ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Wire For Bilge Pump
Author | Topic: Wire For Bilge Pump |
modenacart |
posted 02-04-2009 04:31 PM ET (US)
I have a RULE 500 automatic bilge pump. I want to run the wires [from the electrical motor in the pump] to the console on my Montauk. What gauge wire should I use to do this? Thanks. |
seabob4 |
posted 02-04-2009 06:02 PM ET (US)
14GA would be fine. |
modenacart |
posted 02-04-2009 06:33 PM ET (US)
great, thanks. |
Chuck Tribolet |
posted 02-04-2009 06:38 PM ET (US)
14 ga is probably overkill. Check the current draw, then go to the Ancor or West Marine websites to see what size is appropriate for the the current draw and distance.
Dick E |
posted 02-04-2009 06:56 PM ET (US)
Use heat-shrinking connectors |
modenacart |
posted 02-04-2009 07:40 PM ET (US)
How are these? |
TransAm |
posted 02-04-2009 09:03 PM ET (US)
16 gauge will work fine. My 1100 draws only 3.3 amps at 12V and requires a 6 Amp fuse. The 500 should be a little more than half of that. |
posted 02-04-2009 10:42 PM ET (US)
A bilge pump does not require any sort of specialized wire other than the normal marine grade insulated wire needed for all electrical work on a boat. All wire should be rated for marine use. Marine wire means it qualifies to the usually accepted standards. Electrical conductors in cables on a boat should never be smaller than 18-AWG, and power and lighting conductors not smaller than 14-AWG. This is required in federal regulations, although those regulations may not directly apply to small open boats with outboard motors. A conductor of 14-AWG can handle 25-amperes of current in open spaces and when not in a bundle with other conductors. You should consider voltage drop in any circuit when calculating the wire size needed. See this discussion regarding marine wire: http://continuouswave.com/ubb/Forum6/HTML/001447.html Therein you will find much more detail about wire standards, and where to buy marine wire at reasonable prices. A good source of technical information about marine electrical wiring, including the current capacity, a calculator for finding voltage drop, marine color codes, and temperature ratings can be found at http://www.marinco.com/page/wire-tech-data It is not very hard, really. Use 14-AWG for everything, and if you think the circuit is drawing more than a few amperes, increase to 12-AWG. Use larger conductors for primary battery distribution and to feed to sub-panels. |
posted 02-04-2009 10:55 PM ET (US)
See: for some federal regulations on wire material and size. An excerpt: § 111.60-4 Minimum cable conductor size. Each cable conductor must be #18 AWG (0.82 mm2 ) or larger except— (a) Each power and lighting cable conductor must be #14 AWG (2.10 mm2 ) or larger; and (b) Each thermocouple, pyrometer, or instrumentation cable conductor must be #22 AWG (0.33 mm2 ) or larger. [CGD 94–108, 61 FR 28280, June 4, 1996] |
Dick E |
posted 02-05-2009 05:44 PM ET (US)
Modenacart:Heat-shrink wrapping- They are the same ones ones I used last time they work good. |
modenacart |
posted 02-05-2009 10:16 PM ET (US)
Great, I think its going to work just fine. I plan on keeping the run long so I can move the pump around as I wish. |
