| Author | Topic: NMEA 2000 Interface for 30hp ETEC |
| Alastair |
Does a 2009 E-TEC 30-HP motor support a NMEA 2000 interface [e.g.,] to a Lowrance HDS sounder? I've asked two different dealers and one said no and the other said it should be possible. Can anyone advise if it is possible and if so where does it plug into? Which plug connection from the EMM does it plug into? Thanks anyone for help on this Al |
Typically on an Evinrude E-TEC engine wiring harness for attachemnt to a NMEA-2000 network there will be a four-pole Amphenol SealTite connector available from the EMM with conductors of RED, BLACK, WHITE, and BLUE color coded insulation. This is usually located on a short pigtail from the EMM and covered with a protective cap. To connect to it you need an interface cable with the mating connector and a connector on the other end that is suitable for your NMEA-2000 network backbone. If you have a LOWRANCE HDS unit, the network backbone will probably be wired with DeviceNET wiring components, in which case you can use the LOWRANCE engine adaptor cable. The cable is available from LEI Extras. See http://www.lei-extras.com/store/search.asp?SearchType=Category&Category=LowranceNET+Red The appropriate LOWRANCE-E-TEC interface cable is: Evinrude Engine Interface Cable - Red 120-62 Interface between an Evinrude engine and NMEA network to display engine data. Comes with a T connector. For use with red NMEA network. Now as for the 2009 Evinrude E-TEC 30, I cannot say for certain that it has the NMEA-2000 interface provided. If you have the motor on-hand, you can check for a the NMEA-2000 interface connector at the engine management module. I do see that in the 2010 Service Manual for the 30-HP E-TEC that a "CAN bus" connector is shown in the harness, but the service manual makes no mention of NMEA-2000 interface, and the connector looks different than the usual one I described above. We need an E-TEC expert to resolve this question. |
| seahorse |
NMEA2000 is only on 40hp and larger now |
| SJUAE |
Jim From page 40 of the ETEC 30HP Owners Manual 2010: ENGINE MONITOR SYSTEM IMPORTANT: Evinrude E-TEC 25 and 30 HP outboards A dash-mounted gauge, a warning horn, a CANmodule Gauges For I-Command and other gauges, refer to the gauge user’s Self-Test From page 45 of the ETEC 30HP Owners Manual 2011: Evinrude outboards equipped with remote controls use the SystemCheck engine monitoring system. Self-Test IMPORTANT: If the self-test does not happen as stated, see your Dealer. LOW OIL Warning regards |
| SJUAE |
From page 44 of the ETEC 40hp 2011 owners manual: IMPORTANT: Your outboard may be equipped with an optional engine monitoring system such as I-Command, SystemCheck,or equivalent. Regards |
| seahorse |
There is discussion whether to offer NMEA2000 compatability to the 15, 25 and 30 E-TECs and it would have to be a add-on module as there is no room in the small EMM. As of now there is nothing available and it is still to be determined if customer would want to spend the cost of gauges, adapter module, etc on a smaller engine. Now that the 15HO is selling well, that may push the development of the module as many of the fisherman want to integrate the trolling motor into the boat's network. |
| SJUAE |
Seahorse So the gauge options noted in the 30hp owners manual never existed ? Is that not a rather large error covered by subject to change clause, I guess Is system check also not available ? Regards |
| seahorse |
System Check is standard on those motors. Your owners manual was probably written before the final specs were in production and that's why the reference to I-Command. There is no mention of it in the 2011 manual. |
| Alastair |
Thanks for all your advise on the interface NMEA 2000 for my 2009 30hp ETEC, I was wondering if there is any other way of collecting data from the motor like through a laptop as I would like to see hours run and how high the RPM's are at WOT and general information from time to time. Does anyone know if a data cable of some kind and software to read the data exists for this motor as it sounds like the NMEA 2000 is a non goer for my motor |
| seahorse |
quote:
| Alastair |
| SJUAE |
quote: |
