posted 07-01-2012 09:12 AM ET (US)
[On Friday] afternoon while out [a friend] noticed gauges fluctuating, headed back to dock, turned off [a 1998 Evinrude Ocean Pro 115 which was later determined to be an Evinrude FICHT outboard engine], and nothing: no beeps, no crank, no power, no tilt. [I] went to help and with limited tools onhand couldn't figure out [the cause of the electrical problem]. [The 1998 Evinrude FICHT 115-HP outboard engine was] brought home and looked over [on Saturday in the morning] and again [Sunday] morning. [Here is] what we know and have done:--battery voltage is 12.8-Volts
--all connections good
--found there is no power going to [ignition] switch
--hotwire switch from under [accesory] panel
--get beeps, crank, start and tilt
--found fuse between relays in fuse box on engine blown
--replaced [fuse] and still nothing
--pulled relays to check
--while pulling lower left relay the fuel pump energized
--[engine] still didn't do anything else unless hotwired
--pulled all relays
--checked connections, and
--they are all good.
[If] [I] hotwire [the 12-Volts from the battery to some point in the circuit which is not clearly identified but probably the IGNITION switch, then] everything works--other than blowing tilt fuse--but [I] expect that, considering [the fuse is rated for] 10-Amperes and we are pulling more than that, I would assume, with [the power] tilt pump. [The] harness also appears good from engine thru transom and hull up to [ignition] switch. [I] have been a mechanic for [more than] 20 [years] and have worked on numerous boats, but not a boat mechanic per se. [Do any readers] have any ideas [about the cause of the electrical outage] or have had same [electrical problem]? [The] boat has been out at least six times this season with out any [malfunctions or problems or electrical outages]. [I] have to believe [the cause of this electrical problem] is something to do with the distribution panel on side of engine where fuses and [relays] are [located]. [Any] help would be greatly appreciated. [The] boat is in my yard and only a few steps away, so [I] can go out and check anything if you have an idea. [Thanks]
