| Author | Topic: VHF Ship Station Transmitter Power |
The maximum power for a ship station transmitter in the VHF Marine Band is given in 47 CFR 80.215 - TRANSMITTER POWER. and is mentioned in several subparts. In subpart (e):
quote: In subpart (g):
quote: The manufacturers of VHF Marine Band radios often specify the power output of their radios at 13.8-Volts DC, which is 0.1-Volt higher than the FCC specification. I believe they do this because this will, when the radio is operated at the FCC specified maximum voltage maximum of 13.7-Volt. cause the power output to not exceed 25-Watts. Subpart (g) goes on to say:
quote: For the technically curious, the channel numbers for the mentioned frequencies are 156.375-MHz = 67 Channels 67 and 13 are designated as Bridge-to-Bridge communication—that is ship bridge to another ship bridge or a highway bridge—and are usually used at 1-Watt, but they can be changed to full power. Channels 75 and 76 are the channels adjacent (in frequency) to Channel 16, the distress, safety, and emergency calling channel, (156.800-MHz), and limiting power to 1-Watt is mandatory and cannot be overridden by the operator. This provides a bit of a guard channel so that a nearby station operating on 75 or 76 would not desensitize or interfere with a receiver tuned to 16. I believe at one time no transmission was permitted on those channels. (I have a c.2001 radio, and it does not provide those channels.) |
To summarize: A fixed-mount VHF Marine Band radio must produce more than 8-Watts but no more than 25-Watts power output, and must contain automatic power reduction to 1-Watt on certain channels, but permit override to full power on some of them. A hand-held or portable VHF Marine Band radio must produce no more than 10-Watts, and is exempted from some of the automatic power reduction regulations. If the radio transmitter is operated from a lead-acid storage battery, the power output is to be measured when the supply voltage is in the range of 12.2 to 13.7-Volts. |
