posted 03-05-2014 01:06 AM ET (US)
I've retrofitted a new console onto my SuperSport17-essentially a Super-Tauk.
I've mounted a BlueSea Switch/Fuse combined panel for 'Unswitched' loads on the exterior of the console below the helm surface.
The remainder of the electrical system is
- a 1-2-combine battery switch
- a 6 circuit fuse box for 'switched' loads
- a Negative Buss
- a Positive BussWhat material is preferred/recommended for mounting the 'remainder' components listed above?
I did a cardboard mock-up and it appears a 14' x16" surface will accommodate the components on the port sidewall of the console. I prefer to use 4 stand-offs at the 4 corners of the mount surface to maintain about 1" separation from the console wall to allow for wire routing from behind if necessary.
Maybe something like fiberglass peg-board would work well, but also considering plain 1/4" [FRP] fiberglass laminate material for the mount surface, unless someone has a better suggestion.
Thanks for your time.
Joe