As far as I know, all E-TEC motors have an electronic interface for connecting to the Evinrude Diagnostic Software. It is more or less mandatory, as without the Diagnostic Software the engine could not be set up or adjusted by the dealer, the dealer could not perform diagnostic procedures, and the replacement of certain components like fuel-injectors could not be performed (because the EMM must be fully informed about the precise individual characteristics of each fuel injector, a set of parameters known as fuel injector coefficients that total 33-values for each fuel injector). Based on this I have a very strong belief your E-TEC will have a connector for attaching the interface to the Evinrude Diagnostic Sofware. To make a cable, I have given complete details in a prior discussion. I recommend you carefully read this article to learn precisely how to make the cable: http://continuouswave.com/ubb/Forum6/HTML/002257.html As for the diagnostic software itself, it is generally only available via your local dealer. Check with your local dealer regarding how to obtain the software. The software can be used in two modes: limited mode and dealer mode. In limited mode you will be able to get information from the engine, but you will not be able to make adjustments to the engine. The limited mode is probably preferred as it prevents you from doing anything that might cause a problem in the engine. For an example of what sort of information can be extracted from the EMM of an E-TEC engine, see an article I wrote previously at http://continuouswave.com/whaler/reference/ETEC_EngineHistoryReport.html |
| Alastair |
| Alastair |
Thanks for all your advise on all of the above, I spoke to my dealer here in oz and they advised me that the software is only good for two months and then new software and passwords are required, also I can't seem to locate that trianglar 3 pin plug on my motor would a 2009 30hp which are assembled in China have a different type of connector? I do see a diagnostic connector listed on a wiring diagram with wires 4,5,20. If the software is only good for two months is any aftermarket software available, many thanks |
| seahorse |
Did the "dealer" look you right in the eye as he lied to you about the 2 month software activation? |
Alastair asks: "Does anyone know if a data cable of some kind and software to read the data exists for this motor...." and then repeats the exact question three times in three separate postings. I am sensing a communication problem here, as this question has already been answered several times. The replies given were quite good answers and if carefully read contain the information sought. If you are going to ask questions I have to mention that there is an expectation you will read the answers. |
Sorry--I see the same question posted four time. This is getting silly. |
In the service manual for the 25 and 30-HP E-TEC outboard motors there are numerous references to using the Evinrude Diagnostic Software, and from those I have to conclude that my postulate that a connector exists on the engine which enables the diagnostic software to be linked to the EMM was correct. I do not have first-hand knowledge of the shape or form of this connector on a particular E-TEC 30-HP engine, but it would not make any sense to my way of thinking for Evinrude to use a connector on this particular engine which was different than the connector Evinrude uses on all their other engines. The size and shape of the connector used on all the other engines is not particularly large or inappropriate for use on a 30-HP engine, so, again, I will postulate that the connector used on the 30-HP is the same as all the other engines. However, I may be wrong. My self-doubt is lessened, however, by my experience with reading numerous postings from owners of E-TEC motors who seek advice on locating the diagnostic connector on their engines. From my point of view, the diagnostic connector is rather easy to locate, as its shape is well known, and it is directly connected to the EMM and thus tends to be close to the EMM. However, apparently discovery of this connector has been problematic for other owners. It may very well be that the connector is just not being seen very well by some owners who want to connect to it. |
| hauptjm |
"Sorry--I see the same question posted four time. This is getting silly." Looks like a communication problem between Austrailia and The States. |
| SJUAE |
quote: Now you know why I just re-quoted seahorse reply Maybe if we invert the text he can read it :) Regards |
| SJUAE |
Jim Some pictures I took todayof 09/2009 ETEC 25hp showing EMM and cables http://i707.photobucket.com/albums/ww76/SJUAE/Stern%20and%20misc/ IMG_0007.jpg http://i707.photobucket.com/albums/ww76/SJUAE/Stern%20and%20misc/ IMG_0008.jpg http://i707.photobucket.com/albums/ww76/SJUAE/Stern%20and%20misc/ IMG_0010.jpg http://i707.photobucket.com/albums/ww76/SJUAE/Stern%20and%20misc/ IMG_0012.jpg Regards |
