the alarm signal for an] overheat [condition] is a constant BEEEEEEEEEEEEEP. [On a Mercury outboard motor the alarm signal for a problem with the] oil [system] is a BEEP BEEP BEEP. |
bloller
posted 04-06-2007 03:08 PM ET (US)
Are you sure? When my oil level gets below a certain point it make a continuous beep. It beeps intermittently only when the oil level moves around while underway and goes below a certain level at times. |
bloller
posted 04-06-2007 03:09 PM ET (US)
Also, what would cause the horn to make sporadic hardly audible chirps sometimes. |
