posted 10-13-2013 11:18 PM ET (US)
Our truck camper was severely damaged by an electrical fire a couple of weeks ago. The camper’s electrical system mimics that of larger boats. It is powered by a pair of 6V batteries connected in series, and they are recharged by an alternator, in this case on the truck rather than an outboard. The batteries are connected to interior lights, a water pump, a three-way refrigerator, and a furnace. The furnace had been giving trouble in a way that suggested it was being supplied low voltage. I replaced the older of the two batteries but was not able to line up diagnostic work while on the road in Alaska. The problem persisted, and eventually the lights would dim when the furnace came on. On the way home, I noticed a smell in the camper after a stop. I had forgotten to turn off the 12V supply to the refrigerator, which normally powers the refrigerator while driving. I made no special note of the smell, and two hours later we were flagged down by a trucker who told us we were on fire.
The fire started in the primary wiring near the batteries. We were able to control it with the fire extinguisher and some added water. We did not lose the truck, and owe that to the trucker and the volunteer fire department that responded.
With the usual 20:20 hindsight, I should have:
--carried a good voltmeter. I might have found the voltage drop in the wiring;
--been suspicious of the primary wiring. In retrospect, I think some of it was added by an owner along the line;
--heeded the obvious sign of low voltage in the lighting when the furnace started;
--persisted in seeking out competent help, even if our trip was interrupted; and,
--chased down the “hot” smell, even though that meant moving supplies and getting under the camper furniture.
I hope this might be of instructional value to another reader.--Dave
