posted 05-23-2010 08:12 PM ET (US)
In 12-volt circuits a very thin layer of insulation can block the flow of current. It is possible for just a very small amount of oxidation on connector contacts to affect current flow. When a contact has been affected by oxidation or corrosion and stops conducting current, often all that is needed to restore normal operation is to remove and insert the contact several times. The process of removing and inserting the contact will scrape off the insulation layer and restore the connection. An electrical contact cleaning solution is often applied. The choice of electrical contact cleaning solution must be made with an eye to the other materials in the connector. Some electrical cleaning solvents are harmful to plastics and rubber, common materials in connectors. WD-40 is a reasonably effective electrical contact cleaning solution and is also fairly benign to most other materials found in electrical connectors. Application of a small amount of WD-40 can help restore contacts which have developed an insulating layer of oxidation or corrosion.
In a marine environment water is omnipresent, and water causes oxidation and corrosion of metals used in contacts like copper. To prevent oxidation, it is helpful to keep water and water vapor away from the metal contacts. One way to prevent water from reaching electrical contacts is to use a non-conductive grease as a means of sealing the contact area from any ingress of water. In low-voltage circuits like 12-volt distribution, almost any grease will be sufficiently non-conductive. You can use a grease like petroleum jelly or waterproof outboard grease (as long as it does not contain metals), or you can buy much more expensive and much better insulating (in terms of voltage breakdown) specialized greases, usually sold under the generic name of dielectric grease. As the name "dielectric" implies, these greases are very non-conducting. As non-conductors you do not put them on the electrical contacts themselves, but you apply them to the connectors in a way to prevent water from entering the connector and contact area.
