| Author | Topic: USCG Requests Feedback on AIS Aids to Navigation |
The United States (of America) Coast Guard announced last month (on February 2, 2104) that it would in the near future begin test transmission of AIS messages for a new category of aid to navigation (AtoN) called AIS AtoN, a sort of virtual and electronic-only navigation marker. The USCG issued the following statement on their NavCenter website:
quote: Source: http://www.navcen.uscg.gov/pdf/AIS/AIS_ATON_Special_Notice_v3.pdf |
The AIS AtoN devices will be of three characteristics: real, synthetic, and virtual. A real AIS AtoN is an actual physical aid to navigation, such as a buoy, a day mark, or a light house, whose actual position is transmitted as an AIS message. The AIS transmission originates from the actual physical location of the aid. A synthetic AIS AtoN is also an actual physical aid to navigation, but the AIS transmission originates from a base station nearby, not from the physical location of the aid itself. A virtual AIS AtoN has no physical manifestation. There is no buoy, day mark or tower, but only an AIS signal. The AIS signal originates from a nearby AIS base station. In order for these AIS AtoN signals to be received, the AIS receiver and the associated display device must be capable of decoding AIS messages of Type 21. Not all recreational chart plotters are necessarily assumed to be capable of properly handling AIS messages of Type 21. Further, assuming that a recreational chart plotter can handle and decode AIS messages of Type-21, the manner in which they will present an AIS AtoN described in those messages on a chart display is also likely to be variable. In order for recreational boaters to participate in the USCG request for feedback, it will be necessary to have an AIS receiver and chart plotter that can handle AIS Type 21 messages. It will also be necessary to be in range of the AIS transponders that will be sending these signals. |
| padrefigure |
Any idea which recreational chart plotters are capable of receiving, translating, and displaying Type 21 messages? |
I am fairly confident that most AIS receivers will be pleased to receive an AIS Type-21 message and output the received data. The problem will be in the chart plotter receiving the AIS message. I suspect that many recreational chart plotters may not know what to make of a Type-21 message. At the moment, I don't have any source of a Type-21 message to test with. I have written to the support website for my chart plotter to see what they have to say about display of Type-21 messages. As soon as I have an answer from them, I will post the information. Perhaps several readers could do the same for their particular brand and model of chart plotter, and we could collect the data here. I have written to: Polar Navy regarding PolarViewNS and to Lowrance regarding HDS Gen1 chart plotters. |
For the type of AIS AtoN the USCG refers to as a real AIS AtoN, there will be an AIS transponder on the actual aid to navigation. The transponder will need electrical power to operate, and, if the aid to navigation is a floating aid, such as a buoy, this electrical power will have to be carefully managed. Typically an AIS AtoN transmitter will have a power output of about 2-Watts. Unlike lighted buoys, whose lamps are only illuminated during darkness, an AIS AtoN will have to operate its transmitter continually, day and night. A further problem for a floating AIS AtoN is the power consumed by its AIS receiver. It may be necessary for a floating AIS AtoN to also have an AIS receiver in continual operation. The transmission of AIS signals is done by coordination of all AIS transponders in range of each other. For the AIS AtoN to know when it should transmit, it would have to listen for AIS traffic in its local area, and then coordinate its transmission. An alternative method is for a floating AIS AtoN to be designed to work in tandem with a base station. The base station will transmit an AIS signal that includes data informing other AIS transponders to reserve a time slot in their time-shared network for the AIS AtoN. The AIS AtoN can then always transmit in the reserved time slot. It would not have to continually listen for local AIS traffic and fit itself into the slot pattern. This approach can conserve power drain by reducing the receiver operating time. Also, the AIS AtoN must operate a GPS receiver so that it can know the actual position to send in its AIS broadcasts. |
| Chuck Tribolet |
However, the AIS AtoN doens't need that 2W 7/24. It only needs the 2W in its time slot. The duty cycle is pretty low. Chuck |
A recreational boat grade Class-B transponder says its average power consumption is 170mA at 12-VDC, or about 2.1-Watts. Compare at: http://www.digitalyacht.co.uk/files/AIT2000%20User%20Manual%20V1_01_Eng. pdf Page 29 |
