| Author | Topic: Arduino Boat-related Projects |
I just came across this recent article about building an autopilot by using an Arduino as host computation device. It is quite an interesting application for the Arduino. See: http://themarineinstallersrant.blogspot.com/2013/12/ the-arduino-autopilot-that-jack-built.html The auto-pilot project uses an amazing integrated circuit device to get compass heading and other data. See http://www.pololu.com/product/1268 The Pololu board provides a three-axis gyroscope, three-axis accelerometer, and three-axis magnetometer for $40. The developer also includes Arduino code to acquire the data from the chip. |
I noticed that Pololu is also offering a device they call an orientation sensor. This device is assembled into an enclosure and has its own processor that can be used to interface to other devices. It is only $200: http://www.pololu.com/product/1255 It would be an interesting project to install one of these orientation sensors on a small boat, then record the various motions and accelerations into a data file. In that way you could have a real analysis of the ride characteristics of your boat. You'd have data for the rotational axis of pitch, roll, and yaw, and the linear axis for heave, sway, and surge. Then you could say, with some precision, just how smooth the ride of a certain hull was in poor sea conditions. |
| Hoosier |
Wouldn't this app do pretty much the same thing since it gives you the x, y, and z accelerations? https://itunes.apple.com/us/app/seismometer-6th/id362472189?mt=8 |
David--That iPhone app looks interesting. Maybe we can get it running on two iPhones, tape the iPhones to our boat consoles, and go for a test run in some head seas. We could compare the boat rides of our two hulls. |
| Hoosier |
I don't have an iPhone but I'm sure we could find one or two in our next boat gathering. This would be a neat experiment. |
