| Author | Topic: NMEA-0183 Interface: Paired Two-pole Male, Female Connectors |
[This topic was originally a sidebar to a discussion suggesting a four-pole genderless connector. This different method suggesting the use of two two-pole connectors of opposite gender has been separated into its own topic.] |
| Chuck Tribolet |
Another solution [to the problem of interfacing NMEA-0183 serial devices with a generic or universal wiring solution] would be to put a keyed connector with two [female sockets] on the two NMEA out lines and a keyed connector with two [male pins] on the two NMEA in lines, with a convention about where + and - go. These Molex connectors look like they would be suitable. Chuck |
| Chuck Tribolet |
[Reversed the gender of the connectors; this change has been made to the article above-jimh] |
The cost of the MOLEX connector mentioned by Chuck--the MOLEX Mizu-P25 wire-to-wire miniature waterproof connector--is not too high. I have researched these devices and show a source for them with the cost below. A two-pole plug is only $1.31. I could not locate the price for the terminals, but they can't be much more than $0.20-each. We can figure less than $2 per connector. The mating connector is a little more expensive, about $2.73: http://www.mouser.com/Search/ProductDetail. aspx?qs=AplfTeSvkkCNwOPM3Ynl%2fQ%3d%3d With terminals figure about $3.15. This gives us a cost of about $5.15 per device per port. I was becoming interested in this connector until I read the data sheet. It notes that for assembly of the connector a special "cap fitting tool" is required. http://rhu004.sma-promail.com/SQLImages/kelmscott/Molex/PDF_Images/ 987650-5961.PDF That special tooling has cooled my enthusiasm for this particular connector. |
| Chuck Tribolet |
I wonder if that tool is really necessary, or just makes things go faster in a production environment. I couldn't find anybody with an online quote for the tool. I googled up the manual for the tool, I'd guess it would be about $50. BTW, here's a list of splashproof connectors: |
Perhaps to assemble just a few connectors by hand a cap fitting tool could be improvised. Chuck--You should order a couple of those Mizu-P25 MOLEX connectors and see how they work. Let us know how the crimp connectors work with a non-specific crimp tool, how difficult it is to assemble the contacts into the connector bodies, and how difficult it is to install the cap fitting. If it's possible to assemble those connectors without special crimp tools and the cap fitting tool, they look like they'd be a reasonably good connector for the purpose of connecting NMEA-0183 signals between devices. |
| Chuck Tribolet |
I ordered five of each housing and 15 of each terminal. Mouser had the terminals: 50148 (female, $0.21) and 50147 (male, $0.18). One of the terminals is back-ordered.
| Chuck Tribolet |
They arrived today, USPS Priority Mail (which was the cheapest too, BTW). I turns out that I have a crimper that will work. It's a The tool for fitting the cap is not necessary. You can push
| Chuck Tribolet |
I got an e-mail from Mouser today. The terminals that are backordered won't be in until February. No problem for me.
Chuck and I appear to use the same philosophy about ordering terminals for crimp-on and insert connectors: order about 50-percent more than needed to allow for some mistakes during assembly. |
| Chuck Tribolet |
I got an e-mail from Mouser today. The other pins shipped. I won't see them till next week (out of town), so watch this space. BTW, for small, light, shipments, always check out USPS.
While we are waiting for Chuck to get all the components for the connector he chose for this application, there is one other element of the method that needs to be worked out. We need to hear from Chuck on his "convention about where + and - go" for the wiring. As I mentioned in my original article on NMEA-0183 interfacing, there are four possible configurations of the ports and ten possible combinations of interconnecting those four port configurations. We need Chuck to detail how to wire his two-pole connectors so that all of the possible interconnects will produce the desired results. |
| Chuck Tribolet |
The female pins arrived, no surprises. I don't actually have an immediate project for these parts, At this point, I don't see any reason it wouldn't work. I'll 1. Are the male pins or the female pins the output side? (Ans: which ever is best shielded from shorts) 2. Which pin is + and which is -? Ans: It really doesn't
I would like to have an update on this connector installation, perhaps with some photographs. Has any progress been made? |
| Chuck Tribolet |
I've not done anything further on this project at all. My Garmin 162 keeps working so I haven't been motivated to spend for newer, fancier, chart plotter. I will see if I can come up with some pictures of the connectors and crimper.
| Chuck Tribolet |
Here's some pictures. The crimper: Detail of crimper: Terminals and housings: Detail of terminals: I'd use the female housing as the OUT side as it seems like I'd make the OUT wires 1.5" longer than the IN wires so that
Many thanks to Chuck for the pictures of the crimper, the terminals, and the connector housings. From the images, I believe I have a crimper that will work with those terminal. My crimper is a Molex branded crimper, but the details of the A and B crimp jaws looks extremely similar to the crimper shown. |