The power consumption of an AIS AtoN will be related to --the need to have a receiver listening for traffic on the AIS channels all the time --the frequency at which its transmitter is actually operating The least power consumption will be for an AIS AtoN that is working in tandem with a base station that is reserving the transmit time slots, and thus does not have an AIS receiver running, and the AIS AtoN only transmits its position in those reserved time slots once every three minutes. (In AIS, the frequency at which an AIS transponder sends its position is a function of how fast it is moving. Rapidly moving vessels transmit their position more often than slow moving vessels. Apparently AIS AtoN, which are not moving at all, only transmit every three minutes.) The SRT company has such a device, their CARBON model for AIS AtoN applications, and they rate the power consumption as less than 0.1-Ampere-hour per day in certain modes. A very good overview of AIS Aid to Navigation can be found at http://www.navcen.uscg.gov/pdf/AIS/IALA_1062_AIS_as_a_Aton.pdf The above publications sets out the three general types of AIS AtoN: --real --synthetic --virtual For the real category, it sets out three types: --Type 1: transmit only station --Type 2: similar to Type 1 but with a receiver for remote configuration --Type 3: full transmit and receive station All three types of real AIS AtoN are able to "switch off and sleep" between transmission to conserve power. In addition to just sending their identification and position, a real AIS AtoN can also send sensor data. The sensor can provide data on weather, tides, and sea state. A significant benefit of a real floating AIS AtoN is the confirmation of the position of the aid. For example, a floating buoy with an AIS AtoN can confirm its position as being on station. |
Re the three-minute transmit interval: I have not found that mentioned in any official specifications, but it is mentioned in some literature about the SRT Carbon Type-1 AIS AtoN device at under the "Specification" tab: 'Power consumption: from 0.1Ah/day (Type 1 AtoN with 3 minute position reporting rate)" In that same place under the "Overview" tab the device power consumption is also mentioned: "It exhibits by far the lowest power consumption requirements in the market place at 0.06 Ah/day (Type 1) and 0.5Ah/day (Type 3)." That is really rather remarkably low power consumption. I guess if a floating aid has enough battery power to run a lamp all night, it will be able to run a Type-1 AIS AtoN without too much trouble. |
The technical term for the frequency of transmission of an AIS transponder is reporting interval. The reporting interval is given in a standard, ITU-M.1371-4, "Technical characteristics for an automatic identification system using time-division multiple access in the VHF maritime mobile band." There are two general categories: Class A shipborne transponders, and all other transponders. Here is a summary of the reporting intervals: Class A shipborne Other than Class A shipborne "SO" means self-organizing time division multiple access or SO-TDMA; "CS" means carrier sense time division multiple access or CS-TDMA. Source: http://www.allaboutais.com/jdownloads/AIS%20standards%20documentation/ itu-m.1371-4-201004.pdf |
I asked Lowrance support:
quote: Lowrance support replied:
quote: By inference, I suggest that this means all the HDS Gen1 and Gen2 chart plotters will show AIS targets described in Type 21 messages, and it is also likely that the similar SIMRAD chart plotters will, too. Now I just need a source of some AIS AtoN Type-21 messages to test my HDS. I will watch the USCG website for more information on announcement of some tests and the location. |
I asked Polar Navy (developer of PolarView NS):
quote: Polar Navy replied:
quote: |
I had some correspondence with the USCG about the present marketplace of recreational chart plotters and their ability to show AIS AtoN targets. The USCG expressed confidence that, now that they have begun to broadcast AIS AtoN messages, the marketplace will diligently upgrade or bring to market equipment that can decode AIS AtoN messages. |
I was hoping that the Coast Guard might deploy an AIS aid to navigation in the Great Lakes region, and, if they did, I would have tried to receive it in order to see if its position showed up on my two chart plotters. So far, as best I can tell, there are no Aids TO Navigation (ATONs) using AIS anywhere close to me, but there are plenty in the San Francisco area. Accordingly, I would like to encourage anyone in the vicinity of the Golden Gate Bridge with an AIS receiver and a chart plotter (that are connected together) to test their system. Check to see if the AIS ATON's show up on the chart display of your recreational grade plotter. You can see where these AIS ATONs are located by using MARINETRAFFIC.COM. On their website you will find the AIS ATONs marked with distinctive (pink) icons. There are about 17 AIS ATONs in the region. I would appreciate hearing any reports of how they display (or do not display) on various recreational-grade chart plotters. |
In addition to the San Francisco area, the USCG appears to have also deployed a few AIS ATONs in the following areas: --several on the Mississippi River from New Orleans to Baton Rouge; --one offshore from Astoria, Oregon; --two around Seattle, Washington. To anyone in those areas with an AIS receiver connected to a recreational chart plotter, I invite you to also check to see if these AIS ATONs are showing up on your chart plotter due to reception from an AIS receiver. |
