| Author | Topic: Battery Connections for Outboard Power Tilt |
| picflight |
On my 1998 Outrage 17 the battery is disconnected. I am working on other items and will soon need to lower the motor to clear the area just forward of motor. What wires do I need to connect to the battery to get the tilt motor wired for operation? Link to image of battery box on a boat with PFD's stored close-by. |
| saumon |
For power tilt and trim, blue like the sky is up and green like the grass is down. |
To permit the outboard engine power tilt to operate you need to connect the primary positive and negative cables from the engine to the battery. Operate the power tilt from the cowling-mounted switch on the outboard. |
| picflight |
That green wire seems to be connected on a bracket in the fuel tank. |
The metallic components of the fuel system are connected together by a 10-AWG conductor with green insulation. In newer model Boston Whaler boats the bonding circuit is connected to the battery negative terminal, or, sometimes, to a bronze electrode on the transom that is installed just for the bonding circuit.
| picflight |
[Please ask any questions related to this discussion in this thread. Thanks.] |
