posted 06-04-2010 10:48 AM ET (US)
An unnecessarily long post follows.After installing a new VHF radio I found it would not power up/switch on. After reading the manual I found I was twisting the power knob rather than pushing it. Pushing it made no difference.
I had surface mounted the radio with some difficulty and hated the idea of removing it and replacing it later. So I called Standard Horizon's help desk. The technician I reached, Devin, suggested the radio was not getting power. Of course I'd already checked the fuse and removed the ground wire from the ground strip and wired it directly to the battery so that both power wires were now directly connected to the battery. He suggested using a volt meter to check battery voltage as a minimum of 12 volts is needed to operate the radio.
Battery voltage was 12.55 volts. Next I disconnected and checked the battery side of the radio to power cable connector pins and found no voltage. I then opened the positive side of the cable at the fuse holder and checked voltage to the battery side of the fuse holder and again found no voltage. What could it be? Could the cable be open inside the insulation. Of course not. Next I removed the battery terminal nuts and placed the radio power cable ring terminals on top of the others and reinstalled the nuts. I checked voltage again from the ring terminals only. That was 12.55 volts.
I then checked voltage from the battery terminal to the fuse holder once again and got no voltage. I decided to test the cable for continuity so I removed it. While preparing to do the continuity test I observed that the ring terminal did not look quite right. Close inspection revealed I had crimped the wrong side of the crimping surface. I've done a lot of terminal crimps over the years and this is the first time I've made such a basic mistake.
Of course when I replaced the ring terminal and reinstalled the wiring the radio powered up properly.
My excuse for such sloppy work is that while I was doing the radio installation it was trying to rain and I was in a hurry to finish up so I could close the console and get in the house.
This fiasco has been added to the long list of errors I have made while trying to do work in haste. I reached my 70th birthday today. You would think I would have learned by now!
