Topic: Tachometer Calibration
Binkie |
posted 10-11-2007 01:37 PM ET (US)
I want to install a tachometer on my raceboat powered by a 1974 three-cylinder Chrysler power head on a racing mid section and gearcase. The tach has a switch to set the poles:switch poles #1-- 4 #2-- 6 #3-- 8 #4-- 12 I ran the motor in a barrel at as slow an idle as I can, It is a direct drive motor, and got #1-1400-RPM, #2-900-RPM. #3-700-RPM, #4- 500-RPM, #5=1500-RPM. The motor sounds like it is running about 500-700 -RPM. It also says on tachometer to set the switch to match the outboard engine alternator. rich
posted 10-11-2007 08:49 PM ET (US)
How can we help? |
Binkie
posted 10-11-2007 08:58 PM ET (US)
Anyone know how many poles is used for a Chrysler 3 cylinder motor. What is a pole anyway?rich |
Bella con23
posted 10-11-2007 09:38 PM ET (US)
Rich: I looked it up and your outboard has a 12 pole stator. A pole is the magnetic pickup portion of the alternator assembly. There are permanent magnets imbedded in the flywheel of the powerhead. The stator resides mounted stationary to the top of the powerhead as the flywheel rotates around it.The magnets in the flywheel pass one of the wire-wound "poles" on the stator creating a magnetic field within the stator and thereby generating electricity. The tachometer receives it's pulse each time the flywheel magnet passes a stator "pole". Because your outboard has 12 poles as counted by looking at the underside of the flywheel and counting the small rectangular laminated metal core pickups, the tachometer needs to be set to divide each revolution of the engine by a factor of 12. Hope this helps. Joe
Binkie
posted 10-12-2007 06:46 AM ET (US)
Joe, Thanks for the info, and your time to look it up. Trying to find top speed for this boat is nearly impossable without a tach. The props that fit the racing lower unit are Merc speedmaster props, meant for the original 4 cylinder 140hp powerhead, so with reduced power, I have to get the props reworked to gain rpms.Rich |
sternorama
posted 10-12-2007 04:24 PM ET (US)
just for fun... a handheld non-contact tachometer... http://www.mechanicaltachometer.com/ |
