posted 12-06-2013 10:53 AM ET (US)
I am sure you would want the LSS-2 transducer to be oriented so that it was aimed directly down. That is accomplished by the orientation of the mounting holes in the transom, not by some sort of wedge, as least as far as I can see. With a single engine, you can probably mount the LSS-2 transducer in an off-center position, with the offset equal to at least the diameter of your propeller plus some additional offset. Let us say you have a 16-inch diameter propeller. This suggests at least an 8-inch offset. We will double that to 16-inches to give plenty of margin.
I would expect that Lowrance has very explicit instructions on how to mount the LSS-2 on a transom with regard to offset from center and from the engine. I would be guided by their advice. The OUTRAGE hull is not an extremely deep V-hull, and I don't think there will be too much trouble in finding a workable solution.
It may be prudent to anticipate that the optimum location won't be found on the first try. To avoid having to drill too many holes in the boat transom, a transducer mounting surface that was rather wide, say eight inches or more, might be a good idea. (I wish I had done that on my Boston Whaler 22-foot hull transom.)
I have been very impressed with the echo-sound images produced from the Lowrance side scan SONARs, and I look forward to seeing some of yours. Please keep us informed on how the side scan works for you on the Whaler hull.
