posted 02-05-2008 01:32 PM ET (US)
Re-charging a battery from a solar panel is not a workable solution for most marine applications on small boats. Solar panels which are affordable only produce a "trickle" of current, and they are useful for maintaining a battery's state of charge by preventing self-discharge currents or other parasitic currents from draining the charge. Solar panels of the size suitable for use on a small boat generally do not produce much current output. If you need to recharge a battery which is in a state of deep discharge, it will take a long time with a solar panel.For example, a 50-Ampere-Hour battery (typical of a small boat's starting battery) is to be charged from a solar panel which produces 100-milliamperes output. The time required is
50-Ampere Hours / 0.1-Ampere = 500 hours
Considering that at best there is daylight only 12-hours per day, and that the solar panel probably only produces its rated output during about half that time, it will take
500-hours/6-hours-per-day = 83 days
of strong sunlight to charge the battery. On days with cloudy skies there will be less charging.
To effectively charge or maintain a battery you need to use a solar panel which can produce 13.5-volts. Because the output of the panel will vary, you need to use a higher voltage output from the panel and to add a regulator.
A battery's charge can be maintained by a solar panel, but given the size and cost limitations assumed to be associated with a small boat, a solar panel is not an effective way to restore charge in a battery which been deeply discharged and has the typical capacity for an engine starting battery in a small boat.
