ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Moisture In Gauges
Author | Topic: Moisture In Gauges |
gbcbu |
posted 07-06-2007 07:32 PM ET (US)
My 170 Montauk 2006 has moisture inside the [combinded sidelight lamp] and the voltmeter [gauge] but not the tachometer or the water pressure [gauge]. It's still under warranty and I would appreciate it if [someone] could tell me if this is normal. I can't imagine that it is. I certainly can wait until the end of our season here in the Northeast. Also is the "fix" a new [navigation lamp] and [gauge]? Thanks. |
GreatBayNH |
posted 07-06-2007 09:18 PM ET (US)
http://continuouswave.com/ubb/Forum3/HTML/013508.html |
gbcbu |
posted 07-07-2007 10:00 AM ET (US)
Thanks |
posted 07-09-2007 09:24 PM ET (US)
Moisture on the inside of a sealed gauge is a sign of failure, and if the device is an accessory which is covered under the hull warranty I would take it up with the dealer. You may find that accessories like this are covered only by the original manufacturer's warranty, and in that case you ought to determine what the coverage period is as it may likely be only a year or so, thus requiring prompt action on your part to file a claim. |
GreatBayNH |
posted 07-10-2007 09:56 AM ET (US)
If it is a sign of a failure of the seal then the Mercury Flagship series gauges must not be sealed from the factory. Too many people have noticed the moisture from delivery from the dealer. I hate to think they are all bad. I think it must be the nature of the flagship series gauges. The moisture burns off when underway. |
