posted 06-02-2014 03:16 PM ET (US)
The application GPS Babel can read from files of many formats and translate the data to many different formats. A popular output format for GPS Babel is .GPX, the GPS eXchange format. In working with GPS Babel it was noticed that files exported from the application in .GPX format could not be imported to the Lowrance HDS-8 chart plotter. Upon attempting this import, the HDS would give an alert message:"Import failed: File version 1.0 not supported"
Upon some research and experimentation, it was found that GPS Babel could be configured in its output options to write a GPX file in GPX version 1.1. This option is configured in the GPSBabel window, in the lower pane called OUTPUT. With the OUTPUT configured for FILE and Format=GPX XML, click on the OPTIONS button. A new dialogue box appears, the GPSBABEL OPTIONS FOR GPX. Place a checkmark in the box for the option "Target GPX version for output" and type "1.1" into the data entry box associated with that option. Click OK. The dialogue box window closes.
In the GPSBabel window, you should now see the text field next to the OPTIONS button contains:
"gpxver=1.1"
This will generate an output file with a header that says:
<?xml version="1.0" encoding="UTF-8"?>
<gpx version="1.1" creator="GPSBabel - http://www.gpsbabel.org" xmlns="http://www.topografix.com/GPX/1/1">
A generated GPX file with this header was succesfully imported to an HDS-8.
