posted 07-19-2012 08:46 AM ET (US)
The wiring looks like it is correct. The GP-32 is a GPS receiver, and it will send position data to the radio, so the radio will know the boat's position and be able to transmit it via digital selective calling.
I am not certain what is going to happen with the connection between the radio OUTPUT and the GPS receiver INPUT. Usually you have this connection to permit the radio to send data to a chart plotter. The GP-32 is not a chart plotter. I don't know what it is going to do with data from the radio. The radio is also an AIS receiver, so it will be sending AIS information. I think the radio is going to be sending data in the NMEA sentences DSC, DSE, and VDM. If the GPS receiver knows of those sentences, I guess it will be able to use that information. I looked on-line for more information about the GP-32, and I did not see a list of NMEA sentences it can operate with as incoming data.
The radio has two serial data outputs. The one noted as "NMEA" or the GRAY conductor is a 9600-bps transmit rate. The one noted as "AIS" is a 38400-bps transmit rate. It appears the GPS has an appropriate high-speed input called "NMEA-HS IN."
You can have two listeners or inputs connected at the same time to a single talker or output, according to NMEA specifications that I have seen. You cannot have two talkers or outputs wired together at a single listener or input.
I am confused about the GP-32 wire that is WHITE. In one case you show it as an input (when you connect it to the radio's output) and in another case you show it as an output (where you connect it to the autopilot's input).
