posted 10-19-2013 03:29 PM ET (US)
I bought my 1997 Outrage 20 about three years ago, and it has a c.2005 Lowrance LMS 330C chart plotter and SONAR. The LMS 330C has a five-inch screen and 240 x 320 resolution. It is capable os displaying NMEA-2000 data from my E-TEC, which I rely on and never look at the analog gauges anymore. The SONAR is a fixed 200-kHz 600-Watt system.I have been thinking of buying a used Lowrance LCX-25, -26, -27, or -28. These units are a couple years newer and have:
--seven-inch screen
--480 x 620 resolution
--NMEA-2000 compatability
--50 kHz and 200 kHz 1000-Watt SONAR (but unfortunately my transducer is 73 and 200-kHz), and
--Ethernet (not sure what I would use it for)
SONAR logging to SD card
Of course I would love to do an Elite 7DSI (if it were full NMEA), HDS 7 or 8 ,or a Furuno 1870, but I just don't have that sort of coin. My Lowrance LMS 330C works well now. I mostly would just like a better screen. I mostly use the SONAR for a depth overlay on the map.
Is it stupid to upgrade to an old unit? They can be had for $200 to $300. Are there other units I should look at that have NMEA-2000 and a seven-inch display? I should also be able to use all the peripherals from the old Lowrance (power, transducer, LGC 4000 GPS)
Also, what is the best way to mount these? Modify for flush mount or do a gimbal mount inside the electronics cubby like I have now? Always like the flush mount look, but not sure if it is practical as the current mount I use.
Thanks!
