ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical 1,000-Cold Cranking Ampere Battery
Author | Topic: 1,000-Cold Cranking Ampere Battery |
merc125 |
posted 05-14-2007 04:34 PM ET (US)
Which marine battery to purchase for 1,000 cold cranking amperes? This is for a single battery installation with an electronic fuel injection engine. Thanks Marty D |
Royboy |
posted 05-15-2007 08:22 AM ET (US)
Check your owner's manual. You may be confusing Marine Cranking Amps (MCA) with Cold Cranking Amps (CCA). As understand it, the ratings are derived at different temperatures; Amps at zero degrees for CCA and amps at 32 degrees for MCA. The idea being that people start their cars at zero degrees (if they're unlucky enough to live where this happens) but few people crack up their outboard when it's zero out. My 135 Optimax requires a battery with 750 CCA or 1000 MCA for reliable performance. I suspect your engine has a similar requirement. Roy |
Mambo Minnow |
posted 05-15-2007 12:20 PM ET (US)
I just shopped extensively this spring for 1000 MCA battery and a deep cycle for my two battery system. I recommend the West Marine 1000 MCA in white Group 24 case for $114. The Optimax requires a strong starting battery. That was the best combination of quality and price I found in a traditional wet cell battery. Many other shops only carry a Group 27 with that much MCA. Too big to fit in my remote access battery compartments. I also found their stock to be very fresh date stamped. Purchasing there for me runs countintuitive as most things at West are overpriced in my experience. I got the deep cycle for house circuit at Wal-Mart. After careful consideration, I leaned toward JimH's past advice that double expense of an AGM battery was not worth the additional cost in my particular application. |
rtk |
posted 05-15-2007 04:13 PM ET (US)
Cabelas brand AGM group 24 is a nice battery. A forum contributor used them for his big block Verados, so I do think it will meet your specs. I put two in the boat last season. I did not remove them for the winter layup, just turned the battery switch off. Fired the engine right up this spring without being charged. Rich |
posted 05-15-2007 08:24 PM ET (US)
There are many choices for a 1,000-MCA battery, but this inquiry seeks a battery with 1,000-CCA rating. Please, let's have recommendations only for a battery with a rating of 1,000-amperes at 0-degrees-F. Thanks. |
merc125 |
posted 05-15-2007 10:14 PM ET (US)
I'm having trouble with surging rpm on my 2000 Mercury 200. I rigged this motor myself and the harness is new. My 1997 Dauntless 20 has the battery placed under the passenger side console, so the battery cables are about 16 feet long. I currently have a 750 cca battery, which is greater than the manual calls for.From what I understand the electronic fuel injected motors are very voltage sensitive, and as part of the trouble shooting process, I was advised to get a battery that I could be sure would not be a problem. I realize I may have to double the cables, or get larger ones. MartyD |
rtk |
posted 05-15-2007 11:18 PM ET (US)
Marty, my 2003 Mercury 250EFI only requires a 630 MCA or a 490 CCA or 80 amp hour battery. Do you have a EFI or an Optimax? I have a Cabelas 945 CCA group 24 battery you can try out to see if it resolves your problem before you spend money on a new battery. It is pretty close to the 1000 CCA you seek, and well above the 750 CCA the engine specs. Give me a shout at (732) 604-3718, happy to help if I can. Rich
WT |
posted 05-15-2007 11:25 PM ET (US)
I have 3 Dual Pro batteries in my 170 Montauk. They are great batteries. 1200 CCA http://www.dualpro.com/new/ls3100.html Warren |
