posted 07-01-2014 05:26 PM ET (US)
I just got back from two weeks of boating near Morehead City, North Carolina, in our 1984 Outrage 25 with twin 2006 Optimax 150s. It is a great place to boat.In prior years, with a transom mounted transducer, whenever I got into shallow water there would be interference with one of the motors and the unit would stop reading (less than 5'). If you know the backwaters in that area, 5' is not shallow at all, so for where I really needed the depth finder it was useless. I'd had lesser problems before with the transducer on our Striper 15 with single engine, where it would read down to about 3' before pegging and not giving a number.
Last year, I installed a through-hull transducer in the boat. I picked the Airmar SS264. Since most usage for me is fairly shallow, I went with the 200 kHz model in the wide configuration. I considered a more typical B64, but I was hoping that the taller height of the SS264 would simplify installation (it did somewhat). I drilled a large hole in the fish well on the port side, then a larger hole on the inside to seal off the core with resin and fiberglass, and then a larger hole yet to "countersink" the transducer nut slightly since the hull was too thick for the thread depth on the transducer. If you've done any fiberglass work before it is not complicated to do but drilling the big hole does take some nerve (I've got a neat hull core piece I saved from the install). The transducer is mated to an NSS8 transducer.
The transducer reads accurately down to 1' under the keel, at which point I can feel the motor bumping bottom with the skeg. It holds clear readings perfectly through turbulent water and waves and such, and it is difficult to ever get it to lose a reading (the only time I succeeded in doing so was when I was in a lot of aerated whitewater behind a large powered catamaran, and then only briefly). It also gives very clear readings in more normal depths.
I've searched and read some on ContinuousWave about a few others who installed through-hull transducers. After seeing the difference of using one, I have a strong preference towards them for my uses, and the install is manageable.
[Note - the Outrage 25 has a place in the forward storage locker where the hull is basically solid, but that is so far forward I did not use it - I wanted the transducer near the stern so it keeps good contact - it is about 3-4' in front of the stern]
