posted 09-19-2007 07:57 PM ET (US)
I don't think they can be serviced, but you can test them with a meter or test light. First, I'd check the wiring of the positive leads of the batteries to the switch. Then check that the grounds of the two batteries are connected to each other. If the ground from the engine is only connected to battery 2, and the ground of battery 1 is not connected to battery 2, there is no ground to the engine when battery 1 is selected.
Switch to battery one, hook the meter or test light ground to battery 1 ground, positive lead on meter or test light to the battery one "in" on the switch and make sure you have power to the switch. No power, bad battery lead or poor connection between the battery and switch. If you get a 12 volt reading, then put the positive lead of the meter to the common "out" on the switch. If no reading on the meter or the test light doesn't light it is likely the switch is bad.
You can test the battery switch with all 3 12 volt positive leads disconnected from the switch with a meter that can test for continuity. Put a lead of the meter on battery one "in" and a lead on the "out" of the battery switch. Switch to battery one. No continuity, switch is bad.
Do the same continuity check when 2 and all is selected to make sure the meter is detecting continuity. If you read continuity when 2 is selected, and don't read continuity when 1 and all is selected, I 'd say the switch is toast.
Rich
