Author | Topic: NAVMAN 3100 Repair |
![]() ![]() ![]() I came across this interesting home-movie video that describes how to make repairs to the NAVMAN 3100-series instruments, which are somewhat infamous for having trouble with their displays: http://www.youtube.com/watch?v=IGv0zkGQNx0&feature=player_embedded This repair is not for the faint of heart. Also, there is more information about repairs in this thread: http://forums.sailinganarchy.com/index.php?showtopic=77691 One suggestion is to dry out the display in a warm, hot, dry place, which seems to help remove moisture. |
6992WHALER |
![]() ![]() ![]() Jim, I found this video last fall, I have the part and I am going to try the repair this spring. John |
Peter |
![]() ![]() ![]() Interesting. A few years ago the display on my F3100 failed. Northstar sent me a new F310 for a minimal amount so I took my F3100 apart to see if I could figure out what failed. Wasn't obvious to me so I threw it away. |
6992WHALER |
![]() ![]() ![]() I am happy to report that the repair procedure in the video worked. I actually did a combination of the above video and this one http://www.youtube.com/watch?v=BxwRaE9HyC8. I followed Terry's video except; I cut the elastomer to 11 mm not 9mm - to get more pressure from the front cover of the unit. I trimmed off the rubber part on the elastomer were it contacts the plastic cover so it would mate better with the circuit board. (I modified this idea from the Larry video) I had to cut the elastomer longer than Terry because the fuel flow meter has more contacts between the LCD and the circuit board then the depth unit he was repairing. The repair took less then one hour (not counting removal and installation of the unit) Tools required: I just used the unit for a 350 mile cruise. I topped the tanks off twice, both times the unit and the fuel dock pump agreed on the amount of fuel used. (both times the total difference was less then 0.6 of a gallon) The display worked perfectly. Cost was $22.25 for the donor unit. Northstar told me they would fix the Navman 3100 unit for $346.00. Currently you can purchase a new Northstar F310 fuel flow meter for $340.00. |
![]() ![]() ![]() John--Many thanks for the detailed first-hand account of the repair of your NAVMAN F3100 fuel instrument. This sort of information is much appreciated. I am sad to hear that the F3100 or F310 variant are no longer being made. This device was one of the best designed, most user-friendly, and most useful devices I have ever had on my boat. I regret removing mine, which I did only because I switched over to using my modern direct-injection outboard engine as the source of fuel flow information. |
